Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 03-21-2013, 05:07 PM   #1
promted
Member#: 282888
2002 Bugeye wagon
Rally Blue
Default I've got this leak but not sure how to go about it...
I'm not quite sure how to go about fixing this leak. I'm not quite sure which hose this is for that matter... What is this black hose (be gentle), and did it possibly start leaking because I removed the turbo heat shield after installing a down pipe? Have any of you had this happen?
[/IMG]
[/IMG]
promted is offline   Reply With Quote
Old 03-21-2013, 05:08 PM   #2
promted
Member#: 282888
2002 Bugeye wagon
Rally Blue
[IMG]<a href="http://s1254.photobucket.com/user/promted/media/leak1_zps36a6c122.jpg.html" target="_blank"><img src="http://i1254.photobucket.com/albums/hh605/promted/leak1_zps36a6c122.jpg" border="0" alt=" photo leak1_zps36a6c122.jpg"/></a>[/IMG]
[IMG]<a href="http://s1254.photobucket.com/user/promted/media/32e37d06-20c4-498d-ab7c-9a133a9f0460_zps4e8bb4e2.jpg.html" target="_blank"><img src="http://i1254.photobucket.com/albums/hh605/promted/32e37d06-20c4-498d-ab7c-9a133a9f0460_zps4e8bb4e2.jpg" border="0" alt=" photo 32e37d06-20c4-498d-ab7c-9a133a9f0460_zps4e8bb4e2.jpg"/></a>[/IMG]
Old 03-21-2013, 05:10 PM   #3
promted
Member#: 282888
2002 Bugeye wagon
Rally Blue
Where are my images...???
Old 03-21-2013, 05:10 PM   #4
promted
Member#: 282888
2002 Bugeye wagon
Rally Blue
whoops
Old 03-21-2013, 05:42 PM   #5
SCwrx85
Member#: 340328
04 WRX
I assume you're talking about the hose that is running down the firewall and looks like its melted? If so thats the drain for the evaporator core. It can't really leak as its open on one end and just drains the water from your evap core while you're running the A/C.
SCwrx85 is offline   Reply With Quote
Old 03-21-2013, 05:48 PM   #6
promted
Member#: 282888
2002 Bugeye wagon
Rally Blue
Actually no, the other black hose in the pic, the one with the 12 stamped on it, the one that follows the grey insulated hose. If you follow it down to the bottom where it connects to the right angle piece and starts heading toward the engine, that hose and connector are leaking oil.
Old 03-21-2013, 06:25 PM   #7
ScoobyNub
Member#: 269662
power steering line running to the steering rack. replace if it bothers you otherwise keep topping off the power steering fluid.
ScoobyNub is offline   Reply With Quote
Old 03-22-2013, 11:26 AM   #8
PSBeachBum
Member#: 279870
2005 WRX Wagon
Check the oil lines at the bottom of turbo. Might be disconnected and when oil hits the axle shaft it's flings all over the place.
PSBeachBum is offline   Reply With Quote
Old 03-22-2013, 01:54 PM   #9
Member#: 301037
2004 Forester XT
If it is the power steering lines you could get some aftermarket hose clamps and put on there to tighten it up.
art@grimmspeed is offline   Reply With Quote
