Old 03-29-2013, 10:55 AM   #2101
SXfour
Member#: 233374
2009 Suzuki SX4
2012 Impreza
Anyone have any leads on lowering springs/coilovers for the '12+? I keep hoping that one day, something will materialize ... but so far, nada.
rob
SXfour is offline   Reply With Quote
Old 03-29-2013, 11:09 AM   #2102
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I like ground clearance
Old 03-29-2013, 12:27 PM   #2103
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Not sure about springs, people keep asking about them but no one has anything apparently.
Old 03-29-2013, 12:54 PM   #2104
ltapawan
Member#: 318332
2012 Impreza 5-Door
1981 Corolla Wagon
i saw a posting here somewhere about H&R springs being released for our cars sometime in the summer.
i don't want to lower my car too low, but i would like to lower it an inch and to have a sportier ride.
ltapawan is offline   Reply With Quote
Old 03-29-2013, 02:31 PM   #2105
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
19mm STI RSB
For those that installed it, did you just use the nuts and bolts that is currently used on your current impreza rsb? or did you get a new set?
Wes_888 is offline   Reply With Quote
Old 03-29-2013, 03:09 PM   #2106
Chris223
Member#: 308299
2012 Impreza Premium
Dark Grey Metallic
This has probably already been answered in here but a quick question guys. I have ordered the perrin perf front stb for my Impreza sedan and plan to order soon the 19mm rear sway from perrin also. I understand you should upgrade the endlinks when you do this as well wheres the best place to get these? And to keep a proper oversteer/understeer balance should I also upgrade the front sway? What if I went with the 22mm or is the 19mm plenty? If I should upgrade the front I've read the wrx ones don't work what other subie models will one work from that will be an upgrade if this is even necessary. Thanks guys
Chris223 is offline   Reply With Quote
Old 03-29-2013, 03:12 PM   #2107
Chris223
Member#: 308299
Dark Grey Metallic
I would absolutely love to lower about an inch myself but this... Lol. The rear of my car scrapes backing out of my driveway because of the huge lip my driveway has at stock height. No lowering for me.
Old 03-29-2013, 05:38 PM   #2108
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I believe most people who go from the stock 16mm RSB to a 19mm RSB continue using the stock endlinks. At least that's true if installing a Subaru 19mm RSB.
Old 03-29-2013, 05:41 PM   #2109
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
this and i have snow to deal with
Old 03-29-2013, 06:47 PM   #2110
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
Yeah I called h&r and they said late spring/early summer. The drop says 1.4"f/1.3"r. I just want a slight drop too. Just to make the gap between the tire and fender smaller.
ronjr8102 is offline   Reply With Quote
Old 03-29-2013, 09:50 PM   #2111
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Still waiting for flapatax to get back to me
subaru222 is offline   Reply With Quote
Old 03-30-2013, 02:01 AM   #2112
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
I don't know about you guys, but i'm probably going to RAISE my car. I'm constantly having problems with ground clearance, especially the front end, to the point where one of the front bumper supporting clips snapped at some point. And no, i don't go offroad or smash into curbs or things like that
Submitted a claim to SOA and I have a service appt next week to check the car.
If they say there's nothing they can do, that 1" kit is being installed
After that 1"/SOA fix i'm gonna get a set of flapatax and tints!
Last edited by danstheman7; 03-30-2013 at 02:17 AM. Reason: is there a reason I can't spell correctly?...
danstheman7 is offline   Reply With Quote
Old 03-30-2013, 01:13 PM   #2113
naru177
Member#: 176844
2012 2.0 Impreza
Default COILOVERS by RSR Best i
Try not to prematurely blow a load
http://item.rakuten.co.jp/auto-craft/rsr_1000/
specs:
Car's name Impreza Sport
Vehicle Type GP7
Model year 23/12 to
Drive system 4WD
Displacement 2000 NA
Recommended height adjustable width (mm)
F -15 To -55
R -5 To -45
Recommended height (mm)
F -30 To -35
R -25 To -30
The maximum adjustment range (mm)
F 0 to -85
R +10 To -75
Spring rate (Kg / mm)
F 5.00
R 4.00
Height adjustment system R Length formula
Now the issue is getting them over to the states
naru177 is offline   Reply With Quote
Old 03-30-2013, 01:39 PM   #2114
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Group buy
Old 03-30-2013, 04:14 PM   #2115
ronjr8102
Member#: 216040
dark metallic grey
Originally Posted by aeoporta View Post
Group buy
Great idea but I really only have money for springs alone. Now I just need to find some, anyone??
Old 03-30-2013, 05:39 PM   #2116
MrLebreen
Member#: 344816
2012 Impreza 2.0i
specs:
Vehicle Type GP7
Model year 23/12 to
Drive system 4WD
F -15 To -55
R -5 To -45
F -30 To -35
R -25 To -30
F 0 to -85
R +10 To -75
F 5.00
R 4.00
Australia bound
MrLebreen is offline   Reply With Quote
Old 03-30-2013, 06:47 PM   #2117
Wes_888
Member#: 320291
How much are these CO's going for?
Old 03-30-2013, 07:09 PM   #2118
Dayekuang123
Member#: 333244
2012 Impreza 2.0i 5d
I am down for group buy.
Dayekuang123 is offline   Reply With Quote
Old 03-30-2013, 07:14 PM   #2119
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Those are nice but I prefer to keep the stock ride height for the snowy winters here.
Old 03-30-2013, 07:48 PM   #2120
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
https://www.subaruonlineparts.com/pr...6569b16e96ec16
Does anybody have one of these that can take a pic for me? I want to see how it looks and whether or not it will work with my Kicket "OEM" sub.
Old 03-31-2013, 01:03 AM   #2121
SXfour
Member#: 233374
2009 Suzuki SX4
2012 Impreza
Looks like $1800 or so based on the exchange rate.
Old 03-31-2013, 10:11 AM   #2122
solistik
Member#: 345948
I remember someone posting this link to BC Racing coilovers, has it been confirmed that they are actually NOT for our model? I was hoping to pick them up after I retrofit my headlamps and fog lights.
solistik is offline   Reply With Quote
Old 03-31-2013, 06:32 PM   #2123
Chris223
Member#: 308299
Dark Grey Metallic
ask and ye shall receive.
Not the greatest pics I just snapped them quick with my iPod touch. I don't know how/if they work with an OEM sub on the side of the trunk. I was worried I would have to take mine out when I put in my sub but surprisingly my box doesn't move at all. It isn't exactly a slippery surface the cargo tray, I did put velcro underneath my box just for added security. But I like the tray. Was already in my car when I bought it. I'm glad I have it. A lot easier to clean than the carpet and when I shove my golf clubs in the trunk along with my shoes it doesn't get the carpet dirty and cleaning means just vacuum and spray a little 303 Protectant on.
Old 03-31-2013, 08:26 PM   #2124
jsteg
Member#: 329271
Ice Silver Metallic
Cool thanks...when ya get a sec, could ya take another shot of the left side like you did the right?
Old 04-01-2013, 02:27 PM   #2125
solistik
Member#: 345948
I called Import Image Racing today and they confirmed that these coilovers are for our model.
