Old 03-15-2013, 03:27 AM   #1851
Kermatt
Member#: 350148
Originally Posted by bue car View Post
Glad I could direct you here. Check out my photo bucket album for a ton of ej1.8 build pics, maybe you can find what you need for the lines in there.
http://s146.photobucket.com/albums/r.../95%20Impreza/
You da mann. Cool build. Any idea what page motor pix would be on? I went thru the first 4-5, but lots of stuff there.
Also, is the 8mm Phenolic spacer enough to clear the ALT?
And what do you think about shortening the harlines under the intake to clear the coolanit manifold bolts?
What should I do with my brake booster out?
Kermatt is offline   Reply With Quote
Old 03-19-2013, 04:00 AM   #1852
Kermatt
Member#: 350148
Anyone?^^ (crickets chirping)
Old 03-19-2013, 07:16 PM   #1853
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
8mm spacers clear the alt in pretty much all applications. I dont know what your talking about with hardlines.
I dont know what you want to know about your brake booster.
Old 03-19-2013, 08:14 PM   #1854
MrSlowbaru
Member#: 129231
2005 wrx
cgm
Here is one I did for a good friend of mine
MrSlowbaru is offline   Reply With Quote
Old 03-19-2013, 11:20 PM   #1855
scby rex
Member#: 104878
02 wrxbastardchild
wow, you had to cut the crap out of the hood. Cool to see another reversed 2.5i manifold.
Old 03-20-2013, 04:21 AM   #1856
Kermatt
Member#: 350148
The hardlines attached to under side of manifold...i should be able to cut back at least the one that impairs the coolant manifold bolt and use a hose on it, right?
Im not using my brake booster, what do I do with the brake booster out? Check valve? cap it?
Old 03-20-2013, 08:12 AM   #1857
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
99% of the people doing reverse manifolds are already past the point of upgrading from the stock fuel lines.
Old 03-20-2013, 09:29 PM   #1858
scby rex
Member#: 104878
02 wrxbastardchild
yeah, upgrade the fuel rails, or figure out how to make them work. All the vaccum crap you dont need would need to be cut and welded shut or capped off.
Old 03-22-2013, 04:54 PM   #1859
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Updated pic of the bay. Now just need to powder coat those pipes.
Old 03-22-2013, 05:11 PM   #1860
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
yay hawk eyes!
bue car is offline   Reply With Quote
Old 03-25-2013, 01:56 PM   #1861
Swifty504
Member#: 342656
06 Subaru AW STI
F-R TS EFR 8374 IWG
Anyone know if the P and L reversed intercooler set up will clear ac if I get a spacer kit.
Thanks,
Jordan
Swifty504 is offline   Reply With Quote
Old 03-25-2013, 02:25 PM   #1862
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Thanks,
Jordan
I bet P and L know
Old 03-25-2013, 05:11 PM   #1863
scby rex
Member#: 104878
02 wrxbastardchild
Why is your Iat on the hot pipe?^^
Old 03-25-2013, 05:42 PM   #1864
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Its not. That's so I can log compressor outlet temp to calculate IC efficiency. The IAT is mounted in the intake manifold.
Old 03-25-2013, 08:59 PM   #1865
scby rex
Member#: 104878
02 wrxbastardchild
ah, ok.
Old 03-26-2013, 09:48 AM   #1866
TickTack
Member#: 100353
Just wanted to bump this post. I decided to go ahead and make another batch of these because a handful of you have requested them. Shoot me a PM if you want one from this batch. I'm making 10 and 4 are spoken for. $35 shipped.
Originally Posted by TickTack View Post
Got my throttle body spacer back from waterjet today. I ended up having five made. If anyone wants one of the extras, let me know and we can work something out. (update: sold them all, if you still want one, let me know, maybe I'll have a few more made)
TickTack is offline   Reply With Quote
Old 03-26-2013, 11:58 AM   #1867
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
I got one last time to put away for later, simple yet quality. Appreciated!
Old 03-27-2013, 08:38 AM   #1868
TickTack
Member#: 100353
Good stuff! Only have a few left unclaimed already. Maybe I should make a bigger batch.
Old 03-27-2013, 10:30 PM   #1869
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Has any one tried using the intake manifold from the BRZ yet? Will it even work?
Badmunky is offline   Reply With Quote
Old 03-28-2013, 11:08 AM   #1870
MrSlowbaru
Member#: 129231
2005 wrx
cgm
Prob not being that the brz is a direct injection motor
Old 03-28-2013, 01:28 PM   #1871
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Direct injection and port injection but the injectors wouldn't be in the intake manifold anyway would they. Our injectors aren't in the intake manifold they're in the TGV housing.
Old 03-28-2013, 01:32 PM   #1872
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Unless you have a JDM manifold
Or some 2.2L ones
Old 03-28-2013, 03:41 PM   #1873
25rsti
Member#: 166324
2.5i intake manifold is the best.
Old 03-28-2013, 10:57 PM   #1874
scby rex
Member#: 104878
02 wrxbastardchild
Since the heads and everything about the brz engine is different I doubt anything will crossover.
Old 03-30-2013, 03:57 PM   #1875
funk32
Member#: 245787
2004 STi
here is my test fitting
IMG-20130304-00047 by Funk32, on Flickr
funk32 is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
