Old 03-14-2013, 03:32 PM   #651
AirManCam
Member#: 219513
2006 STI
Originally Posted by Slimsti View Post
Looking forward to the updated times.
Me too! I'm doing a full brake system over haul to help slow the ol' girl down. Putting e85 in it and turning it up another 100whp or so. I'll be sure to post videos if I don't break it first
AirManCam is offline   Reply With Quote
Old 03-14-2013, 09:22 PM   #652
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Sounds sick man. Gotta love e85. Big injectors and pump and retune and boom 100 more whp
Slimsti is offline   Reply With Quote
Old 03-15-2013, 12:43 PM   #653
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Here is a look at the 50-100 for my 08 STI. Full build details: http://forums.nasioc.com/forums/show....php?t=2472813
This is now running E85 on the pump tune with injector scaling changed. I'll do an E85 tune here in the next week and see if I can get a bit more out of it.
Vehicle: 2008 STI
Motor: Built WJ257
Turbo: EFR7670
Boost: 24-25.0 psi
Transmission: Stock 6-Speed
Redline: 7800
Upgrades:see http://forums.nasioc.com/forums/show....php?t=2472813
Cobb AP SD
Weight: 3450 lbs empty, with me 3648lbs
50-100MPH: 3.99 (24-25psi, 480ish whp), 4.99 (21-22psi 430ish whp)
You can see that the higher boost makes a bigger difference at the lower RPMs in 3rd gear. The slope once in 4th is almost the same.
I also did a run in 4th gear only, and indeed it is slower. The 60-130 might be different, and I'll be curious to give that a try.
Also, here is a look at boost for the faster run:
I really should turn on flat foot shifting.. that boost drop sucks.
Jeff
sponaugle is offline   Reply With Quote
Old 03-15-2013, 01:10 PM   #654
Slimsti
Member#: 155696
Wow Jeff thats sick man and some really detailed graphs. Nice post. Seems like you dropped a full second off 50whp. I wonder if that carries over through to other build and setups? Your making huge power for only 25psi, that turbo is pretty happy.
Old 03-15-2013, 01:26 PM   #655
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Yea, although on the street it is hard to tell how accurate the whp number comparison is. Boost is more on the street at a lower RPM, so my butt dyno says the higher boost is a bit more then 50whp difference.. and I am running E85 right now so that might add a bit. Once I get on the dyno with the E85 it will be cool.
Jeff
Old 03-15-2013, 01:29 PM   #656
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Vehicle: 2008 STI
Motor: Built WJ257
Turbo: EFR7670
Boost: 24-25.0 psi
Redline: 7800
Cobb AP SD
[IMG]http://www.sponaugle.com/nasioc/08STI50to100MPG.png[IMG]
[IMG]http://www.sponaugle.com/nasioc/08STI50to100Boost.png[IMG]
Jeff
Nice times. Must be a quick car! The comparisons are great to see as well. I think you could easily shave a few 1/10th's with a flat foot shift!
My car dropped about 1/2 second per 40WHP on Virtual Dyno. Loosing a full second with 50WHP is a bit surprising based on what I've seen, but all my testing was within a single gear.
Old 03-15-2013, 03:39 PM   #657
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Exclamation
Yep, based on road feel I suspect it is more like 70-80whp difference.. and of course in 4th gear the boost is higher then what I had on the dyno.. especially in the 24psi run. Boost control with the current wastegate has been difficult because I have the actuator preloaded a lot, which makes it temperature dependent.
If anything this shows how difficult it is to just dyno tune.. so many different variables on the road.
I'll turn on the flat foot and do some more longs this next week.
Jeff
Old 03-15-2013, 06:13 PM   #658
Slimsti
Member#: 155696
Yeah ffs makes a huge difference for me. I'm almost a full second slower without it.
Old 03-15-2013, 10:42 PM   #659
dmjhockey19
Member#: 258009
04 sti
wrb
Ffs made no diff for me and airmancam actually had faster times without it too. All about that footwork bro!
dmjhockey19 is offline   Reply With Quote
Old 03-15-2013, 10:45 PM   #660
Slimsti
Member#: 155696
Yeah I tend to drive way to soft without it thus shifting slower where as when I'm ffs I flog the thing. Lol makes no sense.
Old 03-15-2013, 11:40 PM   #661
dmjhockey19
Member#: 258009
04 sti
wrb
I got you there... I beat on my car when I drive it. Granted I only put 1k on her last year
Old 03-15-2013, 11:41 PM   #662
dmjhockey19
Member#: 258009
04 sti
wrb
And that my friend is a failed /quote
Old 03-15-2013, 11:44 PM   #663
Slimsti
Member#: 155696
I envy ur mileage. Having ur project car as ur dd tends to spoil some of the modding/abuse fun.
Old 03-16-2013, 05:50 PM   #664
AirManCam
Member#: 219513
2006 STI
Good luck daily driving a modded subaru. I get pissed off just looking at mine.
Old 03-16-2013, 05:56 PM   #665
AirManCam
Member#: 219513
2006 STI
Originally Posted by amalgrover View Post
If that is his tire and wheel size, then he is maybe a little faster from 50-100mph than has been calculated. that tire and wheel setup would hit 100mph when his speedometer says 98.3mph. The proper reading would be from about 49.3-98.3mph...as fast as his car is, i think an error of 1-2mph is only going to cost maybe a couple 10ths at the most, but still awesome to be able to say that he could be even faster.
Yeah, I'm on 18x9.5's with 235/40 federals. Big ol' heavy tire and wheel combo I weighed them before I can't remember how much they weighed exactly but mid-high 40's. Putting on my set of stock wheels and tires would probably save me 3-4 10ths from rotating mass alone.
Old 03-16-2013, 06:34 PM   #666
Slimsti
Member#: 155696
Lol honestly I've been lucky I guess. Threw a built block in at 19k and.now.have 62k and.have not had 1 issue. 415/405 everyday. I don't get on it often though.
Old 03-16-2013, 07:53 PM   #667
AirManCam
Member#: 219513
2006 STI
I guess so LOL! I threw a built block in at 46k, 47k and 59k LOL.
Old 03-16-2013, 09:59 PM   #668
Slimsti
Member#: 155696
Hahaha omg I would've just threw in the towel and bought a KIA at that point. You sir are quite stubborn
Old 03-17-2013, 12:13 PM   #669
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
^ this...I LOVED it when my car was working, but it only managed to run about 6 months out of the year...partly because I have ZERO luck and partly because I was pretty aggressive with it
Old 03-17-2013, 07:04 PM   #670
Slimsti
Member#: 155696
Yeah most of my buddies are all on there 2nd or 3rd built block or have moved on to a new model sti or swore off subaru all together and bought evos, yet mine is still going. I'd say its partly cause I'm usually in traffic to and from work so it doesn't see many wot pulls and because the tune is on the conservative side. I mean I have a fully built block, Dom3xtr,fmic and meth and I'm only making 415/405, I'm sure I could squeeze Way more out of it but I'd prefer to make just over 4 and not have to constantly have issues.
Watch me blow my motor tomorrow now cause I said this. Lol
Old 03-17-2013, 07:47 PM   #671
shano
Member#: 223839
2004 WRX
Java black
Yup. You just jinxed yourself bigtime.
I'm just jealous because I have to constantly worry about my 5spd exploding.
shano is offline   Reply With Quote
Old 03-17-2013, 08:03 PM   #672
Slimsti
Member#: 155696
Yeah that's a crappy situation to be in. You can make big power on a 5speed but its only a matter of time before something breaks. Then ur left with the dilemma. Sell it and buy an sti, do gears or do a 6 speed swap. My buddy learned the hard way and replaced his 5 speed with a new 5 speed 3 times before biting the bullet and doing the 6 speed swap. He wasted so much money
Old 03-18-2013, 12:26 PM   #673
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
So how is your day going? Lol
thisisntjared is offline   Reply With Quote
Old 03-18-2013, 12:28 PM   #674
Slimsti
Member#: 155696
Hahaha all is well thus far. Lol
Old 04-14-2013, 02:52 PM   #675
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Default Manitou's XTI 50-100 time
Vehicle:2006 XTI
Motor:HP Techs, MPS SS LR 2.5
Turbo:Blouch 3.5XTR, 8cm HS
Boost:25 psi
Transmission:2007 STI 6 speed
Redline:8000/ revved to 7600
Upgrades:
  • HP Tech's big valve, PnP'd, cammed D25 heads
  • Killer B Holy Header w/ custom Tial MVR up pipe
  • Custom 3" Exhaust w/ 1 3/4" Supertrapp muffler EWG exhaust
  • Walbro 465 hard wired FP
  • Perrin TF fuel rails
  • Aeromotive 1000 FPR, 55 psi base
  • ID 1000 injectors
  • ETS TMIC
  • PnP's STI intake, TB
  • Custom 3" Vibrant SRI in customized closed Cobb box
  • Cobb AP SD tuned by Junior2JZ, E85
I ran a log on 4/2/13 and posted a VD graph of it on my thread. I decided to VD graph just the 50-100 mph portion of the log based on my MFactory gear calculations for speed/ rpm's/ gear's. Here is a link to the full pull VD graph.
http://forums.nasioc.com/forums/show...2480570&page=3
Here is my 50-100 mph time based on this portion of the 3rd gear log.
Here is the VD time/ rpm graph
Weight: Full Stock Weight for an XTI+ driver (it's not at all a stock FXT) probably 3600 lbs. with all the crap I had in it not including me!
50-100MPH: 4.19sec
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
