Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 05-14-2010, 10:40 PM   #1
JLW2007RS
Member#: 162089
2008 G37S IPL
Default Cost of replacing all vacuum lines?
Is there a kit i can buy for this or is it recommended to just buy bulk line, cut and replace.
I just feel like i should replace all lines to eliminate vacuum line issues and rule out the lines as future problems. I dont really get the carb cleaner spray and pray procedure.
JLW2007RS is offline   Reply With Quote
Old 05-15-2010, 12:02 AM   #2
OrbitalEllipses
Member#: 178811
2013 WRB BRZ Limited
For Sale!
I was actually thinking about doing this too. I was considering silicone lines though. I was planning on buying bulk (at least +1 foot extra) and cutting to fit.
Old 05-15-2010, 03:34 AM   #3
oguitar
Member#: 206720
2002 WRX Wagon
Problem is the tubes are different diameter and some have complicated bends. If you guys do it write a DIY for the community.
oguitar is offline   Reply With Quote
Old 05-15-2010, 08:23 AM   #4
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
as long as the hoses are the right diameter and are good quality I can't see why it wouldn't work fine.
jdmboy is offline   Reply With Quote
Old 05-15-2010, 10:44 AM   #5
SHARP_DAL
Member#: 183247
2005 WRX
Some hoses you really need the oem bend. A straight hose may not work as some bends are 90 degrees. It can be done with straight autozone vacuum hoses, but it is not optimal as you risk completely cutting of air flow
SHARP_DAL is offline   Reply With Quote
Old 05-15-2010, 05:06 PM   #6
JLW2007RS
Member#: 162089
2008 G37S IPL
thank you for all of the responses, so the general consensus is that i can replac most with bulk, and the obvious bendy's I should OEM or test with air pressure
Old 05-15-2010, 11:14 PM   #7
cash1220
Member#: 156342
you can use bulk hose from autozone to replace all of your vacuum hoses. as long as the hose diamter is similar and the fittings & restrictor pill are the same size you will have the same functionality as the oem. that being said, i dont see why anybody would ever need to change their vacuum hoses unless they are switching to a 3-port solenoid and/or ewg setup.
cash1220 is offline   Reply With Quote
Old 05-16-2010, 12:36 AM   #8
OrbitalEllipses
Member#: 178811
For Sale!
Old hoses :-\
That's why there's the ancillary hose kits. Why not do the same for your vacuum lines? Old rotten hard rubber sucks, sexy smooth silicone doesn't!
Old 05-16-2010, 09:43 AM   #9
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
there are kits on ebay. i found one that was even wrx-specific.
i have no idea how good or bad they are.
http://cgi.ebay.com/ebaymotors/Silic...Q5fAccessories
ronaldwrx is offline   Reply With Quote
Old 05-16-2010, 10:03 AM   #10
JLW2007RS
Member#: 162089
2008 G37S IPL
Yes! that is what i was looking for, i will have to look into the quality however, looks good thank you!
Old 05-17-2010, 01:51 PM   #11
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
i just remembered this company as well .. somewhat reputable, been around a long time .. sells WRX specific kits ..
http://www.hosetechniques.com/silico...-subaru-c-2_47
Old 05-17-2010, 02:14 PM   #12
WhyHelloOfficer
Member#: 193989
2004 Matte White GTO
Australian Racecar
Simply google "WRX Ancillary Hose Kit" and you will find a silicone hose kit that will replace some of the main hoses under the hood. If your car is higher mileage, I would definitely suggest replacing the vacuum lines that connect your boost control solenoid, wastegate and turbo.
When I replaced my boost control solenoid on my 35,000 mile '05 for a 3-port, nearly all of the vacuum lines cracked/fell apart in my hands.
WhyHelloOfficer is offline   Reply With Quote
Old 05-17-2010, 04:58 PM   #13
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
i dont think the ancillary hose kit does most of the vacuum lines.
when i did the 7 piece samco on my 02 there were still a lot of hoses left behind.. and that kit didn't fit all that well either.. maybe its gotten better.
Old 05-17-2010, 05:22 PM   #14
dem1k
Member#: 146186
2002 wrx
psm
Ancillary hose kit doesn't cover much at all
dem1k is offline   Reply With Quote
Old 05-18-2010, 12:36 AM   #15
OrbitalEllipses
Member#: 178811
For Sale!
The hose techniques kit plus an ancillary hose kit should cover MOST the engine.
Old 05-18-2010, 01:36 PM   #16
JLW2007RS
Member#: 162089
2008 G37S IPL
WIll look into this next, thank you
Old 05-18-2010, 04:43 PM   #17
suby newby
Member#: 215905
2002 Impreza WRX
Try this place http://www.siliconeintakes.com/index...1506ac976db72a. I bought about 10' of silicone vacuum line to redo a different car and it works great. It's really pliable and bends very easily, even more so than the rubber 1/8" vacuum line you can get at a parts store if you're lucky enough to find it.
suby newby is offline   Reply With Quote
Old 05-18-2010, 04:46 PM   #18
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
look into samco or mishismoto kits.
Kenji815 is offline   Reply With Quote
Old 03-22-2013, 02:43 PM   #19
3dbello
Member#: 318602
2003 WRX Wagon
I've changed all my hoses to this kit here.
http://www.ebay.com/itm/Mishimoto-Si...item35bed8c282
It's great, easy to install, I also suggest going to the store and just buying new clips to go along with it as well. Personally I replaced all the pinch style clips with the screw on ones.
3dbello is offline   Reply With Quote
Old 03-22-2013, 03:05 PM   #20
greenplates
Member#: 239162
You need vacuum lines feeding wastegate, boost control solenoid, and "pill"
greenplates is offline   Reply With Quote
Old 03-22-2013, 03:41 PM   #21
DZXN
Member#: 306186
2002 Subaru WRX
You might want to look into what worm drive (screw on) clamps do to silicone hoses 3dbello. And nice bump on a 3 year thread.
DZXN is offline   Reply With Quote
WTB: All vacuum lines from an 02-05 WRX mikebdubsuby SCIC Private Classifieds 2 12-10-2009 12:54 PM
WTB: All vacuum lines for an 02-05 WRX mikebdubsuby Private 'Wanted' Classifieds 0 12-10-2009 12:19 PM
Cost of replacement A-pillar cover...and guage pod paint?? Kwyjibo Interior & Exterior Modification 4 12-10-2002 01:52 PM
all vacuum lines from one point very bad?? jdchmiel Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-05-2001 08:31 PM
Pics of AVC-r Vacuum lines. Keith Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-18-2001 09:03 PM
