Closed Thread
Old 03-16-2013, 08:15 PM   #1101
fu5i0n
Member#: 350137
Xluben can you pm your contact info? want to send you an email but can't do it through site
Thanks.
fu5i0n is offline
Old 03-16-2013, 11:14 PM   #1102
xkadajx
Member#: 347572
2013 WRX Hatch
Do you have any keys for the 2013 WRX xluben? Shoot me a PM please. Thanks.
xkadajx is offline
Old 03-17-2013, 12:23 AM   #1103
olazy
Member#: 263322
2011 WRX Limited
WRBP
i think i may have been one of the first to buy a shell, finally got a chance to get this done. ended up dremeling an original key to fit. thanks x!
olazy is offline
Old 03-17-2013, 12:53 AM   #1104
austriker
Member#: 315079
2011 Impreza Outback
Silver Bullet
So I got mine cut today at the dealer and it surprised me how cheap it was. Twenty bucks!! They were so surprised to hear and see what I was doing.
Now I just to figure out why the buttons are sinking in when I don't leave my padding in. Anyone else have this happen?
austriker is offline
Old 03-17-2013, 12:58 AM   #1105
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks.
Will do.
Replied to your email. 2013 WRX is identical to this.
Great!
Is it screwed all the way together now?
Are the shell gables separating when you push the buttons?
Do iou have the front and back installed on the Legacy remote inside the housing?
Can you take some photos with the housing opened up?
This is definitely not normal.
xluben is offline
Old 03-17-2013, 01:55 AM   #1106
austriker
Member#: 315079
Silver Bullet
Its screwed in about 98% as I didnt want to strip the plastic.
Uhm what are the shell gables? Sorry I really am unfamiliar with the terms.
Oh wait a second here, so I just put in the front part of the legacy key with the buttons, not this back part you are mentioning (which I assume is the black thing with the circular silver thing inside). If my assumption is correct thats probably my issue huh. Gosh Im a dufus.
I will take some pics tomorrow- thanks for all the help!!!!
Old 03-17-2013, 01:57 AM   #1107
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Sorry. Typo. I meant to say "shell halves". If you dint have the full Legacy remote in there then that is your issue! It should be a tight fit.
xluben is offline
Old 03-17-2013, 02:01 PM   #1108
austriker
Member#: 315079
Silver Bullet
Holy cow I'm a fool. In my excitement to put it back together I forgot to put the legacy key back together. After putting it together it fits well. Thanks for all the help. Now the tricky part of programming it!
EDIT: after reading through several times of the directions I finally got the courage to go ahead and do it (since I messed up on the fob). Nailed it the second time! Its awesome, thanks sooooo much xluben! Highly recommend you all try it and get the stuff from him directly.
Old 03-18-2013, 09:18 AM   #1109
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Great! I'm glad you got it working! It's pretty simple if you take your time. And I'm happy to answer questions.
xluben is offline
Old 03-18-2013, 05:25 PM   #1110
StealthWRX
Member#: 50175
RHD Bugeye & '11LGT
Brainchild Customs
question - I have a 2011 legacy and just bought the flip key shell.
I got the blank cut today, and I'm wondering, will I still need to program the remote if I am using the guts from a spare key remote that came with the car (i.e. is already programmed?)
StealthWRX is offline
Old 03-18-2013, 06:11 PM   #1111
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You will just have to transfer over the remote and the transponder. No programming required. Getting the transponder out of the Legacy key can be tough. You may end up destroying the key shell in the process.
xluben is offline
Old 03-18-2013, 06:29 PM   #1112
StealthWRX
Member#: 50175
RHD Bugeye & '11LGT
Brainchild Customs
Thanks very much! Great thread
Old 03-18-2013, 07:27 PM   #1113
fu5i0n
Member#: 350137
Anyone in the San Jose/Bay Area that had success getting theirs laser cut? striking out calling dealerships and locksmiths
if so you can supply place you got it cut and the price?
fu5i0n is offline
Old 03-21-2013, 03:36 PM   #1114
lcrazyaznl
Member#: 350014
14 Forester XT
Crystal Black Silica
I just got a 2014 forester xt. Not sure but I had the old style milled keys, its like the legacy where all the buttons are built into the key.
Would I be able to make this mod work?
lcrazyaznl is offline
Old 03-21-2013, 03:39 PM   #1115
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, the only issue may be getting a proper blade. I have blanks for the laser cut blades and for the older standard blades, but the newer Impreza has a non-laser cut blade that is thinner on both sides. I don't have any blank blades like this. If you could post a photo of you key I should be able to tell you if I have a blade for it or not. If I don't have the blade, then you're only choice is to modify your stock blade to fit into the housing.
xluben is offline
Old 03-21-2013, 04:29 PM   #1116
lcrazyaznl
Member#: 350014
14 Forester XT
That is what I figured. It looks like its not the thin blade. It looks like your standard key.
Old 03-21-2013, 04:37 PM   #1117
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, but does it have the thing portion on one side, or both? Here are examples:
Standard Blade (ie. Most 02-07 Subaru's):
It may be hard to see, but this has a thin side, and then a thick side. It also has one groove running down the length of the blade.
Newer Blade (ie. 2012+ Impreza):
The one is thin on both sides. It looks basically like the other one, but the thicker side is machined down to being thin all the way up to the groove.
I have the 02-07 blade, but not the 2012+ style. Depending on which style your key is will determine if I have the parts or not.
xluben is offline
Old 03-21-2013, 05:24 PM   #1118
lcrazyaznl
Member#: 350014
14 Forester XT
It looks like the impreza key it says g on it
the orginal grove is in the middle and the top and bottom are milled down to the middle if i'm correct.
Old 03-22-2013, 02:31 PM   #1119
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If you want to know for sure you'll have to post a picture.
xluben is offline
Old 03-22-2013, 03:39 PM   #1120
lcrazyaznl
Member#: 350014
14 Forester XT
Old 03-22-2013, 03:43 PM   #1121
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah that is the newer style blade. I don't have any of those blanks and I cannot find a source. Your only option is to modify the blade like I showed in the first few posts.
xluben is offline
Old 03-22-2013, 03:49 PM   #1122
lcrazyaznl
Member#: 350014
14 Forester XT
Okay so I would need the shell. If its exactly like the legacy it should fit in once you modify it right?
I guess I might wait and try to tackle this once i get the pieces.
Thanks for the help!
Old 03-23-2013, 08:27 AM   #1123
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The remote should fit into the flip shell just like the Legacy remote.
Getting the blade to fit will be the tricky part.
xluben is offline
Old 03-26-2013, 12:21 AM   #1124
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Made another one:
xluben is offline
Old 03-27-2013, 04:33 PM   #1125
Cmonkey0609
Member#: 349201
2013 WRX
Ice Silver Metallic
Made another one:
Great work xluben! Hopefully I get my key soon.
Cmonkey0609 is offline
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
