Old 03-15-2013, 02:45 PM   #3701
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
indeed it has! I managed to go throw 2 motors
I was running stock pinks 550cc before
Hyper is offline   Reply With Quote
Old 03-19-2013, 04:34 PM   #3702
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
well looks like I am going to use 0.9mm nozzle, since it's the only find I could find locally, and it's bigger than my current one
Richard, I ran into another problem, and I've been backtracking it for the past few days.
I have my 2D system connected, with the exception of boost cut failsafe.
FIA2 is monitoring my IDC, pump is priming the system to the given pressure... but it doesn't spray!
I tried disconnecting one of the connectors on the boost valve to simulate working pressure thus forcing the system to spray - no spray, and FIA2 doesn't indicate WI since red light is off
However, if I disconnect the HSV connector, and then disconnect one connector on the boost valve, FIA2 starts blinking the red light!
Note, that in both cases failsafe orange light stays off...
I tested HSV connector with a multimeter for resistance, and didn't get ANY readings.
So based on the this, can I make a conclusion that HSV is dead and I need to change it, or there is something else?
Old 03-19-2013, 05:06 PM   #3703
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
The HSV should read 13 ohms. If you cannot read anything, it is probably dead or one of the wire has come off.
Aquamist is offline   Reply With Quote
Old 03-19-2013, 05:17 PM   #3704
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Got it, I know where to look now
in case it's dead, what are my options?
Old 03-19-2013, 05:41 PM   #3705
Aquamist
NASIOC Manufacturer
Member#: 110029
yes, you use purchase the 806-239B - other than the electrical connection, the two valves are very similar in flow and current drawn.
Old 03-20-2013, 08:35 AM   #3706
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
yep, it's dead, no resistance. Tried to resolder the wires, didn't work
how do I connect this fast acting valve to my 2D system? I can't find any decent pics explaining it
Old 03-20-2013, 07:02 PM   #3707
Aquamist
NASIOC Manufacturer
Member#: 110029
connect the wires to the two pins that measures 12 ohms.
Old 03-24-2013, 12:22 PM   #3708
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Default Pump Resistance?
Originally Posted by dsmtowrx View Post
It's right in front of the washer tank in a GR. So could see moisture but should be pretty protected in the fender well there. How susceptible are they to moisture? Pump is just over a year old...
Would I check pump condition by testing it's resistance? What should that be?
Soooo, getting 6.2 ohms. What should the pump read?
dsmtowrx is offline   Reply With Quote
Old 03-28-2013, 05:49 PM   #3709
Aquamist
NASIOC Manufacturer
Member#: 110029
It is not easy to determine the condition of the pump by reading the winding resistance.
You need to pull the pump head away from the motor to examine the condition of the shaft bearing. If it is rusted up, it will put extra load on the pump. Fuse blowing follows.
Old 04-01-2013, 11:16 AM   #3710
bicho_ojo
Member#: 268847
2005 35r'd STI
I will switching from an SMC meth kit to an Aquamist. I am curious to know what you guys recommend for a 500-600 whp car. It will be on a daily driven tune of 93 and meth and a race tune of c16. Also how many nozzles will I need I was told by awd tuning 3-5. How many Does your kit come with? Adn can you just use denatured alcohol?
bicho_ojo is offline   Reply With Quote
Old 04-02-2013, 04:11 AM   #3711
Aquamist
NASIOC Manufacturer
Member#: 110029
The HFS3 will be good for your application. The kit come with three nozzles as standard. Denatured alcohol is fine provided there are 99% pure.
http://www.aquamist-direct.com/806-0...-valve-system/
Old 05-17-2013, 10:37 PM   #3712
tmclaughlin83
Member#: 336108
2006 Impreza WRX Lim
Red/ Black
Hi, had a question about the pump itself.. I've noticed the pump is leaking out of the metal plate held with the 3 screws. Also possibly out of the 2 feed ends. Sorry for the lack of terminology but I was wonder if the pump can be fixed or if it needs to be replaced?
tmclaughlin83 is offline   Reply With Quote
Old 05-20-2013, 02:01 AM   #3713
Aquamist
NASIOC Manufacturer
Member#: 110029
What system do you have?
Shurflo pump has a tendency to leak after a few years of service due to its design. We have made an o-ring + adaptor to seal the front but we don't have stock of them any more. The best solution (not the most economical, but effective) is replace the entire pump itself.
Old 05-27-2013, 11:54 PM   #3714
y.z.d
Member#: 289172
its so noob question, but what the hell.... i already have aquamist hfs-3 kit (but just missing failsafe gauge). so the question is that can i run other failsafe gauge brands on aquamist hfs-3 or should it be the same failsafe gauge that comes with the kit??
thanks
y.z.d is offline   Reply With Quote
Old 05-28-2013, 02:54 AM   #3715
Aquamist
NASIOC Manufacturer
Member#: 110029
You may be confused between the HFS2 (no failsafe assembly) and HFS3 system.
The HFS2 is supplied with the same controller as the HFS3 (labelled HFS3). But does not come with the following:
1. Dash gauge
2. Gauge cable
3. Flow sensor assembly
4. Hall-effect flow sensor cable.
It is "not" possible to use gauge from other makers.
What is the serial number of the controller?
Old 06-03-2013, 09:56 AM   #3716
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
Sub'ed
M4c0770 is offline   Reply With Quote
Old 06-05-2013, 11:57 AM   #3717
sti20g
Member#: 300874
2006 Subaru sti
gunmetal grey
cant seem to find a map on how to wire into the ecu...
do i have to wire to the dimmer my other gauges don't dim really wouldnt like this one either?
sti20g is offline   Reply With Quote
Old 06-05-2013, 07:33 PM   #3718
Aquamist
NASIOC Manufacturer
Member#: 110029
To test the dim trimmer, just apply a simple 12V to the purple wire.
Old 07-13-2013, 09:18 PM   #3719
06AspenSTI
Member#: 144845
1998 OBSTI
2013 Limited STI
Default low water level light coming on
I have a quick question as I'm having an issue with my hfs-6 setup. The setup was working flawlessly for 3+ years and after the car was parked for a few months it developed this problem.
As the car comes up in boost the low water level light is coming on. Could a faulty level sensor be the culprit of this problem?
I am using a 1 gallon summit racing tank and it is 95% full with a 75/25 meth(vp m1)/water mixture. The light only comes on with the boost, while the system is spraying and is not on while the car is on an incline/stopping hard/and driving not in boost.
Thanks in advance for any insight before I start pulling the system apart.
Pete
06AspenSTI is offline   Reply With Quote
Old 07-15-2013, 03:46 AM   #3720
Aquamist
NASIOC Manufacturer
Member#: 110029
I think it is a failsafe trigger, most probably a clogged jet or filter. Do a test spary with the jet in the open air.
Old 07-15-2013, 10:02 PM   #3721
06AspenSTI
Member#: 144845
1998 OBSTI
2013 Limited STI
Thank you for the reply.
I did the 100% flow test and the spray pattern was good on both of my jets and my gauge was bouncing between 6-7 bars. It seemed the pump was surging during the test. Is the surging normal or should it sound like an external fuel pump?
I did find one major problem that coulld be causing the entire problem though. The clip-in connector where the main meth output line splits to the 2 jets is leaking profusely.
Thank you again
Pete
Old 07-16-2013, 04:27 PM   #3722
Aquamist
NASIOC Manufacturer
Member#: 110029
What type of clip in connector do you have? Can you post a picture?
Old 07-16-2013, 08:24 PM   #3723
06AspenSTI
Member#: 144845
1998 OBSTI
2013 Limited STI
this is the connector that is leaking really bad.
Old 07-17-2013, 05:52 AM   #3724
Aquamist
NASIOC Manufacturer
Member#: 110029
This is a push fit fitting supplied with our older system. We have since changed to a compression fitting:
http://www.aquamist-direct.com/4mm-t...ssion-fitting/
This type of fitting is prone to leak after several years of service due to the shrinkage of the o-ring seal. the new fitting will not leak over time.
It is available from our US dealers or on the online shop above.
Old 08-08-2013, 01:49 PM   #3725
J_Maher_WRX
Member#: 290307
Hey guys,
Looking for a methanol injection system for my 11' wrx. Going to be using a 50/50 blend of water/meth. A friend of mind bought your HFS6 kit a while ago and he swears by it, says it's been amazing for his 20GXTR STi build. Just curious, do you guys not sell that kit anymore?? Or what is your current top of the line kit that is available? Would it be the HFS4??
Thanks guys,
Justin
J_Maher_WRX is offline   Reply With Quote
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 04:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 02:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
