Closed Thread
Old 10-17-2009, 08:25 PM   #1
SkylineR35GTRx
Member#: 25119
2005 Impreza WRX STi
Default Radio reception is worse after installing aftermarket head unit. Help please!
Hey everyone,
So I installed an Alpine CDA-9886 in my 2005 STi recently. I noticed some radio stations get more static, and I get worse reception. I know for sure my antenna has less range now.
I know this because two radio stations from my home town is clear when listening to it from my college town about 80 miles away with the stock unit. Now with the new head unit, one station is very static-y, and the other I can't even get a clear signal.
Does putting in a new head unit suppose to change how well it can receive some stations?
I double checked the antenna connection and the wiring for the antenna and it looks ok. The thing is, the antenna connection does not sit flush with the receiver on the Alpine. I can still see like 1/4th of an inch of silver metal sticking out. I tried pushing the two connections together as tight as I could, and it does not go in any further. I will try to get a picture of this soon. Any help is greatly appreciated!
SkylineR35GTRx is offline
Old 10-17-2009, 08:35 PM   #2
rabbit_ears
Member#: 208908
06 2.5i Wagon
Red
did you hook up the power antenna lead? Subarus have a signal amplifier for the antenna that requires power. If you didn't hook up the power antenna lead it's not getting power and you're not getting radio reception
Found this out by trial and error when i did the same thing. good news it's an easy fix, if in fact this is your problem.
rabbit_ears is offline
Old 10-18-2009, 01:21 AM   #3
weshole
Member#: 193373
1996 Outback
White/Grey
That's the exact thing I found out by installing an aftermarket dvd in my friends Sti. Wish I had known when I first installed it though.
weshole is offline
Old 10-25-2009, 02:21 AM   #4
SkylineR35GTRx
Member#: 25119
Hey guys,
Thanks for the suggestion. At first read I actually thought this was the problem. When I read Power Antenna, for some reason I thought htey were talking about the antenna's that automatically goes up and down when the car is started/turned off. Anyways, I thought this was the problem but when I was unscrewing the cover, I realized I actually had crimped this wire together as a test crimp because this was my first time doing it. I thought maybe my crimping was bad so I recrimped this wire, and checked all connections again. Well, the problem still persists. For some reason it is not getting as good of a signal, and it's actually pretty bad..the signal. Some stations I usually get are a has a bit of static.
I am thinking maybe...the crimp connections aren't good enough to supply the power to the antenna, and maybe even the 12 volt wire aren't wired as well as it could. Should I try soldering the wires together and maybe this will give the wires a better connection and solve the problem?
Here is the picture of the antenna connection. There is a bare metal part that doesn't sit flush with the sleeve. I'm not sure if this is the problem because when I plugged it in as tight as I could, this is what it looks like. Anyone with an Alpine 9886, can you tell me if this is what yours look like? Thank you.
Old 10-25-2009, 08:59 AM   #5
C89ZX7R
Member#: 119154
2004 White
STi
Did you hook 12 volts to the antenna wire? Your suppose to take the remote wire from the deck and hook it to the blue wire on the factory harness plug which will power the antenna amp located in the "C"-Pillar.
C89ZX7R is offline
Old 10-25-2009, 11:23 AM   #6
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
12v is generally 12v... the antenna amp isn't a high current draw item so unless the wires are corroded a crimp will be as good as a solder joint for the most part. Seat the antenna connector as well as you can into the connector, it probably won't go in all the way, generally no worries.
Did you tint the back window?
I have seen in the past where the aftermarket radio didn't get as good of reception as the factory deck... and I've seen vice versa... 80 miles is a long way to reach out for a radio station, particularily FM.
couchflambeau is offline
Old 10-25-2009, 01:07 PM   #7
hookedontronics
Member#: 216078
2005 Legacy GT L
pretty common problem, get sirius or xm
hookedontronics is offline
Old 10-26-2009, 12:55 AM   #8
PolarisSnT
Member#: 85905
2004 WRX
Same problem with my Alpine unit. All wires hooked up, just bad reception. Havnt listened to the radio in a year and a half which sucks, but oh well.
PolarisSnT is offline
Old 11-21-2009, 05:10 AM   #9
Chainsaw_Willie
Member#: 211337
2006 WRX
Resurrecting this thread to get a little more info.
My '06 came with an Alpine CDA 9856 in it. Radio reception totally blows, I can hardly get anything in, even the strongest local stations have static in them most of the time.
Pretty sure the power antenna lead isn't hooked up to anything as I don't remember seeing it connected when I pulled the head unit out to connect the RCA cables for the amps. There's a power antenna lead and an amplifier turn-on lead that are both blue. The amp lead is, of course, connected to my amps to turn them on. What should the power antenna lead be connected to on the factory wiring harness? What color is the wire I'm looking for and where is it located? A picture would be even better.
Chainsaw_Willie is offline
Old 11-21-2009, 11:24 AM   #10
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Power antenna is usually blue with a white stripe..out of the HU, i'm not 100% what the car is, but I bet it's up in the sticky at the top of the section..
Aaron'z 2.5RS is offline
Old 11-21-2009, 06:50 PM   #11
Chainsaw_Willie
Member#: 211337
2006 WRX
Just to update with a success story. Pulled out the HU and sure enough, the power antenna lead was not connected. Got that hooked up and radio reception is dramatically better. Seek works on the HU now, before it would just scan continuously, never picking up a station. Now it stops on all the normal stations and the stations I listen to regularly are much cleaner and have far less static.
Thanks for the tip on the 10 minute fix! I had no idea there was an antenna amplifier in these cars. Even went to Car Toys and told them I was having problems and they wanted to charge me a bunch of $$ to install an aftermarket antenna in the headliner.
Old 11-22-2009, 10:36 AM   #12
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Every head unite has a listing for how well it will pick up radio signal. Im guessing that your radio like mine dose not have a strong receiver in it.
Later.
Badmunky is offline
Old 11-22-2009, 11:02 AM   #13
Daishi00
Member#: 78952
2005 WRX
No, he didn't hook up the power antenna lead as has been discussed throughout this and countless other threads.
Daishi00 is offline
Old 11-23-2009, 11:10 AM   #14
Espo
Member#: 219981
2008 STi
Spark Silver
Wow, i've been frustrated since I installed my nav unit about a month ago, I like to listen to the local morning talk show on my way to work and the reception sucks, and cuts in and out a lot. I know for a fact I did not connect the power antenna wire, I too thought it was for one of those antennas that go up and down when the car is on/off.
I will rip it apart tomorrow and connect the power antenna wire to the 12v lead and see if that helps.
Espo is offline
Old 11-23-2009, 11:41 AM   #15
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
You need power, +12v, to amplify the signal. If you used
a Metra plug this would be obvious.
CRAZYHAWK is offline
Old 11-23-2009, 03:42 PM   #16
Dobbs
Member#: 28291
2015 WRX
i installed a cda 9883 this weekend and am having the same trouble... i appreciate the thread, thanks!
Dobbs is offline
Old 03-24-2013, 06:50 PM   #17
rallytim888
Member#: 85413
2004 WRX
Sorry to resurrect this oldie, but this just saved my day!! Plus 926,393,263 for connecting the power ant to the good old yellow 12v!
rallytim888 is offline
Old 03-24-2013, 07:10 PM   #18
klarowe
Member#: 284753
2004 WRX STI
Do not connect it to the yellow. The yellow in the harness is constant 12volts. You are now powering the antenna at all time and it WILL drain your battery. You need to connect it to the power antenna or remote output from the radio (blue/white or blue). If you do not have either of those then connect it to the red switched 12v wire.
klarowe is offline
Old 03-24-2013, 07:32 PM   #19
rallytim888
Member#: 85413
2004 WRX
Wow, thanks for the heads up. Makes sense now that I think about it but I was just so happy it worked, I didn't think about the fact that its constant. Thanks again!
Old 03-24-2013, 09:00 PM   #20
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No need to resurrect this ancient thread when the info is in the stickies.
Mulder is offline
Closed Thread
Illustrated guide to install aftermarket head unit and front speakers in an '08 WRX Sabba Car Audio, Video & Security 17 10-05-2010 07:40 PM
Powering Component speakers with just a head unit??! Help Please! Jsunn Car Audio, Video & Security 8 11-08-2009 03:11 PM
Replacing stock head unit help, please. Okeyd57 Car Audio, Video & Security 4 12-08-2006 11:40 PM
Poor FM reception after going to aftermarket head unit? overdose Car Audio, Video & Security 14 04-28-2004 10:39 AM
Aftermarket head unit wiring question - WRX radio illumination light? Fubaru Car Audio, Video & Security 2 03-09-2002 03:55 AM
