Old 03-16-2009, 11:35 AM   #26
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
I'm not sure the extra 'cooling time' makes any difference.
I assume the primary cooling occurs from air going through the rotor - which happens whether you are on or off the brakes.
If an average lap is 2 minutes - lets guess you are on the brakes for 20 of the 120 seconds. Do you think 19 or even 18 seconds would make much difference. I say you'll need date to back that up.
Not slowing down as much I think is the winner.
energy absorbed = 1/2mv^2 (vinitial-vfinal)
The squared term drives the equation - and if v final is higher - thumbs up.
To the OP running XP-8 - i think you are ready for the next level.
KNS Brakes is online now   Reply With Quote
Old 03-16-2009, 11:35 AM   #27
KNS Brakes
Member#: 125739
2015 WRB WRX
Originally Posted by boost junkie View Post
and I also had to scrub off more speed since cornering speeds were lower than normal.
I think that's your answer
Old 12-23-2010, 03:07 AM   #28
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Bringing this back from the dead. I was wondering if anyone has tried this idea yet? I searched and found nothing like this on a Subie . I found them on Audis, Porsches and this is a Mini Cooper. Seems like it would help with the problem of the tire hitting the hose.
Murphdog is offline   Reply With Quote
Old 12-23-2010, 08:48 AM   #29
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the backing plate or the lower control arm scoop?
The backing plates have been done and IIRC, there is a company that makes them. I think Dunk was running them, as he had done extensive work on brake cooling. Check out some of his threads.
Old 12-23-2010, 11:03 AM   #30
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
racecomp's new brake ducts are much nicer now too, and have an almost full backing plate type thing going on.
the lower scoop a few people have run. not sure how effective it is.
AndyRoo is online now   Reply With Quote
Old 12-23-2010, 11:32 AM   #31
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Not the backing plate just the scoop. Seems like it should work pretty well. I'm just concerned about ground clearance issues.
Old 12-23-2010, 11:57 AM   #32
08WhiteRex
Member#: 187453
2012 Mulletmobile
you shouldn't really have issues that close to the wheel, but you could fab up a bracket on the control arm so that you could bolt it on trackside while you are changing pads/ wheels if you are that concerned about it.
08WhiteRex is offline   Reply With Quote
Old 12-23-2010, 02:05 PM   #33
Murphdog
Member#: 75414
2004 STi
Its the Blue one
True. I thought about a bracket and some dzus fastners. Hey I was wondering if any of you guys could help me out with an argument I'm having with a friend. He keeps telling me if I'm worried about the hose rubbing the tire to just use a smaller hose. He said a 1.5'' hose would work just as well as a 3'' as long as the scoop or collector is the same size. I completly disagree with him but I was wondering if any of you have a diagram or some sort of fluid dynamics sketch showing how a smaller hose diameter would be less effective.
Old 12-30-2010, 08:00 PM   #34
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Bump for any info
Old 12-30-2010, 11:34 PM   #35
08WhiteRex
Member#: 187453
2012 Mulletmobile
Uhhhhh..... I've got physics if you want that form of machete for your intellectual thicket.
Total Volume = (Cross sectional area) x (Velocity) x (time)
Assuming the velocity and time remain constant, the cross sectional area (a function of the diameter), is the only determining factor.
The cross sectional area is equal to ∏r^2, So the cross sectional area of a 1.5" tube will be 1.75 square inches. The cross sectional area of a 3" tube will be about 7 square inches.
That means that, if just given the open end of the pipe as the collector, the 3" pipe will flow roughly 4 times more air at a given velocity over a given amount of time than the 1.5" tube.
Now, if the size of the collector remains the same for both, this will increase the velocity of the air in the smaller tube, thus increasing its flow. But this will also create a high pressure zone where the bottleneck is formed, and that will force a large amount of the air out of the collector and into the air stream around the car, making it useless. Taking all of this into account, the larger diameter tubing would still allow for much higher flow.
I'm not going to punch out all of the dynamics of it, but i would say that given the same size collector and a given speed, the 3" diameter tubing is going to flow over 2 times more air than the 1.5" tubing (any less-tired engineers out there can check it, but i'm just guesstimating). Note that it is not as simple as saying 3/1.5= 2. But it would definitely flow more air than the smaller tubing.
Hope you didn't get lost and that it was somewhat helpful.
Old 12-31-2010, 12:32 AM   #36
Murphdog
Member#: 75414
2004 STi
Its the Blue one
You sir are a to damn smart. I thank you for the info and I'm sure this will help settle the argument. Thnak you again.
Old 09-16-2011, 07:52 PM   #37
02RS25
Member#: 293773
2003 Impreza 2.5RS
BRP
search. i know i saw one done. and it looked descnet from what i saw. pretty inexpensive too
02RS25 is offline   Reply With Quote
Old 09-16-2011, 08:02 PM   #38
scoobiedude 66
Member#: 231599
2009 WRX
Obsidian Black
ha ha nice thread revival... telling someone to search in a thread a year old... but still good advice
scoobiedude 66 is offline   Reply With Quote
Old 10-28-2011, 11:19 AM   #39
chicagozer
Member#: 247446
Going to bump this one myself. Have a nice DIY solution for the fronts. I'll try to post some pictures. Was wondering what if anything anyone had done for the backs.
We are racing a 99 Legacy Brighton in the 24 hours of LeMons on WRX 16s, I can't afford bigger/better so I have to try to cool them down more.
Cutting an opening in the rear strut tower or the like would be a no-no. They want the gas tank completely sealed off. There just doesn't seem to be much room to get a duct in there unless I come in from the back somehow.
chicagozer is offline   Reply With Quote
Old 03-24-2013, 08:00 PM   #40
Scargod
Member#: 260314
2008 STI hatch
I cannot find info on rear brake cooling. I guess it's not done? Not even ventilating the backing plate?
Scargod is offline   Reply With Quote
Old 04-05-2016, 04:06 AM   #41
billyboy999
Member#: 292919
2007 STi
Back from the dead!... well I can give some input here. I bring an infrared thermometer to track days. Some example numbers when I shoot them after a session:
Fronts - over 800F
Rears - 200-300F
It's not worth cooling the rears. If anything you'd want to keep them toasty so they work better with whatever race pads you're running.
billyboy999 is offline   Reply With Quote
Old 04-05-2016, 10:18 AM   #42
Scargod
Member#: 260314
2008 STI hatch
Agreed that being warm enough to work at optimum could be an issue. I was using more aggressive DTC 70 pads in the rear and 6's in the front at one point. With my ABS I have felt like the sensitivity is pretty good. With my BBK and Gyrotor floating rotors in the rear I have not seen a need to mess with a biasing arrangement. At times the rear has felt a little happy (wiggly-loose) under really hard braking, going down from 135 to ? at the end of WGI's front straight.
Starting out, with some Brakeman rotors, I cooked Hawk HT-10s. Then I installed front brake cooling, whereas I had just had the backing plates off. I have the rear backing plates removed.
What mpg are you getting and what are your mods? WRXVII General Community 45 12-19-2011 08:21 PM
What are some DIY for 09-10 WRX? Zeppelinkix87 Interior & Exterior Modification 24 03-19-2010 05:52 AM
cool/odd set up, what are your thoughts WjRgX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-24-2006 11:03 AM
What are your trunk storage solutions? T-WRX General Community 32 09-12-2005 01:35 AM
