Old 03-24-2013, 05:53 PM   #1
RISubieRex
Member#: 307060
2004 Impreza WRX
Default Bad Brake Hose? Bad Caliper?
So. I replaced my brake pads 2 weeks ago and yesterday I noticed a burning smell of brake. So i checked my rear passenger wheel and it was really tough to turn compared to the rear driver side. I pull off the rear passenger caliper and BAM pads are toast. So I clearly have a sticky caliper...
I tried to compress the piston and it was really tough but it compressed. I built up pressure in the lines by stepping on the brake pedal like 20 times and tried it again but this time I cracked the bleeder and it was alot easier to compress..?
any thoughts?
My buddy told me it could be the e-brake but I don't think it is.
RISubieRex is offline   Reply With Quote
Old 03-24-2013, 06:19 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Wrong forum. For future reference, POWERTRAIN refers to the motor.
Edit: Onto your problem, you likely need to replace or rebuild the caliper. It's frozen.
Old 03-24-2013, 07:36 PM   #3
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
If the caliper compressed when the bleeder was cracked, its not frozen.
Does it move on the slides properly?
Are there any kinks in the hose?
What you are describing (I tried to compress the piston and it was really tough but it compressed. I built up pressure in the lines by stepping on the brake pedal like 20 times and tried it again but this time I cracked the bleeder and it was alot easier to compress..?) is exactly how a single piston caliper behaves. What were you using to compress the caliper?
Old 03-24-2013, 08:01 PM   #4
RISubieRex
Member#: 307060
2004 Impreza WRX
WELL. Thats embarrassing haha sorry I was in a rush. and I am using a pair of channel locks. there seems to be no kinks in the hose as well.
Old 03-24-2013, 08:03 PM   #5
RISubieRex
Member#: 307060
2004 Impreza WRX
How can I tell if its moving on the slides properly? I lubed them up and they move in and out very freely.
Old 03-24-2013, 08:06 PM   #6
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Sounds like your caliper is fine. Using the channel locks you are potentially pushing the piston in crooked making it extra difficult. Use a C-clamp (or a brake caliper tool)
Old 03-24-2013, 08:09 PM   #7
RISubieRex
Member#: 307060
2004 Impreza WRX
Thanks, appreciate your help. So before I avoid burning up brand new pads again what do you suggest I do?
Old 03-24-2013, 08:13 PM   #8
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Are the pads tight in the caliper bracket? They should be able to slide in and out freely. Sounds like your pads are a hair too big and are sticking here.
Old 03-24-2013, 08:16 PM   #9
RISubieRex
Member#: 307060
2004 Impreza WRX
hm, ill have to check tomorrow im home now and not at the shop. thanks!
Old 03-26-2013, 12:11 AM   #10
RISubieRex
Member#: 307060
2004 Impreza WRX
turns out the rust from me compressing the piston when I changed the caliper got caught under and in the piston cylinder preventing the piston to compress away from the pads. 90 dollars later new pads and a caliper shes good to go.
