Old 03-17-2013, 01:41 AM   #1
dowdengc8
Member#: 193427
2012 wrx
wrb
Default can it be fixed?
So long story short, I hit something running across the street and just want to know if it could be fixed or another solution or just suck it up and buy a new one.
dowdengc8 is offline   Reply With Quote
Old 03-17-2013, 02:17 AM   #2
stevejones19
Member#: 275250
2006 WRX
Sure you can fix it, but it won't be as strong as original and may crack out depending on the quality of work. It maybe be easier just easier to save up for a new one.
stevejones19 is offline   Reply With Quote
Old 03-17-2013, 02:39 AM   #3
my name is joe
Member#: 171412
Buy a new one. Not worth to fix. Just zip tie stitch it for now.
my name is joe is offline   Reply With Quote
Old 03-17-2013, 10:01 AM   #4
I WANT AN STI
Member#: 79983
2005 STI
definitely fixable, but a whole hell of alot easier and better peace of mind to just buy a new one. Unless you have the correct material and ability and are able to save yourself a ton of money by doing it yourself., just suck it up and buy a new one.
I WANT AN STI is offline   Reply With Quote
Old 03-17-2013, 08:08 PM   #5
CBR_Steve
Member#: 327553
2005 WRX
Unless you know what you are doing, fixing it will just result in it cracking and ruining the paint job you put over it. Possible, but do your research. Fiberglass the back, glue and sand the front and paint work. Unless you have materials already, just replace
CBR_Steve is offline   Reply With Quote
Old 03-18-2013, 03:32 AM   #6
dowdengc8
Member#: 193427
2012 wrx
wrb
Thanks for the replies. I figured that it would be really difficult to fix. Guess I'll stitch it and buy a new one soon
Old 03-18-2013, 03:57 AM   #7
Imprzaboy89
Member#: 241311
95L V6WRXSTI type R
HE?RP DERP
Q Bond Plus Bondo= Win
Imprzaboy89 is offline   Reply With Quote
Old 03-18-2013, 11:07 AM   #8
stevejones19
Member#: 275250
2006 WRX
Buuuuuut, if you just look at it wrong it will crack. And if you happen to touch coming into a steep driveway or something... goodbye hard work.
Old 03-18-2013, 10:44 PM   #9
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
ziptie it till you get a new one. you dont want a piece breaking off and hitting someones car
m1r4g3 is offline   Reply With Quote
Old 03-18-2013, 10:47 PM   #10
scoobytreats
Member#: 267960
2004 WRX
buy a new one if you try to fix it you run into the risk of showing cracks and waisting you time.
scoobytreats is offline   Reply With Quote
Old 03-18-2013, 10:48 PM   #11
ABeastinWRX
Member#: 239469
2004 WRX
Just some body work. Fiberglass / bondo / paint, etc...
ABeastinWRX is offline   Reply With Quote
Old 03-24-2013, 10:44 AM   #12
thegrk86
Member#: 350920
can be easy fix....nice little weekend job. some glass wrk sanding and your set
thegrk86 is offline   Reply With Quote
Old 03-24-2013, 10:55 AM   #13
Dinoman
Member#: 309342
2004 Forester xt
Java Black Pearl
Can fiberglass and put work into it like theyve said for not much but will easily crack even with tons of work. Can ziptie stitch to keep it from getting worse until a new one is put on. because racecar.
Dinoman is offline   Reply With Quote
