Closed Thread
Old 03-24-2013, 09:36 AM   #501
MikeCee
Member#: 136687
15 iginla, dup...
Originally Posted by skywaffles View Post
I've seen plenty of torn and smeared rims on brass cases too. That's not unique to steel.
The chamber will get dirtier with steel cases as they don't expand and seal the chamber when fired. This typically only causes a problem if you transition to brass cases without first giving the chamber a quick scrub. The brass case will expand and stick to the carbon caused by steel case's lack of expansion.
Steel cases are perfectly fine to shoot. Steel jacketed bullets will accelerate wear on the barrel for high velocity rifles. The cost savings in shooting steel will easily pay for new barrels if you shoot enough though. For pistols this is less of a concern because pistol cartridges don't generate enough pressure and force on the barrel to make steel jackets detrimental.
What about extractor wear?
MikeCee is offline
Old 03-24-2013, 09:44 AM   #502
chulooz
Member#: 159438
99 GC8
Originally Posted by SonicWRX View Post
I talked him down to $700. He was a nice old guy and we both went away happy.
I was tempted to shoot it at the range yesterday, but held off. I figure it's old enough to need some fresh lube before firing. After reading up a bit I'm glad I did. They can be a bit quirky and there are no spare parts available. Some are shooters, some are not. I'm anxious to see what I got. Hopefully a shooter.
You have a never fired NIB model. Its not a shooter, its a collector.... until you shoot it, then its just used. Maybe find a trade for a more range appropriate specimen + cash?
chulooz is online now
Old 03-24-2013, 10:18 AM   #503
MikeCee
Member#: 136687
15 iginla, dup...
Fuddy duddy
MikeCee is offline
Old 03-24-2013, 10:21 AM   #504
PGT
Member#: 57283
2014 4.7L of TT Fury
w/ 4Matic
Meh. Go shoot it....its relative value isn't related to its particular accuracy.
PGT is offline
Old 03-24-2013, 10:34 AM   #505
Strider
Impeded.
Member#: 2197
an inconvenience,
properly considered.
Pretty much every gun ever made is test fired before it's sold anyway. Shoot it and enjoy it.
Strider is offline
Old 03-24-2013, 11:31 AM   #506
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Com-tac Minotaur came in.
Psychoreo is offline
Old 03-24-2013, 12:49 PM   #507
MikeCee
Member#: 136687
15 iginla, dup...
that last picture is awesome
MikeCee is offline
Old 03-24-2013, 12:59 PM   #508
NutBucket
Member#: 90804
'15 SJ, '05 GG
Dirty
That's his scepter
NutBucket is offline
Old 03-24-2013, 01:08 PM   #509
CryderSpeed
Member#: 88816
TO TWERK
It's like someone went to Home Depot and just went crazy with pipe fittings.
CryderSpeed is offline
Old 03-24-2013, 01:27 PM   #510
Psychoreo
Member#: 79643
2015 WRX STI
Originally Posted by NutBucket View Post
That's his scepter
That flash light is bright as **** too 700 lumens, 500 lumens, and a 700 lumen strobe
Old 03-24-2013, 01:32 PM   #511
kinkinhood
Member#: 54934
2011 Honda CRZ
need a 4000 lumen flashlight.
kinkinhood is offline
Old 03-24-2013, 01:32 PM   #512
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
If you miss your target with that gun, you can beat him to death with that flashlight!
ganzhimself is offline
Old 03-24-2013, 01:44 PM   #513
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Oh I'm going to shoot it. I have no guns that will remain unfired. The only thing that keeps them virgins is my time and the weather.
I disassembled the bolt and found a little rust on the firing pin spring and the bolt body under the handle. It cleaned up easily. The whole bolt and chamber area had some sort of preservative on it that bleeds out as bright orange; not cosmoline, but not natural. Ten minutes with Q-tips, 0000 steel wool and CMP and it's back in business. The barrel had the same stuff in it.
I put a fired case in the breech to test the trigger pull (these guns can't be dry fired) and it is VERY light. I'm guessing 1-2 lbs, but will check it with a digital pull gauge to make sure.
The sights are a marvel and the front has 10 different inserts: three posts of varying widths and seven circles that jump in diameter by 0.2 mm. They are made in Australia and attach to dovetails on the barrel.
I probably can't make it back to the range for another try at March's 25 yard irons target, but I'm thinking April could be a competitive month for me.
SonicWRX is offline
Old 03-24-2013, 01:59 PM   #514
53x12
Member#: 206332
For a first AR15 build, would you guys recommend a 14.5" carbine or a 16" middy?
53x12 is offline
Old 03-24-2013, 03:16 PM   #515
The Motel Fella
Member#: 140147
02 '13 Sienna
I make minivans look hot
That is a really pretty gun sonic.
The Motel Fella is offline
Old 03-24-2013, 03:17 PM   #516
ToddZ199
Member#: 71637
2006 Freestyle
OMGHi2U
My parents came over for dinner yesterday and my dad brought me this:
I didn't need anymore 9mm, but now I have over 1000 rounds, so I can shoot some I guess.
ToddZ199 is offline
Old 03-24-2013, 03:28 PM   #517
subaru3169
Member#: 55252
* pullup bar *
i wish ppl simply gave me ammo
subaru3169 is offline
Old 03-24-2013, 03:30 PM   #518
Ryan24
Member#: 451
2000 Impreza 2.5RS
2008 Legacy GT Limited
16" is still a carbine, 18" is considered a Mid
If it is your first then you cannot go wrong with a 16
The only issue with a 14.5 is you have to have the muzzle devise welded on for it not to be labeled an SBR. Which becomes an issue if you want to change it to an aftermarket one.
Ryan24 is offline
Old 03-24-2013, 03:31 PM   #519
ToddZ199
Member#: 71637
2006 Freestyle
OMGHi2U
So do I.
I paid him for it.
ToddZ199 is offline
Old 03-24-2013, 03:40 PM   #520
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
This is my rifle, this is my gun. This one's for fighting and this one's for fun.
Couldn't resist.
SonicWRX is offline
Old 03-24-2013, 03:43 PM   #521
vecdran
Member#: 162932
I think he's talking about the gas system. 18" usually use an Intermediate gas tube.
If you're going to get a 14.5" middy, make sure it's from a reputable manufacturer like BCM. They are more finicky than 16" middys.
As far as the muzzle device thing, I wouldn't worry too much about it. Most manufacturers make 1.5" versions of their comps/brakes, or are already as long if not longer than that. A good pin & weld job shouldn't cost more than $40.
vecdran is offline
Old 03-24-2013, 04:49 PM   #522
53x12
Member#: 206332
Yeah I was talking about gas systems in terms of the lengths I am considering (14.5" vs 16")
I know the 14.5" middy is an option, but figured if I want a middy I would just go with the 16" and not have to deal with any reliability issues. Seems like the 16" middy might be the best route for me to go with.
53x12 is offline
Old 03-24-2013, 04:52 PM   #523
MikeCee
Member#: 136687
15 iginla, dup...
Originally Posted by ToddZ199 View Post
So do I.
I paid him for it.
Did he gouge you too? Jesus christ. They come over, eat your food and take your money for **** you didnt need. Thats effed up man.
MikeCee is offline
Old 03-24-2013, 04:56 PM   #524
subaru3169
Member#: 55252
* pullup bar *
So do I.
I paid him for it.
"hey son, gimme some money"
Old 03-24-2013, 04:56 PM   #525
ToddZ199
Member#: 71637
2006 Freestyle
OMGHi2U
And drank my beer!
He used a coupon on the ammo.
ToddZ199 is offline
Closed Thread
