Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 04-21-2011, 11:37 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Precision Turbo oil feed and return - need help
So what exactly do I need to connect them.
When I ordered them I got the oil feed npt to an adapter. I think the an side is -4, can anyone confirm?
For the return, I got something that looks like:
I think it's a 1/2" npt adapter. So how do I get this hooked up to the oil return?
Bad Noodle is offline   Reply With Quote
Old 04-22-2011, 11:53 PM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
For the bottom I used a 1/2 npt to -10 45* elbow, the top I used a 90* 1/8 npt to -4 elbow.
scby rex is online now   Reply With Quote
Old 04-23-2011, 09:31 PM   #3
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Thanks for the info. That sounds pretty good. Any fitment issues / possible kinks with those measurements?
Old 04-24-2011, 01:39 AM   #4
scby rex
Member#: 104878
02 wrxbastardchild
No, it fits well, I made a -10 hardline that makes a nice arc from the 45* on the return to the oem drain.
Old 04-24-2011, 02:16 AM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The oil return line is 5/8, same as -10 AN. Just get a 1/2" NPT to -10 AN adapter and run a nice -10 hose to the barb on the block, like this:
http://www.atpturbo.com/mm5/merchant...Category_Code=
Old 04-24-2011, 09:07 AM   #6
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ Awesome,thanks dude. One more? Can I use a $5 home depot brass NPT to hose Barb or do I need a $30 earl's fitting?
Old 04-24-2011, 09:51 AM   #7
STIBungy
Member#: 51684
Brass is fine.
STIBungy is offline   Reply With Quote
Old 03-23-2013, 04:31 PM   #8
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I have a question can you just get this parts instead:
Get this for the drain get this one and use a quality 5/8" ID oil line: http://www.treadstoneperformance.com...+5%2F8%22+Barb
For the supply it seems that you don't need a restrictor or their oil feed fitting at all:
http://www.treadstoneperformance.com...install-28.pdf
So you should be able to use this instead:
http://www.treadstoneperformance.com...+Feed+line+Kit
Am I missing anything?
Old 03-23-2013, 10:26 PM   #9
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
You are correct on the oil feed. On the drain, I got a 45 an fitting because I couldn't get the oil return like to make the turn from the turbo to the oil inlet on the block without kinking. with the 45 deg drain fitting, no problems. And I tried every kind of oil return line, even the high quality blue one.
Old 03-24-2013, 03:18 PM   #10
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Are you using a banjo fitting on the block for the feed or a straight adapter?
It seems for the 07 WRX the banjo bolt that goes into block is a M12X1.25:
So I could get this for the block a M12x1.25 to -4AN straight adapter:
http://www.ebay.com/itm/4-AN-to-M12x...e9d482&vxp=mtr
For the line a -4AN braided line.. .but how long? about 24"?
and for the turbo a 1/8" MNPT to -4AN
I can get eveything for 30-40 bucks....
Old 03-24-2013, 04:33 PM   #11
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Juan - Does this mean you're going to a rotated PTE setup?
07 wrx, npt sizes needed for oil feed and return mystilexzero Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 03-19-2011 01:19 AM
W T B: TD04 oil feed and return lines/RS Side skirts/WAGON SEATS davedaman77 Private 'Wanted' Classifieds 5 08-02-2008 03:36 PM
Turbo Upgrade Oil Feed and Oil Return Questions w/Pics B16A2NR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-31-2007 01:19 AM
turbo oil feed line problem need help bikerboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-10-2003 09:58 AM
question about turbo oil feed and drain lines inpreza kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-06-2002 03:24 PM
