Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 02-15-2013, 06:53 PM   #1
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
Default STI engine in WRX wont start
Hello all! Just installed an EJ257 STI engine into my 2002 WRX. I used the WRX harness and ECU, left the AVCS disconnected, swapped over the 2002 WRX TGV's, intake manifold, and Throttle body.
I have fuel, spark, compression (it's a BRAND NEW, ZERO mile engine), and air.. But the engine wont start. I can use starting fluid and it will start for a second or two, but then will immediately die out. If starting fluid isn't used then it will only turn over.
Any ideas, or advice on what could be wrong..?
scoobynoobEMT is offline   Reply With Quote
Old 02-16-2013, 08:46 PM   #2
scoobynoobEMT
Member#: 199206
84 people looked at this, and noone has any advice..??
Old 02-17-2013, 02:56 PM   #3
scoobynoobEMT
Member#: 199206
Found out what happened. The wires were pulled out of the pinout harness that's right behind the battery.
Old 02-17-2013, 08:27 PM   #4
scoobynoobEMT
Member#: 199206
AP2 shows codes for Misfire on 1 and 3, cam position sensor, heat control circuit bank 1.
Any ideas on what the problem is..?
Old 03-24-2013, 09:48 PM   #5
motoxrider365
Member#: 351283
new here, trying to contribute...
From my reading so far, it doesn't seem you flashed the ECU? So in your case I think you pissed off the WRX ECU (cause it still thinks its a 2.0 its trying to run)
motoxrider365 is offline   Reply With Quote
Old 03-25-2013, 10:26 AM   #6
carnz-pj-410
Member#: 110994
1998 2.5 RS
1995 2.5 RS Clone
the cam position sensor code is why it won't start, 02-05 WRX uses a different style cam position sensor than the STi
carnz-pj-410 is offline   Reply With Quote
Old 03-25-2013, 10:27 AM   #7
scoobynoobEMT
Member#: 199206
The wiring harness was broken, causing the injectors to not have power.
Old 03-25-2013, 10:32 AM   #8
carnz-pj-410
Member#: 110994
1998 2.5 RS
1995 2.5 RS Clone
All good now? if so, good to hear
Old 03-25-2013, 10:57 AM   #9
scoobynoobEMT
Member#: 199206
I'm still trying to diagnose a random misfire from a cold start to 180 degrees coolant temp. Once it's 180 degrees it runs fine.
Old 03-28-2013, 10:55 PM   #10
1BADAZZSUBY
Member#: 351746
problems?
1BADAZZSUBY is offline   Reply With Quote
Old 03-28-2013, 11:00 PM   #11
scoobynoobEMT
Member#: 199206
.. What?
