Old 10-28-2006, 11:46 AM   #1
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Default alternator relocation
so i am trying to figure out how to mount the alternator where the
A/C compressor used to be.
it looks like you could modify the one bracket a little bit where the long bolt that the alternator pivots on. and if that was groyund down a little bit you could flop the alternator over to tthe other side, but then you would need to have another bracket to secure the other end of the alternaotr and adjust the belt tension.
any tips on that other bracket? is there an existing bracket that one could use?
AsphaltsCry is offline   Reply With Quote
Old 10-28-2006, 12:35 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
I don't think any other subby engines had the alternator mounted over there. So i'd guess you'd have to fab up a bracket for it.
subbyspeed is offline   Reply With Quote
Old 10-28-2006, 01:18 PM   #3
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I just did this last weekend. You need a welder, hack saw, and a grinder.
The braket that you flip the alternator over has to be modified. The top of it has to be cut down so the alt can flip.
i had a spare EJ18, so i used an idler pulley from the timing belt. and a tensioner from that motor as well. i made the bracket for the tensioner from other old spare brackets and piston wrist pins. haha
RS_to_WRX_swap is offline   Reply With Quote
Old 10-28-2006, 01:55 PM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Thats pretty nifty! ^^
Old 10-28-2006, 03:16 PM   #5
oldhat
Member#: 113036
That's awesome. Any benefits other than it looking really cool?
oldhat is offline   Reply With Quote
Old 10-28-2006, 03:19 PM   #6
pinter
Member#: 86472
1998 2.5RS, 2x 1995
Impreza Coupe
If you flip the intake mani around you eliminate a foot or two of intercooler piping.
RS_to_WRX how come you haven't flipped it? I thought that was the whole point of moving the alternator over.
pinter is offline   Reply With Quote
Old 10-28-2006, 03:58 PM   #7
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
what bracket did you use for the alternator tensioner?
Old 10-28-2006, 07:47 PM   #8
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Zero benefit. i bet i lost power adding the idler pulley, but oh well, no ac belt. Now i'm just one step closer to flipping the manifold.
Did you notice i said i just did this last weekend? Don't worry, it will happen in time. My car is a daily driver so i'm doing it in steps to avoid down time.
The tensioner was from the AC unit i think. i had to cut the bottom off it, and modify the top a lot.
Next i'm moving the reservoir.
Old 10-28-2006, 08:16 PM   #9
oldhat
Member#: 113036
Ah, FMIC, I see.
Old 03-26-2013, 09:14 AM   #10
snake32
Member#: 167338
02 Silver dollar
Rs_to_Wrx_swap
I envy your non abs engine bay! damm thing is always in my business!
snake32 is offline   Reply With Quote
Alternator Relocation Bracket for Reversed Manifold Setup. $85<<--SOLDSOLD bicanek Engine/Power/Exhaust 5 10-14-2013 12:00 PM
Alternator, Alternator, Alternator ShadowIMg Car Audio, Video & Security 18 06-01-2013 02:11 AM
Relationship between alternator whine, voltage, and alternator health caterpill Electrical & Lighting 2 01-16-2005 06:15 AM
Music: Is there an alternative to the alternative?? O2-GGA Off-Topic 20 02-05-2004 07:27 PM
