Old 03-25-2013, 06:05 PM   #1
03wrxBC
Member#: 337930
Default 2003 wrx datalog AF learning 1 high negatives??
i was doing some datlogs and i noticed the my af learning 1 is in the hight negatives up untill about 3500 rpm is this a boost leak?
any help or input would be great.
thanks guys!!
https://docs.google.com/spreadsheet/...3c&output=html
https://docs.google.com/spreadsheet/...lE&output=html
03wrxBC is offline   Reply With Quote
Old 03-25-2013, 06:09 PM   #2
03wrxBC
Member#: 337930
sorry i forgot to mention its a 2003 wrx with a cobb stage 2 91 oct ots map
only mods are 3" cobb turbo back exhaust and a cobb short ram intake.
Old 03-25-2013, 06:53 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
ecu is trying to take fuel away to achieve target afr..
Old 03-25-2013, 07:27 PM   #4
03wrxBC
Member#: 337930
comparing other peoples logs to mine. I could not find any with af Learning 1 numbers like mine. Is it something to worrie about?
Old 03-25-2013, 08:18 PM   #5
neurosis05
Member#: 230265
2005 WRX stage II
Sorry to switch gears on ya but I did some logs for AF sensor 1 Ratio and imported into a spreadsheet and the layout looks wrong, everything is lumped together. Did I import this into the spreadsheet wrong? Here's a link to my thread. 3rd comment down. Thanks
http://forums.nasioc.com/forums/show....php?t=2484597
neurosis05 is offline   Reply With Quote
