Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 03-04-2013, 03:16 PM   #1
REECERS
Member#: 259958
Default 90 degree inlet
K so I found that my stock intake piping has a few holes and rips in it, was wondering if anyone has found a good way to either make your own or get a good aftermarket setup. The car will see rally duty and I feel that with mechanics crazily pulling this stuff out of the way at times i don't want the stock setup as it seems to be easily torn. I have searched a few different places with no luck but to find a 400 dollar setup
REECERS is offline   Reply With Quote
Old 03-07-2013, 08:50 PM   #2
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I replaced the plastic intake elbow with some silicon hose
sizzflair is offline   Reply With Quote
Old 03-08-2013, 09:25 PM   #3
CRX7
Member#: 31639
99 Impreza
I fixed mine with epoxy, but I've got a custom silicone setup almost ready to go in.
CRX7 is offline   Reply With Quote
Old 03-08-2013, 10:54 PM   #4
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
Samco makes(or at least they used to) one but they are not cheap, back when I bought one it was around $200. I know RallySport Direct used to sell them, they are a vender on here.
spackyscooby is offline   Reply With Quote
Old 03-08-2013, 10:55 PM   #5
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
i run the samco turbo inlet. it is a nice piece. i have had it on for almost 5 years now and it has held up great
07VTRex is offline   Reply With Quote
Old 03-09-2013, 12:36 PM   #6
REECERS
Member#: 259958
that samco piece is 400 bucks now
Old 03-11-2013, 03:08 AM   #7
CRX7
Member#: 31639
99 Impreza
This was my old intake pipe, which I was getting major leakage from:
This is the current mockup for my custom intake:
I'm in the process of attaching the vacuum hoses to my 3inch exhaust pipe you see in the middle. The other silicone hoses are available on ebay for cheap simply measure your turbo inlet and order.
Old 03-11-2013, 11:03 AM   #8
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
Check out martimus919s write up on bbs: http://bbs.legacycentral.org/viewtopic.php?f=1&t=49555
His set up is really nice and he lists all the parts he used.
monkeyposeur is offline   Reply With Quote
Old 03-24-2013, 04:47 AM   #9
jdmwrx94
Member#: 211619
94 jdm wrx
red
using a usdm legacy turbo,it's for td05 tho, donno if it the same diameter the nipples are almost the same, had to work them out just a bit. worth someting like 45$ can
jdmwrx94 is offline   Reply With Quote
Old 03-25-2013, 09:13 PM   #10
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
Mine was cracked too, and I used "Rescue Tape" on it, and is is holding up fine
Tizzle is offline   Reply With Quote
Old 03-26-2013, 09:32 PM   #11
The-Stig
Member#: 188944
1999 92' Legacy SS
Black Pearl
I would actually like to know what intercooler you are using? I was mocking up something similar to your inlet setup when I noticed it.
The-Stig is offline   Reply With Quote
Old 03-27-2013, 12:36 AM   #12
CRX7
Member#: 31639
99 Impreza
It is an 02 WRX Intercooler. Do NOT use this intercooler. It took me forever to modify it to fit. It has been constantly hitting my firewall, and now that I've finally got it so it doesn't knock... It's got a leak. I think I was manhandling it a bit too much to get it out the other weekend to install my STI pitchstop, and now it's leaking.
I'm going FMIC, ordered the CX Racing kit, hopefully I can get it put in this weekend and see more than 9 lbs of boost. Oh, BTW, intake worked out great, been working well for 2 weeks now, I'll get pics up soon.
Old 03-27-2013, 12:05 PM   #13
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
Hey CRX7, you will probably run into the same issue with the CX Racing kit as well(edit:just noticed you're going fmic :S). The only intercoolers that fit well on the older na engines are the ones off the 2006 wrx or foresters, all others are too tall and will hit the fire wall. With the 2006 intercooler you have enough room to put on/take off without any issues as you can see below, you can find them for dirt cheap too. I figured I'd chime in since I am also running a custom 90* inlet.
V8Slayer is offline   Reply With Quote
