Old 03-23-2013, 02:12 PM   #2776
Only1Wrx
Member#: 300799
2011 Impreza WRX
Blue Pearl MR
Originally Posted by _davin View Post
OK you just said revs too, wtf are you talking about. Are you saying while it's running? If the car dies while it's running due an electrical issue it's the alternator.
What I mean by revs- it's like I have to hold the key on for a while and it wants to turn on but it doesn't the first time. The second time I turn the key it almost chokes turning on.
I'll try what celery said with a multimeter. Cuz I do have a sub in the back but this happened even before that. I'm just worries as I just sent the last payment and my warranty is almost out!! I'm at 27k!
Only1Wrx is offline   Reply With Quote
Old 03-23-2013, 02:27 PM   #2777
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
If you still have warranty you should probably use it
Celery GT-5 is offline   Reply With Quote
Old 03-23-2013, 02:50 PM   #2778
Only1Wrx
Member#: 300799
2011 Impreza WRX
Blue Pearl MR
But the thing is I can't replicate that situation.. Doesn't it matter? I mean, will they just blow me off?
Old 03-23-2013, 04:04 PM   #2779
_davin
Member#: 260501
2003 miata SE
Blurple
Honestly from what you're describing it doesn't sound to me like there is a problem, just hold the key down for a second the first time until it starts. I could be misunderstanding though.
_davin is offline   Reply With Quote
Old 03-23-2013, 04:18 PM   #2780
Only1Wrx
Member#: 300799
2011 Impreza WRX
Blue Pearl MR
Yeah I guess. I'll see if it acts up on me more frequently before I take it in. Anyhow, I'm excited now that I used my tax money for the last payment! I can now get some goodies for it! I'll Probably get an access port and the Invidia down pipe so I can take it to stage 2!
Old 03-23-2013, 04:23 PM   #2781
mcuzzin
Member#: 292732
2007 FXT
SGM
So I see all these dudes in the picture thread blacking out their headlights leaving NO reflective features. Does anyone have a comparison of light emission compared to stock housing(either 2011 or 2012+)?
I can't imagine it's worth looking "cool" to lose nighttime visibility. But I can't talk smack without data
mcuzzin is offline   Reply With Quote
Old 03-23-2013, 04:42 PM   #2782
Celery GT-5
Member#: 98210
2002 WRX SRP
Yeah they will blow you off if you can't replicate the issue although it wouldn't hurt to tell them about it before your warranty ends in case it gets worse later they might fix it for you if there was a complaint on file. Probably not though
Old 03-23-2013, 08:30 PM   #2783
_davin
Member#: 260501
2003 miata SE
Blurple
I recommend looking into Nameless performance, best downpipe design I've ever seen.
mcuzzin, it shouldn't effect the projectors but the high beams will be useless, from what I understand.
Old 03-23-2013, 09:36 PM   #2784
Only1Wrx
Member#: 300799
2011 Impreza WRX
Blue Pearl MR
Davin, yeah I have their muffler delete but only reason why I would do Invidia is cuz the access port has an "off the shelf" map for it. Otherwise I'd have to get the ap, nameless dp, and a custom tune for it. Don't really want to spend the $$ for the custom tune just yet for just a dp. Any thoughts?
Old 03-23-2013, 09:42 PM   #2785
Celery GT-5
Member#: 98210
2002 WRX SRP
you can use ots tunes with any dp
also I always have to mention open source torqued performance ots tune + tactrix cable ftw
Old 03-23-2013, 10:30 PM   #2786
_davin
Member#: 260501
2003 miata SE
Blurple
^ Yeah, they might make slightly different power levels from a protune, but it won't matter with an ots map.
Old 03-24-2013, 01:44 PM   #2787
tcoffin014
Member#: 173734
Sexy White Princess
Yeah I ran a stage 2 ots map with my custom hacked up downpipe lol and it never gave me any problems. Now I have a tp tune with ebcs and it's pretty awesome
tcoffin014 is offline   Reply With Quote
Old 03-24-2013, 04:54 PM   #2788
Celery GT-5
Member#: 98210
2002 WRX SRP
Not sure why Cobb says you should have a cat an Eric(torqued performance) says it doesn't matter
Old 03-24-2013, 05:09 PM   #2789
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
No it doesn't matter, but over boosting with catless is more common.
Louie is offline   Reply With Quote
Old 03-24-2013, 05:11 PM   #2790
SWP is Sexy
Member#: 302389
I'm a stormtrooper pewpew
Because according to emissions regs you have to. For an OTS tune having the cat does make some difference, I stuck with a catted dp for that reason. Erics maps are set to allow for catless while Cobb's are specifically designed to have a cat
SWP is Sexy is offline   Reply With Quote
Old 03-24-2013, 05:22 PM   #2791
Celery GT-5
Member#: 98210
2002 WRX SRP
i haven't really seen any overboosting but I do have a stock midpipe and a 2.5-2.75" muffler so that might be holding it back some
Old 03-24-2013, 05:27 PM   #2792
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I don't think cobbs maps using cats has anything to do with emission regs. I recall seeing for offroad use only in my manual or someplace associated with my ap.
I haven't seen any over boosting either in my 11 but I did on my 07....all the time. So I protuned.
Old 03-24-2013, 05:34 PM   #2793
Celery GT-5
Member#: 98210
2002 WRX SRP
from what I've read overboosting/boost creep is a physical issue with the exhaust, wastegate and turbo, not a tuning issue
I still haven't really had a concrete answer about why if I go much past 10ish psi at low revs in 4th or 5th gear I get like some sort of vibration. I'm surprised more people don't have that issue or complain about it
Old 03-24-2013, 05:38 PM   #2794
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Tuning sets the waste gate duty cycle. If I'm not mistaken, you set the cycle to open too early you build too late and miss. You set the cycle too late youboverboost.
Obviously there are other details... I'm just understanding from cliff notes
Old 03-24-2013, 05:47 PM   #2795
Celery GT-5
Member#: 98210
2002 WRX SRP
it does but overboosting is from the wastegate not being able to move enough exhaust out fast enough which causes the boost to rise higher than you want it to. You can tune around it to a point but the only real solutions are running less boost or getting a higher flowing wastegate.
Old 03-24-2013, 05:50 PM   #2796
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I agree with what your saying. But how it applies to the Cobb ap and the early stage 2 subies. It's tunable, I think (I'm told)
Old 03-24-2013, 05:53 PM   #2797
Celery GT-5
Member#: 98210
2002 WRX SRP
bull**** ******* no one likes the TUNAble here
oh that was bad
i think its only tunable to a point...that's what eric said anyway
Old 03-24-2013, 07:49 PM   #2798
PearlRex11
Member#: 284420
2011 WRX Sedan
I've heard the grimmspeed ebcs makes it possible to tune out boost creep if you are catless. Catless+hi flow tmic = porting turbo or external wastegate though.
PearlRex11 is offline   Reply With Quote
Old 03-24-2013, 08:19 PM   #2799
Celery GT-5
Member#: 98210
2002 WRX SRP
pretty sure that doesn't stop creep either, just gives you more precise control over boost to start with
http://www.grimmspeed.com/catalog/pr...roducts_id=145
it might make it easier to tune but once the load gets too high its still a wastegate issue
Old 03-24-2013, 09:11 PM   #2800
_davin
Member#: 260501
2003 miata SE
Blurple
I hope not, I'm about to order a Mach V EBCS and install my AVO TMIC and Perrin turbo inlet...
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
