Old 03-20-2013, 04:51 PM   #1
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Well I went from having a two finger gap front and rear on the Forester with wrx suspension. I liked the look and how it handled. Decided to try and put a white line roll center adjustment kit on it. I still like how it handles and it did stiffen things up a bit but now I've got a two finger gap in the rear and a four finger gap in the front. I think it looks dumb so debating about taking the roll center kit off. What do you all think? Should I keep it on there or take it off. What are your experiences with these roll center kits?
2010SubieFoz is offline   Reply With Quote
Old 03-20-2013, 05:30 PM   #2
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
When I put mine on, it didn't noticeably effect ride height at all. The balljoints are only about 1cm longer than stock...how small are your fingers?
Old 03-20-2013, 05:40 PM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
roll center adjuster kit has no change on ride height. something got put back together wrong or something (unseated spring for example).
jamal is offline   Reply With Quote
Old 03-20-2013, 05:42 PM   #4
BombAtomic
Member#: 345031
2013 Wrx Hatch
How much stiffer is the ride now? Reduce roll a bunch?
BombAtomic is offline   Reply With Quote
Old 03-20-2013, 10:06 PM   #5
jdblock
Member#: 235211
2004 STi
Was this right after you put the car back on the ground? The kit will not affect ride height.
jdblock is offline   Reply With Quote
Old 03-21-2013, 09:43 AM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
the roll center kit will not affect stiffness (unless your ball joints and outer tie rods were completely dead) nor will it affect height.
Something else is wonky.
Old 03-21-2013, 10:10 AM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
What everyone said. The Roll Center Kit does not affect height. Something else is wrong.
mav1c is offline   Reply With Quote
Old 03-21-2013, 11:49 AM   #8
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Ahh, then my suspicions were correct. Something was installed incorrectly by all pro subaru.
I wear a size large glove. Sometimes a medium glove. there is definitely two finger in the rear and three to four in the front.
Old 03-21-2013, 11:50 AM   #9
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
I never did understand exactly what the roll center adjustment kit did.
Old 03-21-2013, 01:16 PM   #10
Wicked Performance
Member#: 265606
It corrects your suspension geometry and dynamic alignment when you lower the car from factory height.
Wicked Performance is offline   Reply With Quote
Old 03-21-2013, 01:22 PM   #11
teiva-boy
Member#: 22825
While this explanation is abridged. The main thing to understand is you lowered your car excessively with a WRX suspension on your Forester. While it may look cool to you, you actually worsened some natural attributes of the factory front suspension design.
The kit you installed, helps to bring things back to "normal."
There is a monster thread on the topic you can read up on.
http://forums.nasioc.com/forums/show....php?t=1604279
teiva-boy is offline   Reply With Quote
Old 03-21-2013, 01:30 PM   #12
Wicked Performance
Member#: 265606
thanks for calling it abridged and not something bad lol. i tend to over explain things and am trying to do better at summing it up
Old 03-21-2013, 01:33 PM   #13
teiva-boy
Member#: 22825
Oh no no no, holy wall 'o text is back road runner
Old 03-22-2013, 06:25 AM   #14
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Yeah,
After reading several of the 58 pages on the roll center adjustment kit I think I will eventually take it off.
Old 03-22-2013, 10:56 AM   #15
jdblock
Member#: 235211
2004 STi
You still have no idea what the kit does, do you? Or that there is no way it will change ride height, especially on the rear where the kit isn't even installed.
Old 03-22-2013, 11:49 AM   #16
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Yeah,
I understand that it does not do much. I understand that it does not change ride height.
Old 04-01-2013, 10:49 AM   #17
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Firstly is this all OEM subaru parts and do you have the alu or steel control arms?
runner19 is offline   Reply With Quote
Old 04-01-2013, 07:51 PM   #18
jmp6889928
Member#: 340677
2005 LGT 5EAT
RBP
Extra set of the hardened inserts in the LCA by mistake?
jmp6889928 is offline   Reply With Quote
Old 04-02-2013, 12:15 PM   #19
jdblock
Member#: 235211
2004 STi
It wouldn't raise the car up. It would just lower the control arm even further. I don't think its even possible to do anyways.
Old 04-02-2013, 12:46 PM   #20
teiva-boy
Member#: 22825
Yeah,
Wow really? You still don't get it, and how it benefits your overly lowered forester.
Old 04-02-2013, 02:40 PM   #21
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
How about a pic homeslice...
Old 02-21-2014, 01:11 PM   #22
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Yeah I know what it does now. I think it was the way the car was sitting as it is even all the way around on even ground. The car looked like it was sitting level but apparently the ground was not completely level.
