Old 03-27-2013, 08:20 PM   #1
kdubski
Member#: 251464
2006 Impreza 2.5i
Obsidian Black Pearl
Default JDM ver 2 sti
Local guy is selling a 2.5rs jdm ver 2 swap. I've been considering a swap for quite some time now but at this point all it would take is a trade. Now few things make me iffy. Ver 2 is 1995 motor, how much abuse has this engine seen? No paper work for this pup either. What else should I look for when i check this out and what should give me the green light?? thanks fellas
kdubski is offline   Reply With Quote
Old 03-27-2013, 09:37 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
why are you interested in it? for the nostalgia? the v2 sti factor?
Its an old platform with limitations on tuning support. Even a 205 usdm swap has better tech with the ignition.
if you're set on it, check for fluid leaks, existing CEL codes, ask for compression numbers if possible.
Old 03-27-2013, 10:18 PM   #3
kdubski
Member#: 251464
2006 Impreza 2.5i
It's mainly for affordability. I'm a student and have a salvaged 2.5i that I've had trouble selling so I see this as a potential way into turbo world.
Old 03-27-2013, 11:39 PM   #4
Smity Subaru
Member#: 211714
95 Sti Swapped GC8
Red
i wouldnt suggest buying this and i will tell you why.
1. I have a 95 sti ver 2 engine swap and i havent swapped it my car yet but i now all the in's and outs about because it has been 2 years and im still gathering parts.
2. the 95 sti ver 2 ej20g doesnt have the necessary emissions stuff for obd 2 cars like the 2.5rs's. i dont have to worry cause my swap is going into my 95 obd 1 impreza L.
3. buying a modded car and especially a swapped car can be a money pit. and yes i have seen it
4. you said your a student. best thing to do is get a closes to stock as possible wrx that you can lightly mod or a stock 2.5rs
5. I wouldnt suggest a engine swap let alone a jdm engine swap. there is alot of parts gathering involved.
summary...honestly man that 2.5rs swapped car sounds too good to be true man. all in all its your choice but a 2.5rs with a wrx engine would be a potentially safer buy than a 2.5rs with a jdm engine that is 5 years before its time, especially when you need a state inspection
Smity Subaru is offline   Reply With Quote
