Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 03-22-2013, 07:25 PM   #2001
solistik
Member#: 345948
Originally Posted by webster354 View Post
The Canadian Limited models come with stock HID headlights.
Yeah, I considered Canada in the European market but that's what I am wondering if this set is the same set the Canadian version got.
solistik is offline   Reply With Quote
Old 03-22-2013, 07:34 PM   #2002
aeoporta
Member#: 334126
2013 5mt Sp Premium
Venetian Red & Dark Gray
this seems related to the headlight question.
http://forums.nasioc.com/forums/show....php?t=2483457
you could always wait for the crosstrek hybrid
Old 03-22-2013, 07:44 PM   #2003
solistik
Member#: 345948
Thanks man, that actually did help. The headlamps I originally posted are the HID headlamps because these headlamps are listed as "headlamp assy HALOGEN TYPE" and they are half the price.
Old 03-22-2013, 11:35 PM   #2004
webster354
Member#: 343343
2014 Impreza 5dr Ltd
Originally Posted by imcausinmadrukis View Post
Thanks! Question though, how are you getting 35% off? I've tried several parts and it only works out to 19% off.
webster354 is offline   Reply With Quote
Old 03-23-2013, 11:05 AM   #2005
aeoporta
Member#: 334126
2013 5mt Sp Premium
false advertisement
Old 03-23-2013, 12:14 PM   #2006
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
What do you guys think about removing the rear muffler and getting a bolt on turn down pipe
Just for noise sounds ok
Not looking for crazy power but the weight saving should help
subaru222 is offline   Reply With Quote
Old 03-23-2013, 12:42 PM   #2007
tenaciousZ
Member#: 342279
2012 Impreza Sport
There's a few clips of how that'll sound up on YouTube.. to each their own but I'm looking forward to the rallisport racing headers up get the true Subaru rumble. my piggy bank is already started lol
tenaciousZ is offline   Reply With Quote
Old 03-23-2013, 03:15 PM   #2008
Angelus911
Member#: 89967
2012 Impreza Sport
it says up to 35% off MSRP, not 35% off everything
Old 03-23-2013, 04:31 PM   #2009
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by Angelus911 View Post
ordered the STi rsb and the 2 bushings with the code
Can someone verify the part number for the 19mm STI swaybar and bushings? Do they come together or do you need the mounts and bushings separate from the bar?
jsteg is offline   Reply With Quote
Old 03-23-2013, 04:46 PM   #2010
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
I don't see part #'s but here's the page If you have the base you'll need everything on that page. If you have the sway bar already you just ned the bar and bushings, and they're sold separately.
apexracer is offline   Reply With Quote
Old 03-23-2013, 04:53 PM   #2011
jsteg
Member#: 329271
Ice Silver Metallic
Gotcha, thanks. Even with the "discount" it doesn't really work out to be a deal. I can get it here https://www.subaruonlineparts.com/pr...6569b16e96ec16 with the bushings for $94...figure in the same shipping price and I'd be saving $14 without a "discount code"
Old 03-23-2013, 04:54 PM   #2012
aeoporta
Member#: 334126
2013 5mt Sp Premium
Old 03-23-2013, 04:56 PM   #2013
jsteg
Member#: 329271
Ice Silver Metallic
Haha, yeah, got it, and like I said..cheaper there even without a discount code.
Old 03-23-2013, 05:36 PM   #2014
aeoporta
Member#: 334126
2013 5mt Sp Premium
Subaruonlineparts are always cheaper
Old 03-23-2013, 06:56 PM   #2015
MrLebreen
Member#: 344816
2012 Impreza 2.0i
Are the headers for the N/A impreza man?
MrLebreen is offline   Reply With Quote
Old 03-23-2013, 07:27 PM   #2016
tenaciousZ
Member#: 342279
2012 Impreza Sport
Indeed, check out the Rallisport 2.0i UEL header build thread.
Old 03-23-2013, 07:35 PM   #2017
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Cool, I'll keep an eye out for you. I just haven't seen many 2012+ Imprezas on the road in general...
I've only seen a handful. Most of them are DGM like mine. Have you went to any of the local events/gatherings?
pkL is online now   Reply With Quote
Old 03-23-2013, 11:07 PM   #2018
Rememo
Member#: 340728
2013 Impreza 5-spd
Not with the current SubarupPartsWarehouse discount code.
For me the sway bar and bushings were $102.90 shipped from SubarupPartsWarehouse with the discount, but would have been $111.72 from SubaruOnlineParts.
But yeah... normally they are.
Rememo is offline   Reply With Quote
Old 03-23-2013, 11:49 PM   #2019
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Ya it doesnt sound that bad at all
Old 03-24-2013, 12:32 AM   #2020
leonyuen
Member#: 330720
2013 2.0i Sport 5dr
Installed a set of Rally Armor UR (grey) mud flaps. Here's some installation tips for those interested:
  • Approx. 1.5 hour installation. (30min for the first side, 15min for the other side) x 2. Note: the rear mud flaps will take longer to install on a 5dr because you have to remove an additional inner liner (as recommended in the instructions).
  • Useful tools (but not necessary): body clip removal pliers, trim pry tools, Phillips off-set screwdriver (I didn't have one so I used vise grip pliers and a short bit. There wasn't enough room to use a ratchet).
  • To removal the clips that have a Phillips head, hold the outer portion while you're unscrewing it. It's only approx. 1/4 turn to remove it.
  • To reinstall the clips, separate them into 2 pieces and insert the outer portion of the clip first and make sure the body sections are secured. Finally, insert the inner portion of the clip.
  • If you're not removing your wheels, install the hardware for the inner most portion of mud flap before you install it on the vehicle, but leave a little slack for adjustments. There's very little space to fit your tool to tighten it in the wheel well.
And of course, here are some pictures:
I just installed the same thing on my SWP sport trim - so just add the spoiler on the outside. I got red trim on the RA Mud Flaps though =). I didn't remove the inner liner to install anything, just yanked the bumper skin out while installing.
leonyuen is offline   Reply With Quote
Old 03-24-2013, 11:53 AM   #2021
jsteg
Member#: 329271
Ice Silver Metallic
The discount code "saves" you ~$20...the numbers above (which were the same for me when I went to checkout on both sites) don't reflect a $20 savings!
Old 03-24-2013, 02:28 PM   #2022
webster354
Member#: 343343
Yeah you're right, I've only seen a DGM sedan and hatch. I haven't been to any meetings yet, but I plan to sometime.
Old 03-24-2013, 07:39 PM   #2023
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Just to confirm, for those of us with the 16mm bar, we do not need to order two bushing brackets, right? We just need the 19mm bar and two bushings, correct?
RSB P/N: 20451FG020 (quantity: 1)
Bushing P/N: 20464FG020 (quantity: 2)
Right?
Thanks!
Old 03-24-2013, 07:47 PM   #2024
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Right?
Thanks!
Yup!.
Old 03-24-2013, 07:51 PM   #2025
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Originally Posted by flyboy1100 View Post
Yup!.
Perfect. Just ordered the RSB, two bushings for the RSB, and a Cobb short shifter. I'll do without replacing the shifter bushings for now, and maybe forever if I'm happy with how the Cobb shifter feels with the OEM bushings.
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-29-2011 11:31 PM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
