Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 03-15-2013, 02:28 PM   #126
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
Originally Posted by CraftyCraft View Post
Any word on how to order one of these welded up for a EWG setup? Would they weld one up for me?
Blouch will do that for you if you ask them no problem
07VTRex is offline   Reply With Quote
Old 03-15-2013, 02:31 PM   #127
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
Originally Posted by T-37 View Post
I'm very likely going with this turbo on my ej205 (along with PW TMIC, AMR inlet, and TGV deletes).
Would there be any benefit to doing the 3" inlet compressor housing for $50 more? Does it do anything more than complicate installation?
This is based off no data at all just talking out my ass but I highly doubt this turbo flows enough air to warrant a 3" inlet. If you did do it you'd have to get a 3" turbo inlet. And changing those sucks balls.
Old 03-15-2013, 02:57 PM   #128
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
That was my thought too, I read about people having to cut up the TGV housing and that doesn't sound very appealing. The AMR comes with a 3" and a 2.4" silicone coupling, so either way would work.
Old 03-22-2013, 04:21 PM   #129
Masters84
Member#: 319235
2005 WRX Blouch 18g
just bought my Blouch 16g XT ported for my 05 Wrx cant wait ive read so many good things about this turbo. i will post the results in a few weeks and let everyone know how everything turns out.
Masters84 is offline   Reply With Quote
Old 03-23-2013, 03:09 AM   #130
yo!
Member#: 249478
2004 Impreza WRX STI
black
I had the 16gxt on my STI running deatschwerks 740cc yellows, turboxs top, turboxs rfl exhaust and perrin inlet. Only had one run and managed 12.3 in the 1/4 at 112mph. 1.7 60 foot spinning and stepping 5 foot to the left.
https://www.youtube.com/watch?v=AWB2VfXO6ZE
Hvae a 20g tomioka right now on 850cc injectors. need a new clutch to run on a dyno. I love the Blouch turbo though and e85 is it's crack. can't wait for new numbers.
yo! is offline   Reply With Quote
Old 04-11-2013, 02:54 AM   #131
JDM WRX
Member#: 222191
02 WRX
so is it safe to run a set up like this on a car with high millage ?
i am debating doing the same thing but a little bit scared because my car has 230,000KM on it. I dont wanna blow the thing up after a couple of months of having a set up like this.
PS i am already running a VF39 setup on a 02 wrx
JDM WRX is offline   Reply With Quote
Old 04-11-2013, 03:39 AM   #132
Green_Guy
Member#: 325889
if you're nervous about an upgrade i'd hold off until you have a spare block/cash money around.
Green_Guy is offline   Reply With Quote
Old 04-11-2013, 01:18 PM   #133
CraftyCraft
Member#: 340451
2008 Corvette Z06
Atomic Orange
I agree with Green_Guy. I have 140k miles on mine and I plan on slowly building a block by the end of next year and get a 250cc bike (alternative transportation). With proper cooling and oil, it should be fine for a while. Plus, I have decided to go with the STi pan and Killer B oil baffle+pickup. Oh, and E85 for the slightly cooler running temps and performance.
CraftyCraft is offline   Reply With Quote
Old 04-15-2013, 09:04 AM   #134
Masters84
Member#: 319235
2005 WRX Blouch 18g
Originally Posted by Unabomber View Post
Facility: TurboXS, tuning by Jermaine
Type of Dyno: Dynapak
Baseline # for a stocker at the dyno: stock 02-05 WRX is ~170 HP/~170 TQ
Boost: 24 PSI
Fuel: 93 octane
Mods:
2004 WRX with 150,000 miles on it
Blouch 16 XTR prototype
Perrin Pulley
TurboXS Stealthback no cat version
Massiv USA catback
Killer B equal length header + v-band uppipe
CSS Performance FMIC
TGV deletes
Walbro fuel pump
APS turbo inlet
Deatschwerks 650cc injectors
Cobb AccessPORT ver 2
TurboXS big MAF intake
Grimmspeed BCS
333 HP and 322 TQ
About the turbo:
It is a prototype Blouch 16G XTR. It has a billet 16G wheel, Blouch housings, and a Garrett ball bearing center cartridge. It is not available yet and is still in testing and final development. If you jam the lines and email Blouch about it, it might speed up the process or honk them off, one of the two! Wheel size is 37 lb/min.
Mine came ported, not sure if the full retail will or if it is extra.
Read deal Garrett center.
BPT 8 is cast and I'm 98.5% sure this means it is an 8cm hotside.
Driving impression is that I am now a huge fan of a ball bearing center cartridge. Throttle response is lightning. Just taking the tension out of the gas pedal generates 5 PSI. If a responsive turbo is your forte, this one is for you. While the graph makes it seem a touch on the laggy side, this is far from the truth as on the road my car is now a holy terror. 0-60 is crazy and 60-100 is down right nuts. My previous turbo was a Deadbolt Super16G which was no slouch putting out 290HP on a Dynojet. The new turbo kills it everywhere, especially down low. Jermaine also made me a more conservative 20 PSI map (as yet not used) considering my car is getting up there in the miles at 150,000.
When Jermaine was tuning he remarked normal 16Gs make 280HP on his Dynapak. This one is +50HP over that. When I reminded him that this WAS a 16G, he got all bugeyed and made me laugh. After road tuning when we were done, he flipped me the keys and smiled like a Cheshire cat and said I'd like it and he was right! It's really awesome when someone like Jermaine is happy with the results. Fuel according to the logs was low 90s for IDCs with a couple values at 96, so this pretty much maxes out 650s on 93 octane.
Props:
Mike at Blouch Turbo in Lebanon, PA for letting me test this.
Andrew at Andrewtech Automotive in Gaithersburg MD for install help and letting me sleep on his couch.
Jermaine at Turbo XS in Gaithersburg, MD for tuning the crap out of my car.
Justin at Grimmspeed in Minneapolis, MN for my BCS.
Trey at Cobb Tuning in Austin, TX for AccessPORT ver. 2.
Mike at Deatschwerks in Oklahoma City, OK for the injectors.
Chris at Killer B in Waynesboro, VA for my new headers and uppipe.
Is this whp?
Old 04-15-2013, 10:35 AM   #135
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
Yes, whp. Great turbo, can't wait on mine!
T_Racer69 is offline   Reply With Quote
Old 08-15-2013, 08:40 PM   #136
ajarena95
Member#: 306633
Does this put up bigger numbers than the 16gxt on the 2.0? i just read the entire thread but didnt see a comparison of the two and cant seem to find one anywhere
ajarena95 is offline   Reply With Quote
Old 08-18-2013, 04:40 PM   #137
point78
Member#: 344329
2008 Wrx, 6mt
Blouch advertises the 16gxt as 41lb/min & the xt-r as a 38lb/min.
The xt should make about 30hp more, using blouch's numbers.
point78 is offline   Reply With Quote
Old 09-30-2013, 06:24 PM   #138
SnowKing
Member#: 282260
2002 WRX Sedan
anyone know where I can get a good deal on this kick *** turbo!?
SnowKing is offline   Reply With Quote
Old 09-30-2013, 09:41 PM   #139
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
I got a pretty good deal on mine from Motion Lab, but I think they were running a sale at the time...
Old 10-01-2013, 01:48 PM   #140
SnowKing
Member#: 282260
2002 WRX Sedan
How much did you drop on it?
Old 10-01-2013, 02:25 PM   #141
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Significantly less than msrp. I suggest PM'ing a few NASIOC vendors who are Blouch dealers.
Old 10-02-2013, 12:36 AM   #142
SnowKing
Member#: 282260
2002 WRX Sedan
I mean could you give me an estimate, so I know it is even worth my time without seeming like an ***hole. I am on some a sort of budget... Thanks
Old 10-02-2013, 12:51 AM   #143
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
In the time you spent asking me about the price I paid - several months ago - that may or may not be honored today, you could have PM'ed a few vendors and gotten an actual quote. I'm not selling you a turbo, so how much I paid doesn't mean dick.
For what little it's worth, I think I saved somewhere between $100 and $200....but it's been quite a while.
Old 04-09-2015, 03:30 AM   #144
OneManArmy
Member#: 36154
2004 WRX Wagon
Hey Ron... trade me the 16g xtr for my 18g xt
OneManArmy is offline   Reply With Quote
Old 04-28-2015, 08:23 PM   #145
point78
Member#: 344329
2008 Wrx, 6mt
I was out messing with my tune this morning, here's my 16g xt-r 8cm, on a 08 wrx, pw tmic, 91 pump, 18.5 psi, 2004 6mt.
THIS IS AT 10,000'.
2 pulls each in 3rd and 4th, thats the spool difference, (dunno how accurate the torque and hp plots are?) I made 315/303 on the same dyno as below on 91 pump.
here was my e85 tune down at 5500' and 24 psi. This particular dyno spools everything late, so just shift that torque curve over to the left, and up a bit
I'll try to get a plot of its spool next time I'm down in denver to show the difference the altitude makes.
Old 05-02-2015, 06:08 PM   #146
rumblewrx13
Member#: 420209
2013 WRX
THIS IS AT 10,000'.
Nice setup! What made you choose this turbo over a vf52?
rumblewrx13 is offline   Reply With Quote
Old 05-02-2015, 07:35 PM   #147
point78
Member#: 344329
2008 Wrx, 6mt
I couldn't find a good vf52 when I was ready to swap it out, otherwise I would have. (I also think the BB center section will hold up better at 24psi)
I figured I'd try this one out, I also still had the 5mt then and didn't want to have to worry about it.
Old 05-03-2015, 10:24 AM   #148
mopar3.0
Member#: 261696
2004 wrx
red
i have the 18gxrt version, very nice unit, but too small for my 2.1 with cams . boost tapers off to 19 psi
mopar3.0 is offline   Reply With Quote
Old 05-03-2015, 02:44 PM   #149
point78
Member#: 344329
2008 Wrx, 6mt
The 16g is to small for the 2.5 down in denver, but up where I live it's pretty good.
There's a hill by my house that I'm typically hitting like 5-8psi just going up it in second gear. I dunno if a bigger turbo would be able to do, or if it moving more air would make up for it. But it is tempting to put something 20g sized on it & see how it does at altitude.
I'd hate to lose all my first & second gear boost threshold-it's to much fun driving sideways & hooning around after it snows in the ski resort parking lots, currently second gear is perfect for going fairly slow, but still being able to slide all over the place at about 3-5k rpm.
Old 05-07-2015, 10:44 AM   #150
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Crazy results off this little turbo. Would make a street weapon on E85!
CEEBEE is offline   Reply With Quote
FS : LA/Socal: New Blouch Evo III Big 16G, supporting mods, Greddy Ti-C Sokana SCIC Private Classifieds 9 04-09-2012 07:29 AM
*Help* I need help choosing the better 16g..TD05 Big 16g or FP 16g or EvoIII 16g? min88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-04-2009 01:38 AM
FS: Blouch Big Evo III 16G, Deatschwerks, TIAL44 EWG, Process West TMIC, Walbro specialev NWIC Private Classifieds 9 06-04-2009 04:54 AM
FS in WA: Blouch Big Evo III 16G, Deatschwerks, TIAL44 EWG, Process West TMIC,Walbro specialev Engine/Power/Exhaust 19 06-04-2009 04:54 AM
FS: Blouch Evo III Big 16g (Pics) Boxer4u Engine/Power/Exhaust 17 10-15-2007 11:53 PM
