03-18-2013, 11:37 PM | #1 | |
Member#: 335013
RMIC
Vehicle:2013 Premium WRX 5dr WRB |
2012+ OEM Fujitsu Ten Navigation HU to Non-Nav WRX transplant!
Replaced my original info with more detailed info from wrexed1.
03-19-2013, 12:16 AM | #2 |
Member#: 346435
SCIC
Vehicle:2013 WRX Hatchback wr blue |
Soobscribed for follow up
03-19-2013, 06:32 PM | #3 |
Member#: 334892
Vehicle:2013 WRX Satin White |
Subbed
03-19-2013, 07:07 PM | #4 |
Member#: 311622
Tri-State
Vehicle:2020 WRX Lapis Blue |
Nice!
03-19-2013, 09:05 PM | #5 |
Member#: 335013
RMIC
Updated with info about required parts. I finished connecting all the harness. Waiting for my antenna adapter & GPS antenna to come in and I'll attempt to install this. Hopefully this weekend. I'll have to wait on the USB and the bluetooth mic to see if SVXdc or I can come up with some solution. I really want USB function so that'll be what I focus on more. Hopefully I'll hear some good news from SVXdc about it soon.
03-20-2013, 12:14 AM | #6 |
Member#: 309901
BAIC
Vehicle:2012 Impreza 2.0i 5D Black |
curious you would think the 28 pin is hard to find; I got mine off a fleabay vendor. the usb cable and satellite radio antenna on the other hand I have absolutely no luck whatsoever. For GPS I used GPS Antenna for ECLIPSE AVN726E AVN5533 AVN5435 AVN30D. The common Motorola antenna adapter won't work with the F10. I had to get the adapter of a Toyota/Lexus.
03-20-2013, 01:35 AM | #7 |
Member#: 335013
RMIC
03-20-2013, 08:26 AM | #8 | |
Member#: 335013
RMIC
03-20-2013, 02:17 PM | #9 |
Member#: 345079
NWIC
Vehicle:13 Wrx sedan SWP |
What is advantage of this unit over a WRX Nav or aftermarket unit?
03-20-2013, 02:23 PM | #10 |
Member#: 335013
RMIC
This is like what's the advantage of an STi over an Evo. Just personal preferrence. I like the look of it. Plus I got it for $375 shipped so that pretty much beat most aftermarket HU as most in that price point doesn't have Navigation. For me I just like the OEM stuff.
03-20-2013, 02:50 PM | #11 |
Member#: 194216
W. Canada
Vehicle:2022 Fast POS |
While it is OEM it doesn't have an OEM fit with the bezel as the corners look funny. As long as you are happy though that's all that counts.
03-20-2013, 02:59 PM | #12 |
Member#: 335013
RMIC
Yeah you need the JDM bezel to make it less funky. But it isn't very noticable so I don't really mind. it isn't bugging me so no reason to spend $60. I am very happy with this project. Once I get USB to function it'll be much better.
03-20-2013, 10:55 PM | #13 |
Member#: 194990
Vehicle:2008 OBS Steel Silver/Spark Silver |
Wow that is a nice looking head unit..!
03-21-2013, 09:19 AM | #14 |
Member#: 107573
MAIC
Vehicle:2012 WRX hatch Ice Silver |
No, you need the Nav bezel that came stock with that HU in the first place.
03-21-2013, 12:42 PM | #15 |
Member#: 335013
RMIC
it does look pretty good. You can make it plays pictures slideshow while listening to music too.
So after a couple days of using this HU. I have to say it is a BIG improvement over the base HU. The sound is MUCH better. It will distort a bit at higher volume + High low frequencies. There's a SVC (Speed Volume Control) option that seems to make the volume a lot louder. I'll be install a pair of Infinity Kapa 63.9i in the front soon. There probably won't be much improvement but I already have the speakers. |
03-22-2013, 02:21 AM | #16 | |
Member#: 309901
BAIC
03-22-2013, 08:24 AM | #17 | |
Member#: 335013
RMIC
03-22-2013, 11:01 PM | #18 |
Member#: 335013
RMIC
My GPS antenna came in today. The plug on the antenna was a bit bigger than the socket on the HU. I did some modification to the plug on the antenna and got it to work. GPS works very good without VSS so far. No delay in turns. I might not connect the VSS cable if it works fine without it. Waiting for SVXdc to reply to me about the USB cable still. He forgot the Hirose connector. Once I have that connector I might actually connect each cable to each pin in the HU USB socket using a small quick disconnect. This is probably not the best secure option for this but I think I'll do until I or someone can find the connector to make the harness.
03-23-2013, 02:23 AM | #19 | |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
Looking good so far!
I'm glad you solved the problem with the aux input -- I was worried that I had connected a wire wrong. I'm surprised that your WRX's mic works. I need to check more thoroughly, but I had found that a WRX with the FT nav has a different part number for the map light cluster than a WRX with the CZ624U1 (non-nav HU). The only difference would be the mic module. Both nav and non-nav mics are amplified. I figured the two used different gains. I contacted a BRZ owner who is the parts manager for a Subaru dealership. He found the USB cable for the BRZ (86273CA000, MSRP $121 ). I didn't realize that it is wrapped together with a portion of the aux harness. The online price is about $89 plus shipping, which is still too much when all you want it for is the USB plug. I've asked him to check the similar USB harness in Impreza/WRX/STI with the FT nav. I know the harness is a separate piece in those cars, so I'm hoping it will be slightly cheaper. As for finding the FT USB plug as a separate piece, I don't know the manufacturer or model number for that. I'll need a Subaru or Toyota owner who has a HU with this socket to look closely at the plug on their car's USB harness. There should be a manufacturer's name or logo on it. That's how I figured out that Hirose makes the USB connectors for the non-nav cars (in the picture here, I saw the "HRS" on the plug and knew it was Hirose). I'm fairly sure that Hirose is not the manufacturer for the Toyota USB connector -- I didn't spot anything like it in their catalog. There are many other companies. Quote:
I'll let you know what the parts guy says about the Impreza USB cable. |
03-23-2013, 04:08 AM | #20 |
Member#: 335013
RMIC
Hmm that's a lot different than I imagined. I thought there was 4 pins coming out of the FT USB Socket so I was just going to use those pin quick disconnect and connect it to the hirose connector from you. I guess it does look like a USB B socket but I highly doubt that will fit in there. I believe you will be able to find something In the mean time I'll try to resist the temptation to buy the harness for $90 lol.
Also SVXdc I didn't receive the hirose plug with the package. I sent you an email about it. I can wait until you can find a proper plug to connect to that Hirose connector and send it to me all at one. Hopefully I'll hear more good news from you about this soon. |
03-23-2013, 06:42 PM | #21 |
Member#: 335013
RMIC
Got the Metra 40-LX21 adapter for the radio antenna. While HD radio is pretty cool, Utah only has a few HD channels and only a couple of them are for music.
03-24-2013, 10:56 PM | #22 |
Member#: 342730
MWSOC
Vehicle:2013 wrx limited Dark Grey |
Do you happen to know if that deck comes with a sub out put on the back? thanks!
03-25-2013, 12:40 AM | #23 |
Member#: 25837
South East
The FM601US came out of a 2012 Impreza or Crosstrek. I don't think that model (or ones from a WRX/STI or BRZ) includes a sub out. There's a small chance that one from a Forester does (but Subaru's wiring diagrams don't show it).
Pictures and pin-outs of the rear harnesses of the STI version are here (see posts 4 and 9 in that thread). The Impreza version looks the same except for the model numbers. Last edited by SVXdc; 03-25-2013 at 05:07 PM. |
03-25-2013, 10:40 AM | #24 |
Member#: 335013
RMIC
I don't know if it has sub output. Belows are some diagram I found while researching this HU. As you can see there are 2 connector not identified. Might be the sub-out but I don't know.
All credit to djz on subaruoutback forum |
03-26-2013, 01:24 PM | #25 |
Member#: 351476
Vehicle:2013 Impreza Sport Dark Grey |
where did you find the hu at? forums or a dedicated site? 375 is a good price for sure.
