Old 12-03-2012, 12:27 AM   #326
papasmurf180
Member#: 322150
Anybody have write up on how to do a 2011 sti TMIC install on a bugeye?!?! Would be greatly appreciated
papasmurf180 is offline   Reply With Quote
Old 01-14-2013, 06:05 PM   #327
I Love Sparklies
Member#: 334475
1999 Impreza
Rally blue pearl
I have a 05 wrx and I'm trying to get a sti tmic on it. What parts can I reuse on my wrx intercooler to my sti intercooler? And what parts would I need to buy to make the sti intercooler fit?
I Love Sparklies is offline   Reply With Quote
Old 01-21-2013, 10:53 PM   #328
geedar
Member#: 224617
03 WRX
6-sp. vf39
I just installed n '05 USDM top-mount on my 03 WRX with a USDM VF-39. I followed the OP's instructions and it worked for me. There seems to be no difference between the USDM TD04 and VF-39 as far as installing the USD STI TMIC. I had to bend my AC line toward the firewall and it will mount on both brackets. I used the stock USDM STI Y-pipe (MY04) and only needed the two custom hoses to install.
2.75in ID at 3" in length
2" ID 90 deg. elbow at 4in. + 4in. in length (four inches on each side from the center) "slightly trimmed"
I located some radiator hose in these same dementions and it worked to some degree to get my car mobile but I later read that radiator hose stretches under boost which wastes energy and creates a lag-then-surge kind of effect. I now ordered the hoses in silicon like I should have in the first place.
I wanted black dull hoses for an OEM look but unfortunately silicon = shiney . Here in CA, cops can give you a $500 ticket for "modified emissions system" (I know, because it happened to me for an intake). Something to consider if you live in CA. A red or blue hose (even a shiny black hose) can cost you a lot of money and trouble.
geedar is offline   Reply With Quote
Old 01-27-2013, 04:58 PM   #329
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
That's crazy. Cops can ticket you for having a modified intake system? What if it has an emission sticker like K&N SRI?
Old 01-29-2013, 12:18 AM   #330
tobigforhisshoes
Member#: 251434
04 WRX
WRB 319/285 bobby tuned!
Holy law book Batman.
tobigforhisshoes is offline   Reply With Quote
Old 03-22-2013, 01:12 PM   #331
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
so in order to have a USDM 04-07 STi Top mount fit onto a 03 wrx w/ 16g =
http://www.siliconeintakes.com/produ...01078ee9aee664 ??
+jdm splitter + jdm scoop
kevin85193 is offline   Reply With Quote
Old 03-23-2013, 10:31 PM   #332
Rally Red Bugeye
Member#: 275808
2002 Wrx
Rallie Red
I need a write up on a 2008 and up sti tmic on bugeye?
Rally Red Bugeye is offline   Reply With Quote
Old 03-23-2013, 11:16 PM   #333
DZXN
Member#: 306186
2002 Subaru WRX
There is a link or two in the TMIC section of the manifesto about 08+ Sti I/C on 02-07. If you are going to run it with the td04 you will run into a problem with the wg actuator. If running with a vf you will only need to do some minor mounting mods.
DZXN is offline   Reply With Quote
Old 11-13-2013, 10:41 PM   #334
Bots10
Member#: 364467
2015 WRX
ISM
So people looking to do this, I am in the process of doing this on my 2004 Wrx. I thought it was going to be as simple as buying the tmic from my buddy and slapping it on, well its not.
Heres how much I am in to it already:
2005 STI TMIC with ypipe: $120
HPS 4-ply 2" (51mm) 90 Degree Elbow Coupler Silicone Hose: $31.92
HPS 4-Ply Reinforced 2 3/4" (70mm) Straight Silicone Hose: $10.62
STi Hood Scoop Air Splitter 2004-2005 (90817FE200): $87.27
STi Hood Scoop - 2004-2005 Model (90821FE080NN): $118.91
STi Scoop Duct / Bellows 2004-2005 (90817FE210): $37.34
NAPA 01G Aerosol Color Match Paint 1 Stage: $25.99
Shipping: $103.52
Shipping: $38.72
(My shipping is so high because I am getting a pro tune this saturday and needed everything before then)
__________________
Grand Total: $574.29
Just to be able to run a STI TMIC, (THE CORRECT WAY)
Bots10 is offline   Reply With Quote
Old 11-13-2013, 11:26 PM   #335
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Well, you could get a y-pipe kit from ebay for around $40. I have one on my car with an 04-07 STI TMIC hooked up to a VF23.
The bellows and TMIC splitter cost me $75 shipped, good deals on them here on the forums can be found every so often.
ShinjiML is offline   Reply With Quote
Old 11-13-2013, 11:43 PM   #336
H_wells3000
Member#: 322035
2003 4.44E85=1MPG
Ol yeller
^ this is part of the reason why I just went fmic. Everyone always says fmics are so expensive and pricey when compared to tmic.
Tmic costs add up. Scoop, splitter, heatwrap/turbo blanket(optional) plus the cost of the tmic itself, from what I've seen , when it adds up just isn't cost effective.
Used name brand fmic setups are going for +- 500 bucks. I got my txs for a record steal of $380 bucks, granted I had to repaint the piping but still.
But hey more power to you, not everybody runs it properly. I know I didn't when I had my sti tmic!
H_wells3000 is offline   Reply With Quote
Old 11-14-2013, 07:07 AM   #337
Bots10
Member#: 364467
2015 WRX
ISM
Yea man, I was looking at FMIC but its more attention I dont want. At least now I will have the STI scoop and in the future I will be able to go with a nice big TMIC for an sti and already have the all the parts there for it. So yea the upfront cost was high but at least I know it will be done run and functional.
Old 11-14-2013, 04:55 PM   #338
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
More attention plus horrible look if bumper is not cut properly.
Old 11-14-2013, 08:17 PM   #339
H_wells3000
Member#: 322035
2003 4.44E85=1MPG
Ol yeller
Couldof been alot worse, you got the tmic for a steal! So props for that. The numbers begin to not make sense when somebody buys a $300 one. And yeah I wish I could rock the sti scoop! IMO it looks fantastic. But I have a bugeye :/ just looks strange with one.
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
