Old 03-22-2013, 12:32 AM   #1
drstenso
Member#: 233304
1999 Legacy
Dark Red Mica Pearl
Default 99 Legacy L DJ22 stock DOHC?
I recently purchased a 99 legacy sedan 2.2L, initial research revealed it is one of the DOHC EJ22's...
I have since heard much deliberation on whether or not this motor even exists.
Short of taking off the valve covers. I called Roy Robinson Subaru of Marysville Washington and a service writer confirmed it was dohc.
However, since my initial research and his word I have yet to find any information on the all mighty interwebs to support this.
Is it some rare ej222?
I would greatly appreciate some real knowledge on this.
If it helps my vin is 4s3 bd4354 x6260226
drstenso is offline   Reply With Quote
Old 03-26-2013, 11:28 PM   #2
drstenso
Member#: 233304
1999 Legacy
Dark Red Mica Pearl
Nothing? I know there's some knowledge out there
Old 03-26-2013, 11:34 PM   #3
tibug
Member#: 273906
1831 Conestoga Wagon
My oxen all died.
I think you have a SOHC EJ22. As far as I know, there has never been a DOHC EJ22. The EJ25 that was available on the GT and Outback models of the Legacy was a DOHC.
tibug is offline   Reply With Quote
Old 03-26-2013, 11:38 PM   #4
tibug
Member#: 273906
My oxen all died.
Also, you can just look at the plastic timing cover to be certain. If it looks like this:
...it is a SOHC
You've got a DOHC...
Old 03-27-2013, 09:18 AM   #5
kiyo1990
Member#: 337674
1997 Legacy GT
Red
Glad you got your answer, hope it really is a dohc. That would be neat
kiyo1990 is offline   Reply With Quote
Old 03-27-2013, 10:20 AM   #6
drstenso
Member#: 233304
1999 Legacy
Dark Red Mica Pearl
About to got take a peak now that it's light out, I'll keep my fingers crossed. But not holding my breath.
Old 03-27-2013, 05:26 PM   #7
tibug
Member#: 273906
My oxen all died.
Ha, it would be, but the only DOHC of that year was the EJ25...I'm not too well versed in Subaru's overseas engines, but a quick google search tells me that the only EJ22 DOHC was a turbocharged model only available overseas...like I said, that's beyond my knowledge.
Old 03-28-2013, 01:33 PM   #8
BE5Legacy
Member#: 347875
2005 LGT
USDM ej22 only came sohc
BE5Legacy is offline   Reply With Quote
Old 05-13-2013, 11:46 PM   #9
beaconhillkilla
Member#: 174710
1992 Legacy SS
Someone may have just swapped heads. Although on a N/A motor I don't really see the point, but not to say it could have happened.
beaconhillkilla is offline   Reply With Quote
Old 05-13-2013, 11:47 PM   #10
beaconhillkilla
Member#: 174710
1992 Legacy SS
Also, just check on top of the block to see what is stamped on it. If it says ej22, then my vote is someone swapped the heads.
Message Board Statistics All times are GMT -4. The time now is 03:20 PM.
