Old 02-07-2013, 06:29 AM   #176
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
both you and bmw325 are my hero's...
who cares if the power drops off ... squeeze the crap out of that little turbo and see what you can do with it!
All4bSpinnin is offline   Reply With Quote
Old 02-08-2013, 03:39 PM   #177
bmw325ix
Member#: 204652
Thank you, I've upgraded to a larger turbo and what not since but still think stock sti turbo and a good ewg setup is the best for a street car.
bmw325ix is offline   Reply With Quote
Old 02-09-2013, 01:57 AM   #178
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
Before I did my build I was running 370awhp / 410awtq on completely stock longblock, 20psi and e-85. Only real mods I had where 850cc inj., Wally 255, FMIC, and AEM v2.
...CHUCKLES... is offline   Reply With Quote
Old 02-18-2013, 04:30 PM   #179
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
^ Did you ever go to the track?
Excision is offline   Reply With Quote
Old 02-19-2013, 10:10 AM   #180
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
Drag strip 1/4 was 12.1xxish (it's been a while) also the only 1/4 track in so-cal closed to the public.
AAA speedway roval not sure on time but hit 150ish on the oval (also been a while)
Streets of willow ccw 140ish on front straight just before the brake box.
Also looking forward to a Texas mile run in the near future.
Old 03-23-2013, 10:02 PM   #181
TIGWERKS
Member#: 256615
almost ready to fire it up.
TIGWERKS is offline   Reply With Quote
Old 03-24-2013, 01:57 PM   #182
MrSlowbaru
Member#: 129231
2005 wrx
cgm
I would use rubber bushings where you mounted the ic to the rad support. Even if you have solid motor mounts eventually the vibration will tear those free.
MrSlowbaru is offline   Reply With Quote
Old 03-24-2013, 03:34 PM   #183
TIGWERKS
Member#: 256615
What does motor mounts have to do with the intercooler? That's not the only place it's mounted as well.
Old 03-24-2013, 05:39 PM   #184
MrSlowbaru
Member#: 129231
2005 wrx
cgm
Because of the clamps that you have used, the ic is now solidly connected to the turbo and throttle body. So when the motor moves, the pipes move, and if the ic has no play to move, it will find a way to move.
Old 03-24-2013, 06:33 PM   #185
TIGWERKS
Member#: 256615
Those clamps aren't solid, They have plenty of movement.
Old 03-24-2013, 08:48 PM   #186
MrSlowbaru
Member#: 129231
2005 wrx
cgm
Oh, I thought they were solid, similar to v bands.
Old 03-25-2013, 11:10 AM   #187
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
Looks beautiful! Anymore inconel pics?! I can't wait to try my hand at welding that.
bugeyesubie is offline   Reply With Quote
Old 03-25-2013, 03:00 PM   #188
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
djelly84 is offline   Reply With Quote
Old 03-25-2013, 03:34 PM   #189
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
thats gnarly ^ is your car rwd?
olsen726 is offline   Reply With Quote
Old 03-25-2013, 03:35 PM   #190
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
just saw the build link
Old 03-25-2013, 06:11 PM   #191
207STi
Member#: 197062
1998 Swapped Impreza
black
Not nearly as nice as most of t builds in this thread, but I am still very proud of the fruits of my labor.
Let me know what you guys think!
Old 03-27-2013, 03:07 AM   #192
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Looks good.man, I feel the same way about my setup
Old 03-27-2013, 10:34 PM   #193
spiltheflagon
Member#: 107161
06 WRX&⅓STi+
Are you going to run an AOS or Breather Can. Anxious to see your setup with the welded AN-12 on the intake.
I just ordered a TIGWERKS oil drain fitting. I can't wait to start welding everything up!
-Justin
spiltheflagon is offline   Reply With Quote
Old 03-28-2013, 01:04 PM   #194
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Started life as a Perrin 3076 kit and ended up like this years later.
Trey
treystoys is offline   Reply With Quote
Old 03-28-2013, 01:54 PM   #195
TIGWERKS
Member#: 256615
-Justin
I'm going to make up an AOS setup with a -12 on top which will route to the intake. I'm moving to Texas this weekend and the car will be left behind here in California since its not 100% and its too stressful trying to bring everything with me in one go. I've been making a slight effort trying to sell it before I leave because once I leave I probably won't want to come back and get it. It's been sitting for so long I don't have much attachment to it anymore.
Old 03-29-2013, 08:01 PM   #196
jdblock
Member#: 235211
2004 STi
Just have the car shipped to Texas.
jdblock is offline   Reply With Quote
Old 03-30-2013, 09:14 PM   #197
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Just about done with my setup, Tigwerks rotated kit along with my own IC pipes and perrin FMIC.
ec2k1gt is offline   Reply With Quote
Old 03-30-2013, 09:44 PM   #198
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
^ Excellente !!!!
M4c0770 is offline   Reply With Quote
Old 05-01-2013, 07:57 PM   #199
Bansheeboy11
Member#: 182415
1999 RS
Just started working on my twinscroll motor. Has anyone done a rotated manifold and kept the A/C? Its pretty tight quarters for the throttle body to the alternator, id imagine itd be the same on the hood. I know ECS built a car that was rotated with AC but i dont recall how they ran the pipe over the alt...
Anyways...
Bansheeboy11 is offline   Reply With Quote
Old 05-11-2013, 09:30 PM   #200
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
First, sorry for the crappy cell phone pics. But wanted to ask you guys of what you think of this heat shield. Is it bad to cover up the center cartridge of the air cooled precision turbo? Should i had a heat chimney?:
Bad Noodle is offline   Reply With Quote
Piece of Perrin rotated kit 06rexwagon Private 'Wanted' Classifieds 12 06-24-2010 11:06 AM
Pictures of custom installs/boxes? Gman094 Car Audio, Video & Security 42 04-17-2004 12:43 AM
Post picture of custom grilles!!! WRXVII Member's Car Gallery 0 08-23-2002 12:20 AM
Can someone post a picture of custom designed front grille? WRXVII Member's Car Gallery 0 08-19-2002 01:34 PM
