Old 03-19-2013, 10:21 AM   #1
njsubi86
Member#: 230575
2004 WRX SRR
'01 OBW, '86 944 Turbo
Default Head removal 2002 WRX
2002 WRX stock
Quick questons:
1. Can head be removed on turbo side by just unboltng exhaust manifold nuts on head and lifting head up and off after unbolting head from block? Or does the uppipe have to be unbolted as well, and the entire exhaust manifold removed frm both heads?
o
2. I am told the heads must be machined to "reverse" the effects of possible warpage if the motor was overheated. Is putting a straight edge on the heads a reliable way to tell if they're warped? If so, and they appear straight, is it wise to reinstall them without machining them, or is it lik erolling the dice to do so?
njsubi86 is online now   Reply With Quote
Old 03-19-2013, 10:35 AM   #2
vkyle8
Member#: 312540
brown
As far as number 2 goes you'll need a proper straight edge and feeler guages to measure deck warpage
vkyle8 is offline   Reply With Quote
Old 03-19-2013, 10:36 AM   #3
madkayaker
Member#: 57378
2002 wrx w/ sti swap
04 sti, 11 forester xt
1. Are you pulling the head with the engine in? It would be faster to just pull the whole engine imo.
2. A lot of people get away with block sanding the head so that they have a fresh clean surface to seal. I have done a couple of heads that way with no issues. The dealers use a sanding disk and an air tool to resurface them, and I've heard of a lot of them coming back with blown gaskets. The best way would be to take them to a machine shop and have them machined and might as well let them pressure test the valves while they're at it.
https://www.youtube.com/watch?v=5UYkfuTyugk
madkayaker is offline   Reply With Quote
Old 03-19-2013, 10:41 AM   #4
njsubi86
Member#: 230575
2004 WRX SRR
Default Head Warpage
Is there an acceptable tolerance for warpage, or does the differential between the head and the staightedge have to be less than a certain value? I will be installing stock head gaskets purchased at the Suby dealership in my local area. Also, I heard if the heads are warped beyond a certain point, they are trash anyway. I suppose the same goes for the block if it is warped beyond a certain amount. I was hoping to just be able to reinstall everything and be done with it, but I'm getting the vibe this won't be the case. I would really hate to find out the heads are leaking and have to pull the motor again and repeat the entire process to fix this car.
Old 03-24-2013, 06:07 PM   #5
madkayaker
Member#: 57378
All of the info you are seeking is in the service manual.
Old 03-24-2013, 07:07 PM   #6
devilmademedoit
Member#: 289267
03 wrx
wrb
Why are you pulling heads? Gaskets blown? Did it overheat? I've done head gaskets on a 2.5 legacy and my wrx legacy I left motor in wrx motor out. Way easier and less stressful with motor out. You can pull a wrx motor in under 3 hours
devilmademedoit is offline   Reply With Quote
Old 03-24-2013, 07:09 PM   #7
devilmademedoit
Member#: 289267
03 wrx
wrb
Where in jersey are you? The machinist I used was very reasonable Heads came out beautiful
