Old 03-19-2013, 09:13 PM   #1
bluemicamatt
Member#: 220246
2007 WRX TR
Default Issue w/TGV Deletes. Going back to stock, help
I'm trying to put an '07 wrx back to stock that has a new engine in it. The last hurdle is how to deal w/the TGV Deletes which are in place.
Is there a way to flash in an open source tune to my stock ecu, so that I don't have to go through the hassle of finding stock TGV's, and installing them? Once I Unmarry the access port, what do I do?
I've only used an AP, have no open source experience. Any feedback is appreciated.
bluemicamatt is offline   Reply With Quote
Old 03-20-2013, 03:33 PM   #2
bluemicamatt
Member#: 220246
2007 WRX TR
nobody? Searching for a similar topic doesn't pull up much.
Sounds like I got myself into a pickle of a jam!!
Old 03-20-2013, 04:19 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
unmarry the AP, then find someone with a Tactrix or as a local tuner to flash it..
sidewayz is offline   Reply With Quote
Old 04-09-2013, 01:33 PM   #4
CarverHouseRally
Member#: 315692
2005 WRX STi
You don't need a tactrix openport to read/flash, just a vag-com cable.
1. Download ecuflash from tactrix.com
2. Read the current rom (stock) from the ecu after you unmarry the AP
3. Disable all dtc's related to tgv's using ecuflash
4. Write the new rom to the car
CarverHouseRally is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 03:19 PM.
