Old 03-05-2013, 11:22 AM   #1051
BlockBlockBlockBlock
Member#: 349100
2002 Blown Up Wrx
World Rally Paperweight
As a non-car enthusiast, I really appreciate the ample reading material here on behalf of OP and I'd to add "Because Racecar"
BlockBlockBlockBlock is offline   Reply With Quote
Old 03-07-2013, 02:25 AM   #1052
DoomsdayFAN
Member#: 320580
What kind of gas mileage does a heavily built or fully built STi get, ballpark? Is there an "economy" tune to switch over to when wanting to save on gas and keep her running a little slower?
DoomsdayFAN is offline   Reply With Quote
Old 03-07-2013, 02:51 AM   #1053
rexblake
Member#: 178426
2010 S4
Gray
You don't buy these cars if your worried about spending money on gas. I was getting about 16mpg on E85 with my WRX in mixed driving. Slightly higher running 91. The worse I ever got was 4mpg while canyon carving. You can switch maps to be more economical, but it's not going to be a huge improvement. The best way to save gas is to stay out of boost.
Old 03-07-2013, 09:01 PM   #1054
DoomsdayFAN
Member#: 320580
I hear you for sure, and I've already made up my mind about the STi. It's just, I'd like to know what kinda gas mileage I'm looking at with a modded engine. My first goal is to go COBB Stage 2. Hopefully that doesn't destroy the gas mileage. Then from there just do more and more stuff over time.
The STi will be my play car, but it'll also be my daily driver. So, I gotta kinda keep gas in mind a little bit.
On a DD basis though, staying out of boost wont be a problem. I'll drive like a grandma going to and from work/school/store. I mean, granted, I'll punch probably at least once a day, but I'm usually really good about that sorta thing.
Old 03-07-2013, 09:08 PM   #1055
DDScooby
Member#: 161876
02 Impreza WRX
I can't speak for a fully built STi specifically; however, I can say that a fully built WRX WITH the STi guts (minus the ECU and AVCS) gets about 25mpg MAX...flat road, highway/freeway, straight, no traffic, at sea level, and very little added weight. City...yeah...it tanks...heavy foot =15mpg; light foot =17-18mpg. (...I also have the JDM 6spd...so 5th and 6th are a bit closer, so that will affect MPG some; +/- 1-2mpg)
*That is for a 16bit ECU (02-05 WRX), with the whole STi shebang..again minus the ECU and AVCS.
DDScooby is offline   Reply With Quote
Old 03-07-2013, 09:30 PM   #1056
Member#: 349100
2002 Blown Up Wrx
Define fully built?
Old 03-07-2013, 10:23 PM   #1057
DDScooby
Member#: 161876
02 Impreza WRX
^basically nothing left of the OEM long block except the casings, otherwise completely forged/performance aftermarket internal bottom and upper halves. ...also includes air and fueling.
Old 03-07-2013, 10:31 PM   #1058
Member#: 349100
2002 Blown Up Wrx
You have given me hope.
Old 03-08-2013, 03:25 AM   #1059
tdgrim89
Member#: 349468
tdgrim89 is offline   Reply With Quote
Old 03-08-2013, 06:02 PM   #1060
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Update: 420/380 on 26psi tune. Ragging on my car pretty hard to see what pops this stock motor. No breakage yet after 12k miles daily driven. Full boost several times a day, 1/8 runs, 1/4 runs, highway pulls, thrown several codes sorting out minor issues, and driven in all conditions including crushed gravel daily.
Even hammered it for a few miles to see how high my EGT would get. Pegged to 1800F with no ill effects, usually pulls got to 1600-1700 in a second or two then flatlined. Should really drop off the spare motor to the machinist so its ready when I succeed
Old 03-09-2013, 12:07 PM   #1061
Member#: 349100
2002 Blown Up Wrx
Maybe you just have one of those magicscoobs 0.0
Old 03-19-2013, 12:05 PM   #1062
syldrin
Member#: 317652
2016 STI
I've been debating about buying an sti and i stumbled across this post and i just want to say that the man that made this post is a brilliant brilliant man.
syldrin is offline   Reply With Quote
Old 03-19-2013, 12:19 PM   #1063
Member#: 349100
2002 Blown Up Wrx
I have a 97 impreza outback. How make 400 hp?
Old 03-19-2013, 01:44 PM   #1064
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Easiest and fastest way? Sell it and buy a cammed vette, f-body, GTO, V8 truck, mustang, etc.
Old 03-19-2013, 01:54 PM   #1065
Member#: 349100
2002 Blown Up Wrx
But I want to sleep people with my 97 outback. Should I add more stickers?
Old 03-19-2013, 09:52 PM   #1066
bizarro252
Member#: 336417
2008 STi
I am not quite 400HP (390HP on Cobbs Mustang Dyno) but close enough lol
I get 14/21 and that is with 272 cams, GTX30, 91oct, full catless exh, open loop idle, P&P, ID1000's, etc.
BTW - how can I load the specs of my motor, etc into my profile so I dont have to type them out all the time
**Should note that the 14/21 was achieved on my 'econ mode' which is 310/278 for power numbers, I dont have gas mileage numbers on the higher power modes yet.
bizarro252 is offline   Reply With Quote
Old 03-21-2013, 04:02 PM   #1067
RiujinZero
Member#: 349649
My friend's 06 STI made 387whp on a dynopack and got about 17mpg mixed.
As far as the power level it was fast but it wasn't uncontrollable like some of the posts here say. Wasn't very hard to drive at all when I drove it. My 330whp Spec V was harder to drive with all the torque steer but even that wasn't that hard to drive.
Then again I've been to the strip many times and autocross my car a decent amount.
RiujinZero is offline   Reply With Quote
Old 03-21-2013, 06:47 PM   #1068
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Dave's point about the uncontrollable power is very valid. You have to understand that his point depends on the driver. A "green" driver won't have the same ability to control the pull 400awhp has. Plenty of totaled WRX and STI out there with stock power already. Now up the power, chop a couple seconds off the 1/4 times and you've got a recipe for the tree mod.
Still the same issue with experienced drivers but the driver mod is more important with more power.
Old 04-14-2013, 03:12 PM   #1069
Chrisjp011
Member#: 318114
2005 Impreza Wrx
Default good stuff
i can relate to this for the longest time ive wanted close to 400 but after spending close to 10gs on a rebuilt 2.5 forged pistons and a lot of bolt ons the cost just adds up. so what ever my car makes ill be happy.
Chrisjp011 is offline   Reply With Quote
Old 04-15-2013, 10:52 PM   #1070
Member#: 349100
2002 Blown Up Wrx
What's the car at now?
Old 04-19-2013, 09:02 AM   #1071
progonat
Member#: 353937
A 400 hp subaru engine will probably only last one week.
progonat is offline   Reply With Quote
Old 04-19-2013, 11:59 AM   #1072
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Oh you're right! Subaru must have outsourced 95% of their engines. The other 5% were reserved for jackasses who can't change oil or drive below redline.
Seriously man plenty of us pushing well over 400whp, more like 500hp at the crank. Another month gone by and no signs of this 80k mile oem longblock letting go. Still daily driven at 420/380 to the tires.
Old 04-19-2013, 05:24 PM   #1073
Member#: 349100
2002 Blown Up Wrx
Where the floam did that guy come from anyway
Old 04-19-2013, 09:49 PM   #1074
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Headuphisassylvania
Old 04-29-2013, 11:57 PM   #1075
xjpx131
Member#: 355019
Bumpvjb
xjpx131 is offline   Reply With Quote
Public service Announcement for all you white guys. obyone Off-Topic 12 06-24-2009 10:20 AM
the following Public Service Announcement is brought to you by P.A.C.T Amazake New England Impreza Club Forum -- NESIC 16 11-27-2003 09:43 PM
A public service announcement Midwayman Mid West Subaru Owners Club Forum -- MWSOC 15 02-25-2001 06:34 AM
SVX Public Service Announcement CRZ_MSL SVX Forum Archive 2 11-22-2000 11:24 AM
Public service announcement (AKA: Tony eats crow) Tony General Forum Archive 3 10-18-2000 06:12 AM
