Old 03-25-2013, 01:34 PM   #1
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
Default Cannot get front endlink bolts off!!
So I am trying to replace my front endlinks and swaybars but the bolts are so rusted I cannot get them off and the hex key part is also not useful because it is so rusted.
I tried to use channel locks and that didn't work so I cut them with an angle grinder only to find out there is a washer between the endlink and the control arm. Does anyone have any ideas?
Also I knicked the control arm with the angle grider. This shouldn't cause any structural problems will it?
Fast responses are appreciated!
Imprezaspeed07 is offline   Reply With Quote
Old 03-25-2013, 02:05 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
finish cutting them or cut the nut off.
pic needed of control arm.
Old 03-25-2013, 03:39 PM   #3
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
Ok I'll take a pic of it when I get at it again tonight. Also How can I cut the nut because there is no clearance between the nut and the control arm thus making and even higher probability of damaging the control arm.
Also with a reciprocating saw work better than an angle grinder?
Thanks for the responses in advance
Old 03-25-2013, 04:11 PM   #4
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Try a dremel with a tungsten carbide cutter bit like
this one.this one.
Much easier to get into tighter areas with, It's gotten me out of more than one pinch with seized/stripped nuts.
T-37 is online now   Reply With Quote
Old 03-25-2013, 06:14 PM   #5
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Spray it with PB blaster for several days, then heat the nut with a blowtorch till it is literally red hot, then use an impact wrench.
Suba_Roo is offline   Reply With Quote
Old 03-26-2013, 01:34 AM   #6
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
I ended up grinding off the washer... Took some of the control arm with it. Will these catastrophically fail on me? Will post pics tomorrow
Old 03-26-2013, 10:53 AM   #7
Dakota D
Member#: 293894
2011 wrx sti
world rally blue
we wont know until we have pics
Dakota D is offline   Reply With Quote
Old 03-26-2013, 12:27 PM   #8
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Probably so but without the pics we won't know for sure.
2010SubieFoz is offline   Reply With Quote
Old 03-26-2013, 12:38 PM   #9
SW21MR2
Member#: 60135
2005 Kona Stink-E
SW21MR2 is offline   Reply With Quote
Old 03-26-2013, 01:21 PM   #10
teiva-boy
Member#: 22825
Needs some TLC and POR15...
teiva-boy is offline   Reply With Quote
Old 03-26-2013, 03:06 PM   #11
Daemione
Member#: 13169
2004 Forester XT
I've had to cut off my fair share of end link bolts . . . those hex openings are useless. Much prefer using a dremel over an angle grinder, though. Some heavy duty cutting discs make short work of stubborn nuts, with a lot smaller chance of collateral damage.
Daemione is offline   Reply With Quote
Old 03-26-2013, 04:01 PM   #12
Nuckenfutz
Member#: 304210
2007 STi
I had this issue with the 17mm bolt holding the strut to the control arm this weekend. I tried everything, including bathing it in pb blaster and roasting it with a blow torch. By the time I did that the nut was so stripped there was no other option but to cut it off. I too caught a little bit of the control arm with the cutting wheel, but it just looks like a deep scratch.
Nuckenfutz is offline   Reply With Quote
Old 03-26-2013, 10:00 PM   #13
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
So I think I may have messed up. I got a good bit of the control arm on one side.... It looks like I may be getting an upgrade haha. Let me know what you think I'm going to have it looked at on thursday.
https://docs.google.com/file/d/0B-4z...it?usp=sharing
Old 03-26-2013, 11:29 PM   #14
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
Also does anyone know what my options are for new control arms.... I think I may just replace these. I would rather be safe than sorry or end up having a failed control arm that leads to an accident. Is there a possibility of that happening?
Also how how is it to install a control arm or should I just get it done by a shop?
Old 03-26-2013, 11:31 PM   #15
d000000000000000d...yew need to put the tools down and step away from the car
Old 03-27-2013, 12:00 AM   #16
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
yeah I realized that... live and learn I guess haha
Old 03-27-2013, 03:08 AM   #17
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
One of the lessons I learned when trying to remove a bushing sleeve recently was that you don't necessarily cut all the way through the metal to remove it. If you cut the metal most of the way thru, it can be thin enough that you can then shear the remainder without damaging the piece to remain. This would probably work better for the endlink bolts if you altered your angle. You don't have to cut perpendicular to the axis of the bolt. Think cutting a tree with an axe vs. a saw.
Also, I just removed the FCA and replaced the bushings on our '02 bugeye, and didn't think it was incredibly difficult to reinstall them. Removing a couple of the mounting bolts required a 2' breaker + 2' extension and the bushings were a challenge til I learned the lesson above. That being said, Cali cars don't have nearly as much rust as the rest of you all (even after 12 yrs), and I'm having it towed to the shop for a full alignment and torque check on all the bolts as soon as the last parts go on.
dagger108 is offline   Reply With Quote
Old 03-27-2013, 03:23 AM   #18
man....if you were local to me...id wrench yer car for ya...show ya what's up with it
id even get ya decent links for cheap
Old 03-27-2013, 07:39 AM   #19
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
Do I need an alignment done after doing front sway bars?
Old 03-27-2013, 10:40 AM   #20
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Nope.
Old 03-27-2013, 11:56 AM   #21
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
You should install my 27mm front sway on my bugeye
Old 03-27-2013, 04:55 PM   #22
that would be a real stupid thing to do
27mm is WAY too big....that's your first problem
Old 03-27-2013, 05:09 PM   #23
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Along with full coil setup... doubt it. Recommended by Dan and the Andrewtech guys. I've been for a ride along in Dan's car...seems he knows what he is talking about
Old 03-28-2013, 08:49 PM   #24
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
So what does everyone think about the control arms? do the sway bars create that much force? That I should think about replacing these?
Old 03-28-2013, 11:39 PM   #25
driving a race car on the street is NEVER a good idea
using race car parts on a street car is NEVER a good idea
suspension by swaybar is NEVER a good idea
anybody recommends a 27mm front bar on a gd chassis for the street is an idiot....WAY too much bar
