#1 |
Member Sales Rating: (41)
Member#: 81069
RMIC
Vehicle:1998 ej257 gm6 ewg A/R .60 Rotated |
Parting out our project, full 05 Sti/ gc8 swap with the following,
Fully built block and heads with following internals, 0 miles ACL race bearings std, new 08 Sti nitrate treated crank, wiseco pistons, Carrillo rods, supertech valves, valvesprings, retainers/keepers. Full wiring harness, gauge cluster 44k, Dash, rear seat, Cobb short shifter, Polished front and rear control arms 6 speed with rear diff an brand new act clutch and pressure plate Crawford catback, Bc coil overs, tein super streets w/edfc computer Koyo aluminum radiator gc fitment Hoosier r6 slicks 225/45z r17 Bf Goodrich g force 245/45 17 basically new Oz allegerita 17x8.5 +40 (not entirely sure about offset) Polished rear diff cover Gc coupe shell Full rs interior Sti carpet Full 05 Sti dash minus drivers airbag New 01 rS bumper Full ht autos 22b widebody 4 door kit Blousch 20g Beatrush pitchstop mount Cobb black battery tie down Kartboy exhaust hangers Kartboy shift knob Stock Sti 6spd knob Labonte Motorsports meth kit with Sti intercooler sprayer pump. Pioneer avic d3 DVD player w/Bluetooth, xm radio, iPod hook up, navi disc and built in hard drive. Plus much more. Would like to sell complete but will part out Call Ryan 801-656-7099 Or Jordan 801-209-8928
#4 |
Member#: 81069
RMIC
No the harness isn't merged or cut. I was planning on running the full harness with abs so all of the Dccd would work.
Full drivetrain with brakes and control arms $5500 with the act streetlight clutch and flywheel |
#6 |
Member#: 81069
RMIC
The car is almost completely back together. The shell is fitted for the 05 dash and we welded and painted the firewall so the 05 a/c and heater blower units were compatible, every crossmember, bracket, subframe, axle, steering rack has been cleaned, primed and painted or powdercoated on the entire underside of the vehicle, also we completely stripped down the chassis and put on a new epoxy undercoating similar to rhino lining but it's hardened and gloss black. The engine bay was completely stripped, welded, primed and painted and is completely gloss. You won't find a better done swap anywhere, we have payed meticulous attention to the finest details while building this car. You have to see it in person.
#19 |
Member#: 81069
RMIC
^^^^ if your wondering if ill part with the block the answer is yes $2700 or $4000 with the built heads.
#23 |
Member Sales Rating: (1)
Member#: 193852
RMIC
Vehicle:2004 Forester XT PSM |
-Rear diff carrier/t-brace? I'm looking for the GD Impreza solid one piece design, the forester is a crappy 2 piece design held together with floppy rubber bushings.
-Steering rack by any chance? Looking for a GD STI unit. |
