Old 03-19-2013, 09:52 AM   #1
1akazeus
Member#: 342468
2002 wrx
Default smell burning oil sometimes at idle
Hi guys need some help I have a burning oil smell come thru my vents at some times at idle but I dont see oil on the ground or on the motor please help
1akazeus is offline   Reply With Quote
Old 03-19-2013, 10:11 AM   #2
jam007
Member#: 174706
2008 LGT-B
You may want to check your valve cover gaskets underneath.
jam007 is offline   Reply With Quote
Old 03-19-2013, 11:35 AM   #3
1akazeus
Member#: 342468
2002 wrx
I did and I dont see anything at all O-o im lost right now
Old 03-19-2013, 12:57 PM   #4
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
There are also oil lines that go to and from your turbo.
2gnt2wrx is offline   Reply With Quote
Old 03-19-2013, 01:21 PM   #5
1akazeus
Member#: 342468
2002 wrx
Ok ill check out today ill let you guys know thanks
Old 03-19-2013, 02:29 PM   #6
1akazeus
Member#: 342468
2002 wrx
Found some oil on the back of the turbo is that bad ? Is my turbo going bad ? Or is it the head gasket ? Please help im new to the subbie world
Old 03-19-2013, 02:35 PM   #7
Member#: 301037
2004 Forester XT
Pull the down pipe and see if it has oil in it as well as checking the turbo shaft for shaft play
art@grimmspeed is offline   Reply With Quote
Old 03-19-2013, 02:44 PM   #8
1akazeus
Member#: 342468
2002 wrx
If I can have oil in the down pipe and no play in the turbo what does that mean?
Old 03-20-2013, 02:41 PM   #9
rick-l
Member#: 33868
2003 wrx
srp
Do you have the two piece metal coolant tank over the turbo? Check the sides of it and see if you see dried coolant.
The burning coolant on the turbo on mine did not smell like I thought burning coolant should.
rick-l is offline   Reply With Quote
Old 03-20-2013, 03:33 PM   #10
Member#: 301037
2004 Forester XT
Chances are if you have oil in the down pipe then you have shaft play in the turbo!
Old 03-20-2013, 09:35 PM   #11
1akazeus
Member#: 342468
2002 wrx
Thank you but someone told that there is a oil seal or gasket where the oil filter goes and im not talking about the one for the oil filter is that true ?
Old 03-20-2013, 09:36 PM   #12
1akazeus
Member#: 342468
2002 wrx
Im getting oil change on Friday and look at where the oil leaks from
Old 03-22-2013, 03:25 PM   #13
1akazeus
Member#: 342468
2002 wrx
Hi guys just found out that its leaking from the back of the turbo but leaks very very little oil now can I change the seals in the turbo ? Buy it used turbo? Or new
Old 03-22-2013, 03:34 PM   #14
DZXN
Member#: 306186
2002 Subaru WRX
Back of turbo as in inside the exhaust or underside of the turbo? If it is leaking inside you could have it rebuilt, buy a used td04 from the classifieds, or buy a new one from subaru or an aftermarket one. If you buy anything other than a td04 you are going to need supporting mods and a tune. If it is leaking under the turbo its a different story. Replacing your oil return line, cheap but not fun.
DZXN is offline   Reply With Quote
Old 03-22-2013, 03:39 PM   #15
1akazeus
Member#: 342468
2002 wrx
dribble fall's on downpipe on the outside no oil on the inside the exhaust
Old 03-22-2013, 03:49 PM   #16
DZXN
Member#: 306186
2002 Subaru WRX
So the oil is on the outside? Is it coming from the oil feed line or return line? Could be the connection at the turbo for the feed (new crush washers), oil return line (1' of oil resistant high temperature hose, $4.80 is what I paid this morning), or the connection between the hotside and compressor cover of the turbo (i have no idea if you can reclamp or if you would want to buy something else). Figure out where it's leaking from and go from there.
Old 03-22-2013, 04:10 PM   #17
1akazeus
Member#: 342468
2002 wrx
Thanks dzxn for your help i will look into that
Old 03-22-2013, 08:18 PM   #18
1akazeus
Member#: 342468
2002 wrx
Just found were its leaks from its leaking very little oil from the return oil line from the turbo to the block does anyone know someone in lower westchester ny who works on wrx's and for a fair price . Please let me know thanks
Old 04-04-2013, 01:09 PM   #19
2002scoobybugeye
Member#: 221815
2002 2002 WRX Wagon
2000 Forester L
Had this exact same issue! My oil pan where the dip stick comes in had corroded and a very small amount of oil seeped thru the metal then would drip down till air hit it and blow onto my exhaust. Only smelled it at idle due to the air not pushing the smell by me any longer, and no more oil blowing onto the exhaust. Glad you found the issue but just figured I would chime in to help others if it wasn't what was already suggested. Which was a huge help by the way for places to look, Thanx! Oil pan was 50$ on ebay with free shipping.
2002scoobybugeye is offline   Reply With Quote
Old 04-04-2013, 04:48 PM   #20
danger1138
Member#: 279525
04 rex luger!
Yes i know someone who can help u with and charges very fair price believe me... Hes in queens tho.. Lmk
danger1138 is offline   Reply With Quote
Old 04-06-2013, 08:20 PM   #21
greenplates
Member#: 239162
Common things to think about:
-valve cover gaskets
-turbo oil feed/return line
-turbo seal
greenplates is offline   Reply With Quote
