Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
Old 03-17-2013, 05:38 PM   #1
CDill9
Member#: 345427
2013 WRX Hatch
Pearl White
Default Door Speaker Static?
I am getting a faint static noise from my doors speaker.
Last weekend I replaced the door speakers with JL - C2 650X Evolution 6 1/2's and didn't put the amp in. All was good besides the crappy sound from them being under powered.
This weekend I installed the amp which is a Alpine MRX V60 5-Channel (no sub yet). Now I have a faint static coming from the door speakers.
When the sound (stock base HU) is muted or powered down the static does not make it self known and it does not increase with vehicle acceleration or radio volume it is constant at one level.
For the radio pros - the question is - how do I fix it? I have found that a noise filter may work or is there any other solutions out there?
For the people who just say "this has been brought up before search it!!!" That seems to be your solution for everything. And I have searched it.
CDill9 is offline   Reply With Quote
Old 03-17-2013, 06:04 PM   #2
MongoWRX
Member#: 334892
2013 WRX
Satin White
How did you connect the wires from the head unit to the amp? I was having the same issue, I used crimp style bullet connectors to connect my wires and the wires from the HU wouldn't stay fully secure.The wires would move around in the connector and cause static. If you haven't already soldered the connectors on or made a solid connection by soldering the wires together, you may want to start there. I spent a little time on this and this is what I came up with and so far it's working. Also, you may want to try troubleshooting all of your connections just in case. Hope this helps
MongoWRX is offline   Reply With Quote
Old 03-17-2013, 08:40 PM   #3
CDill9
Member#: 345427
2013 WRX Hatch
Pearl White
I twisted the wires together and heat shrink wrapped them together.... I will play around with it.
Old 03-21-2013, 07:01 PM   #4
njandy
Member#: 350951
deffinatly try using better connections. tighter is better. try isolating the problem. disconnect the remote wire from the amp. if it still has static than it could picking up interferance from another wire. make sure they arent running right next to the power for the amp. for a good noise filter i have used a pyramid one. dont know if their still around but did the trick for me.
njandy is offline   Reply With Quote
Old 03-22-2013, 06:24 AM   #5
Toruste
Member#: 347409
buy speakers down the static does not make it self known and it does not increase with vehicle acceleration or radio volume it is constant at one level.
Hello I am looking to install new door speakers. I have never done that so can you explain the installation process?
Toruste is offline   Reply With Quote
Old 03-22-2013, 08:34 AM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
The static you are hearing is the inherient noise floor of the HU+amp.. or at least it sounds like it from here...hahaha
About the only thing you can do is use less volume on the HU and less gain on the amp..
Of course using the stock HU isnt halping you at all as its output has to go through a LOC or line output converter.. whick always adds noise ..
Get a aftermarket HU and I bet a lot of it goes away
Old 03-22-2013, 08:36 AM   #7
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You didnt crimp properly...
Old 03-22-2013, 08:37 AM   #8
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
There are plenty of install threads for you to find and look at.. search you model year and "install"
Old 03-22-2013, 10:28 AM   #9
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
With the engine off, key in accessory, do you get static?
CRAZYHAWK is online now   Reply With Quote
Old 03-22-2013, 02:00 PM   #10
Beau M
Member#: 345079
13 Wrx sedan
This. I dont want to start a war over butt crimps vs soldering, but twisted together with heat shrink is definitly not the way to go.
Beau M is offline   Reply With Quote
Old 03-22-2013, 05:10 PM   #11
MongoWRX
Member#: 334892
2013 WRX
Satin White
Yes, well not improperly, just didn't work out because I was trying to crimp two different size wires together with a common connector and the HU wiring wouldn't stay secure so I soldered it.
Old 03-23-2013, 12:50 AM   #12
stDragoon
Member#: 351075
I'm I correct in understanding that you are using the radios speaker wires to send a signal to the amp?
If that is the case, What you are experiencing is normal.
stDragoon is offline   Reply With Quote
