Old 03-24-2013, 08:03 PM   #1
06BlueDemonSTi
Member#: 285897
2006 STi
Default aftermarket radiator with air intake duct
I have a Koyo Radiator and I took off the intake duct, now I was wondering if it's possible to put it back on with out melting it? Would I have to put some sort of Heat reflective tape or wrap?
06BlueDemonSTi is offline   Reply With Quote
Old 03-24-2013, 09:40 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Many people run it as is without issue, why would you?
Old 03-24-2013, 09:43 PM   #3
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
How hot do you think the radiator gets?
Psychoreo is online now   Reply With Quote
Old 03-25-2013, 11:13 AM   #4
06BlueDemonSTi
Member#: 285897
2006 STi
Have you ever touched a aftermarket radiator after warming up?
Old 03-25-2013, 12:02 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Not hot enough to melt the intake brotato.
Old 03-25-2013, 12:19 PM   #6
Psychoreo
Member#: 79643
2015 WRX STI
Have you ever touched a stock radiator after warming up?
Old 03-25-2013, 03:43 PM   #7
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
The oem one is plastic on top. The koyo is all alum thay getts much more hot on top then the oem plastic one.
BlackFighter is offline   Reply With Quote
Old 03-25-2013, 04:06 PM   #8
Psychoreo
Member#: 79643
2015 WRX STI
Originally Posted by BlackFighter View Post
The oem one is plastic on top. The toyo is all alum thay getts much more hot on top then the oem plastic one.
The liquid on the inside is can only get so hot. And is MUCH cooler than the melting point of plastic.
Your point is moot.
Old 03-25-2013, 04:21 PM   #9
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
All silly internet bickering aside. Yes , you will be fine.
gutie04 is offline   Reply With Quote
Old 03-25-2013, 06:45 PM   #10
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
It doesn't get any hotter than the plastic end tanks but since aluminum transfers heat faster than plastic it also transfers heat faster to your hands when you touch it giving you the impression that it at a higher temperature. It is not.
Do not confuse temperature with heat and/or the transfer of heat. They are different.
Old 03-25-2013, 09:48 PM   #11
06BlueDemonSTi
Member#: 285897
2006 STi
Just asking because I've seen people heat wrap there whole air intake duct... I don't just want to throw it on drive around and start smelling melted plastic
Old 03-25-2013, 10:34 PM   #12
the reson they did that wasnt to keep the plastic from melting...and wrapping plastic parts of the intake was a waste of time, anyway
