Old 03-18-2013, 04:46 PM   #1
wagon_war
Member#: 320092
02 WRX WAGON
Default Cams? Which set?
I was looking in putting camshafts in my car. Which set would you go with for max power on a stock bottom end ?
wagon_war is offline   Reply With Quote
Old 03-18-2013, 05:00 PM   #2
Nappula
Member#: 260249
Any mods on your setup or is everything stock besides the bottom end?
Nappula is offline   Reply With Quote
Old 03-18-2013, 05:14 PM   #3
wagon_war
Member#: 320092
02 WRX WAGON
I have a big tmic and Full exhaust/ up and down pipe
Old 03-18-2013, 06:03 PM   #4
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
You have an 02 WRX with TBE, uppipe and a large TMIC? As in still on the stock TD04? I would HIGHLY suggest you do a turbo upgrade before you go down the avenue of cams.
Keep in mind cams will just about always push the powerband to the right for top-end. Your turbo will not make top-end power.
And I'm not going to say you won't gain anything...I just think for the money you are MUCH better off doing a basic STI turbo (vf-xx) swap. Do some research.
Old 03-18-2013, 06:12 PM   #5
wagon_war
Member#: 320092
02 WRX WAGON
I see your point but I have money for one. I figured cams because I have a spun rod bearing and am waiting on parts. In the meanwhile while the heads were off I was going to upgrade my top end.....
Old 03-18-2013, 06:33 PM   #6
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Yeah but Billy I think that money would be much better spent elsewhere! Understand that TD04 turbo is falling on its face (HARD) by 5k RPM with stock head and cams. Most builds that you see beefier cams on already have the built bottom end, big turbo, P&P heads w/ upgraded springs, retainers, valves, etc. And you're not going to want to take things that far unless you're also ready to do something about your transmission (as in swap it with an STI 6-speed or go with a PPG 5-speed).
The turbo on your car supports low to mid-range power (but mostly low ) and the factory cams will support that just fine.
A basic STI turbo swap will blow your socks off compared to a TD04. If I were you I'd start searching for:
-used VF-xx turbo
-used Cobb AP
-new Walboro 255lph FP
-Injector Dynamics (or whatever brand) injectors (something in the 750-800cc for plenty of headroom)
-find a reputable tuner in your area.
Old 03-18-2013, 06:46 PM   #7
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
There are lots of things I would consider before cams.
findurpath is offline   Reply With Quote
Old 03-18-2013, 06:48 PM   #8
wagon_war
Member#: 320092
02 WRX WAGON
Makes since and that route is a little cheaper
Old 03-18-2013, 06:49 PM   #9
wagon_war
Member#: 320092
02 WRX WAGON
I have the fuel pump installed and have sti pinks I thought about getting modded
Old 03-18-2013, 06:53 PM   #10
04ScoobyWtf
Member#: 287974
If you insist in cams get a set of used sti cams and block off the avcs holes. They'll give you a little more cam lift. But know since you changed stuff up now you have to sped more time and money getting your valve clearances right
04ScoobyWtf is offline   Reply With Quote
Old 03-18-2013, 09:58 PM   #11
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
complete ****ing waste of money. You select your cams based on turbo size and hp goal and what you use the car for period. Is your goal 400+? if so add the external and internal parts to get there and select cams. td04 has NO need for cams. If your looking to blow a 1k Ill take it and put your name on the side of my car for a season.
Old 03-18-2013, 10:22 PM   #12
wagon_war
Member#: 320092
02 WRX WAGON
Well was shooting for 300 and was planning a bigger turbo / 16g in mind maybe a little smaller
Old 03-19-2013, 02:27 AM   #13
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I bought cams for a later build, so I stuck them an a stock bottom end for a while. A little while, It moved the power to the right where it got rev happy. The stock crank and bearings didn't like it there. Nether did the next two stock blocks. I got to build my motor when I ran out of stock blocks laying around. Go for it then maybe you will get to build the bottom end.
Old 03-23-2013, 07:59 PM   #14
wagon_war
Member#: 320092
02 WRX WAGON
So I still have no awnser which cams should I choose.... Ill do a turbo swap later......
Old 03-23-2013, 08:01 PM   #15
wagon_war
Member#: 320092
02 WRX WAGON
Your stock crank is single drilled I shall do a cross drilled ...... And ACL bearings
Old 03-24-2013, 03:45 PM   #16
steven_koenke
Member#: 349593
do more minor mods first imop.
steven_koenke is offline   Reply With Quote
Old 03-24-2013, 04:22 PM   #17
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Kinugawa 16G (it's actually an evo3-16G from the specs which is really nice), STi cams. This will be a great combo for what you're shooting for.
Old 03-24-2013, 04:34 PM   #18
wagon_war
Member#: 320092
02 WRX WAGON
I inquired one from my dad not that brand and I have pinks and a walboro 255
Old 04-01-2013, 08:44 AM   #19
wagon_war
Member#: 320092
02 WRX WAGON
Anybody tried 264/264 cams? Same lift as a 272
Old 04-01-2013, 09:23 PM   #20
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Maybe you should try some 280s or bigger
Old 04-01-2013, 11:50 PM   #21
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I'm confused, people are telling you to do everything but cams and you want cams for 300whp?
Upgrade everything but cams. Why ask a question and dismiss everyone's answer?
Not trying to be an ass, if you built the motor then yah, cams are important (dependent on power goal) but for your power goal your cams are fine. You seem to have everything you need for your goals. Don't waste money because you are waiting on parts. Money shouldn't burn a hole in your pocket.
If you are really horny on cams get the sti ones as suggested above. They are cheap to and will be an improvement. No sense to be buying an aftermarket cam for your goals.
OC_Nooby is offline   Reply With Quote
Old 04-02-2013, 12:10 AM   #22
wagon_war
Member#: 320092
02 WRX WAGON
Point taken
Old 04-03-2013, 11:35 PM   #23
wagon_war
Member#: 320092
02 WRX WAGON
Crower 264/264 purchased at a Steal!
Old 04-04-2013, 12:16 AM   #24
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Right on. You still won't gain any power though if you stay with that small turbo.
Old 04-04-2013, 01:11 AM   #25
wagon_war
Member#: 320092
02 WRX WAGON
Yea I know it's a start thoa..... And turbo uprgrade is next then I will get a tune
