Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 03-26-2013, 01:50 PM   #26
Kinjirra
Member#: 258345
2013 WRX
Plasma Blue
Originally Posted by jm02466 View Post
I'm confused. You removed one of the two parts that people are telling you could fix your issue and instead of removing the intake as well, you decide your only option it to add an EWG? Why aren't you trying the stock air box instead of throwing more mods at it?
Maybe he likes the sound
To the OP since it doesnt sound like your having the creep issue(boost keeps going up) and your only spiking then maybe a tune specific to your car will help you out IE a protune. Personally I would try the airbox fix just too see what happens.
If your going protune might as well add a pile of parts to maximize the gains and cost you will see with a protune.
Best of luck to ya
Kinjirra is offline   Reply With Quote
Old 03-26-2013, 03:53 PM   #27
jpatt006
Member#: 289470
2010 Forester XT
Downshift....
There is no reason to be going WOT in 4th or 5th from a low RPM.
jpatt006 is offline   Reply With Quote
Old 03-26-2013, 03:56 PM   #28
tec_41
Member#: 346278
04 WRX
I would just find a stock intake man...I found a whole setup on here for $50 shipped. Fixed my issues!
tec_41 is offline   Reply With Quote
Old 03-26-2013, 08:30 PM   #29
09rexrunner
Member#: 293955
I'm on my phone so I can't see OP profile but I'm assuming by the username we're talking about a 13 wrx. Just curious how much you paid for a brand new car with no warranty? You don't have to answer that.
On topic though, have you had cel come on or hit fuel cut during your overboost? Do you have the stock air box?
09rexrunner is offline   Reply With Quote
Old 03-26-2013, 08:41 PM   #30
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
I have my warranty still thank u though. I have the cobb intake and cobb air box
20satinwhitebeast13 is offline   Reply With Quote
Old 03-26-2013, 08:44 PM   #31
sc00by4life
Member#: 97135
yeah you do...everything minus the power train .
Old 03-26-2013, 09:19 PM   #32
09rexrunner
Member#: 293955
Take it the dealership then I'm sure they'll fix it. Why not use that warranty you don't have. Sorry to sidetrack your thread I don't mean to be an ass. FWIW, I have an 09 wrx with catless Invidia TBE, stock intake and I have the same problem. I think I remember reading somewhere on here that Eric from TP had boost creep issues with Invidia DPs. I don't remember any of the details though.
Old 03-26-2013, 09:52 PM   #33
sc00by4life
Member#: 97135
This is the major problem with threads like this.
OP is concerned with OVERBOOSTING, which is NOT the same as boost creep.
Unless OP is experiencing boost creep (highly unlikely) and is mistaking it for overboosting.
we need clarification.
Old 03-27-2013, 12:25 AM   #34
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Only three ways to solve this issue male it simple front mount inter cooler or ewg up pipe or remove after market parts
Old 03-27-2013, 07:32 AM   #35
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
The best way to "solve" this problem, call Cobb SoCal and take your car to them.
Old 03-27-2013, 10:10 AM   #36
GrumpyPitbull
Member#: 313311
Correct.
The issue with this whole thread is the OP is data logging wrong, and doing his pulls in the wrong gear. So, the little information that is provided is worthless.
It's comical, the OP has a basic stage 2 set up, and we got guys telling him to bolt on an EWG because he is 1-2 psi overboosting.
I guess the bottom line here is if the OP cannot even datalog his car correctly, then he should take Hinshaw's advice and take it to Cobb.
Old 03-29-2013, 01:03 AM   #37
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Great news just took out the cobb intake and box and of course bam my stage 2 is fantastic now that intake was nothing but trouble
Old 03-29-2013, 07:19 PM   #38
StiSled
Member#: 351808
^^^^^ word
StiSled is offline   Reply With Quote
Old 03-29-2013, 10:40 PM   #39
GrumpyPitbull
Member#: 313311
Good deal man, glad you got it figured out.
Old 03-30-2013, 03:01 PM   #40
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Here's a question are u required to have the box with the aftermarket I take ?
Old 03-31-2013, 04:38 AM   #41
GrumpyPitbull
Member#: 313311
Not required ... but highly recommended.
Old 03-31-2013, 11:48 AM   #42
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
What's the use of the box and the aem filter doesn't have one so is the amount of air each one build up different
Old 03-31-2013, 12:58 PM   #43
jpatt006
Member#: 289470
2010 Forester XT
The box acts as a heat shield (although a rather poor one). It's definitely a good idea to have.
The AEM doesnt have one because its a cold air intake and the piping routes the filter into your fender.
Old 03-31-2013, 01:08 PM   #44
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
So do they both do the same thing and make same sounds ?
Old 03-31-2013, 02:23 PM   #45
tom312
Member#: 261936
2006 WRX STi
get an ebcs and a tune. enjoy the extra power and be more reliable.. I'd recommend going stage 2 at least to get your moneys worth out of the tune
tom312 is offline   Reply With Quote
Old 03-31-2013, 02:58 PM   #46
GrumpyPitbull
Member#: 313311
As stated, the box is a heat shield. Also, the AEM does have a heat shield that seals it off from the engine heat.
They both perform similarly .. the AEM just sits further away.
Not sure why your even still bringing this up, weren't you overboosting with an intake? If the Cobb overboosted on your car, then the AEM will likely also overboost.
Just stick with the stock box.
Old 03-31-2013, 04:17 PM   #47
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Just trying to find ways to make it work before I actually get rid of it
Old 03-31-2013, 04:28 PM   #48
GrumpyPitbull
Member#: 313311
The way to make it work was stated by tom312 in post #45.
A 3 port EBCS, and protune would do the trick. The only question becomes whether having that airbox sucking sound is worth about $650 extra dollars to you or not.
I have the Cobb SF with box,and it has worked fine for me, but if I had your issues I would pull it off in a second and return to the stock box. Heck, I often consider returning to the stock box anyways ... the noisy intake is getting annoying.
Old 03-31-2013, 04:38 PM   #49
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
It's not so much the noise it's the pull it gives that scond and third they pull harder than the average stage 2
