Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 12-13-2012, 11:39 PM   #1
Scooby Driver
Member#: 1966
Chapter/Region: PRSIC
2000 Sti swap RS
Default 2003 wrx A/t on a 2000 legacy outback
As the title said, is it posible??
My outback broke the auto tranny and I found one out of a 2003 wrx, also auto... can I use it on the outback??
Thank you guys...
Scooby Driver is offline   Reply With Quote
Old 03-13-2013, 12:31 PM   #2
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Thank you guys...
What year outback?
The short awnser is yes it will, but....the rear diff is more likely then not gonna have t be swapped with the wrx trans, there are about 6 diffrent variations of gears in these transmissons. Since they are awd the rear diff needs to match the diff in the trans. With that said, I know outbacks generaly have the taller gear sets (my xt has a 4.44 with the 5 speed) and wrx's are either 3.92 or 4.11, don't hold me to that...the automatic outbacks may have the 4.11's but I'm not positive. There are a lot of collective right ups about what's in what if you look around a bit you'll find your awnser, what ever you do, make sure they are matching gear sets, or you'll be replacing another trans really quick.
Sneeky Pete is offline   Reply With Quote
Old 03-14-2013, 08:22 PM   #3
PA-Outback2000
Member#: 161832
2000 Outback Limited
if the trans has the sport-shift feature, it won't because the computers controlling the 2 trans are different.
PA-Outback2000 is offline   Reply With Quote
Old 03-15-2013, 10:29 AM   #4
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
This is possible too, again Id need to know what year ob you have, I know my 05 limited has sport shift
I just opened my eyes...son of a beech its amazing what you see when you do...2k leggo's don't have sport shift, I believe wrx's did, so yea unless you wana swap a trans ecu as well as other unknowns your better off finding a more dirrect fitting trans
Old 03-18-2013, 01:03 PM   #5
PA-Outback2000
Member#: 161832
the 4EAT trans is "physically" the same and should fit.
but like i said, the computer programming/control in the sport-shift version is different. you would also need the interior shift lever/mechanism with the sport-shift "gate" in it if you went that route. i would just find another legacy trans or rebuild the current one.
what are the issues you are having/had?
