Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 01-21-2009, 12:49 PM   #1
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Default Fuel pump going bad?
Just starting from yesterday, every time I started my car I hear this high pitch whining noise coming from the ear of the car. It is pretty quiet inside but if you go to where the gas door is it is pretty loud there and its coming from the bottom of the car. I assume it is my fuel pump start to go out but just wanted to make sure.
The noise will last about 10 second or so and it will stop completely.
It will only happen again the next time I started my car, and again, and again...
I have a Walbro 255 installed about 3 years ago. Car is currently running at custom tuned stage 1 map
If itís the pump, will it be safe to just put the stock back in with the current tune? Injectors are stock.
ImpreziveWRX is offline   Reply With Quote
Old 01-21-2009, 01:29 PM   #2
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
Yea that defiantly is the fuel pump man. I would say it would be safe to run the stock pump for those power levels
emsmap is offline   Reply With Quote
Old 01-21-2009, 03:53 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
walbros make noise. that's what they do.
mine's been making noise for 5 years and i GUARANTEE i run it a lot harder than you do yours.
you hear it for the first few seconds after starting because that's when the ECU tells the pump driver to go 100% duty cycle, in order to fully prime the system. then it drops it down to 33% for the majority of driving.
Old 01-21-2009, 05:39 PM   #4
emsmap
Member#: 159334
02 WRX, 99RS, 96L
the noise is normal. Mine makes noise EVERY time I start my car lol
Old 01-21-2009, 09:26 PM   #5
ben c
Member#: 200831
does it have a hard time starting after puting gas or start an idel real low
ben c is offline   Reply With Quote
Old 01-21-2009, 09:29 PM   #6
02subynewb
Member#: 164686
i have the same walbro in my mustang with gutted rear interior, that thing whines bad when ur cruising and is def louder when it primes the fuel system
02subynewb is offline   Reply With Quote
Old 01-22-2009, 12:42 AM   #7
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
I noticed louder noise when starting up the day I have it installed... but after 3 years it is really whinning now... It almost sounds like a jet engine the first 10 second or so... I just worry that this is a sign of failing fuel pump...
Old 03-14-2013, 01:43 AM   #8
Stretchvelcroy
Member#: 299169
2002 Wrx/JDM STi v.7
Dirrrty
Resurrecting this thread.
I have rallied my car for over a year no issue
9 months ago we dropped the EJ207 into my 02 bug eye
My walbro fuel pump started whining so loud after I did my first autoX event 6 months ago.
When I pull into a gas station hot off the highway it sound like its going to explode.
Its loud on start up which it known to be normal.
I have an extra one just in case, but I don't want to be changing it on the side of the road.
How long has your walbro pump whined for before dying?
Stretchvelcroy is offline   Reply With Quote
Old 03-14-2013, 05:38 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
they're just loud ime. some more than others.
swap it if it makes you feel better--they're cheap enough!
Old 03-15-2013, 01:53 AM   #10
Stretchvelcroy
Member#: 299169
Dirrrty
I had one.... I am just not overly excited to get wasted on gas fumes.
I shall run the tank dry first seeing as I am changing the pump anyway.
It's sooooo loud
It's louder than the boxer rumble. :/
Old 03-16-2013, 12:54 AM   #11
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
I rally mine as well and besides being loud it functions just fine. My afr is right where it needs to be at all times in all kinds of temp differences.
For piece of mind change your fuel filter to see if it changes, if so there is your restriction.
recce02 is offline   Reply With Quote
Old 03-24-2013, 11:43 AM   #12
Stretchvelcroy
Member#: 299169
Dirrrty
I am going to get her Dyno'd next month so we are doing filter and pump.
Compression/leak down and pretty Much a service overhaul.
Issue should be fixed by the end of service.
Fuel pump going bad? Wrxtuner251 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-04-2008 10:38 AM
Walbro fuel pump going bad or something else? Fairlane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-28-2006 11:55 AM
Any fuel pumps gone bad yet? edubb11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-21-2003 01:19 PM
Fuel Pump going bad? S-1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-19-2003 03:43 PM
Is my fuel pump going bad? Or is it worse? NicGordon Service & Maintenance 5 10-15-2002 02:43 PM
