Old 03-26-2013, 08:41 AM   #26
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Car is totaled.
Tkacik is offline   Reply With Quote
Old 03-26-2013, 09:54 AM   #27
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
CarverSnell is offline   Reply With Quote
Old 03-26-2013, 12:12 PM   #28
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
Originally Posted by CarverSnell View Post
What does everybody recommend for touching it up? Touch up paint off Video Link: http://www.amazon.com/gp/aw/d/B007JJXTTE or should I just get Grimmspred PSM spray?
I use http://www.automotivetouchup.com/
SilverBOXER4 is offline   Reply With Quote
Old 03-26-2013, 03:21 PM   #29
fistv
Member#: 350063
2013 Impreza sport
I'd try popping it back out, don't just whack it in the center either, you need to shrink the metal back down, start working the edges first with a body hammer, light taps and a dolly [anvil] from the outside to hit against. You could even pad the dolly with a wash cloth. Just work slow, if it does not work for you nothing lost.
Eastwood makes a stud welder and dent puller for around $250 as does Harbor freight for cheaper, the puller with the harbor freight sucks.
http://www.eastwood.com/stud-welder-...ng-system.html
Since I got my 13 sport I'm getting back into the practice of backing into parking spaces before I take a shopper out.
fistv is offline   Reply With Quote
Old 03-29-2013, 07:18 PM   #30
frequencyflyer
Member#: 351813
you're lucky you have a silver car, wayyy less noticeable than most of the other colors
frequencyflyer is offline   Reply With Quote
Old 03-29-2013, 07:47 PM   #31
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Do we still get to shoot you?
Gallo2011 is offline   Reply With Quote
Old 03-29-2013, 11:30 PM   #32
fenderpicks
Member#: 287694
Pretty hard to get that dent fixed back into place.
Unless ur inclined with wet sanding, ur best bet will be just using some touch up paint....
fenderpicks is offline   Reply With Quote
Old 03-30-2013, 12:02 AM   #33
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
Do it before I do it myself.
Wet sanding can't be THAT hard.
Old 03-30-2013, 12:20 AM   #34
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
How would wet sanding help where paint is missing? Wet sanding it only to fix really deep scratches in the clear coat that even heavy compounds won't fix. Nothing will fix a spot where paint is missing; your only choice would be touch up paint or actually getting it professionally painted.
07STifastashell is offline   Reply With Quote
Old 03-30-2013, 02:07 PM   #35
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
Originally Posted by SilverBOXER4 View Post
Try popping it back out if possible. I believe if you open up the trunk and pull down the right side of the trunk liner. This will give you an opening to use a tool to try paint less dent repair.
+1 for myself, lol. Then you can do some touch up after popping it back out.
Old 03-31-2013, 01:15 AM   #36
TheStepfather
Member#: 319109
2006 Forester XT
My friend just hit a mailbox too!
TheStepfather is offline   Reply With Quote
Old 03-31-2013, 09:15 AM   #37
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
Good lord, that's the whole neighborhood!
