Old 03-26-2013, 11:55 PM   #1
Trizzeb
Member#: 331467
2005 WRX Sti
CGM
Default turbo or wastegate issues???
Forgive me if this has already happened to some one but im having real problems here, i checked around as best as i could oh well...
So heres the deal i have 2005 sti running like 95k miles, i have basically stage 2 full turbo back catless, intake,ap and a greddy type s bypass recirculation if it matters....... I am having boost control issues the cars targeting 17 psi but in first and second i can only hit 11 or 12psi...... 3-6 gear seems to be ok but the higher the rpm the less boost it seems to taper...i know my turbo seals are bad im getting quite a bit of oil in the intercooler but i hear no noises or nothing unusual.... oh and as a side note since the problem occured i have been getting back fire and flames when i get off the gas, i wrote it off as the car is feeding more fuel for the pressure that the turbos not supplying.... i have reflashed the map and tried even going back to stock..... something is wrong idk what
Please help!!
I can datalog the incidents if needed aswell
Trizzeb is offline   Reply With Quote
Old 03-27-2013, 12:22 AM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Please help!!
the pressure sounds normal. You arent going to build up that much boost in first Or second gear.
Old 03-27-2013, 12:35 AM   #3
Trizzeb
Member#: 331467
2005 WRX Sti
CGM
the only thing is before the problem started i was able to hit full boost through all the gears and i was running the same map and everything.... and boost targets are the same through all gears as well, however actual psi is lower
Old 03-27-2013, 08:54 AM   #4
Member#: 301037
2004 Forester XT
Are you running a protune or AP OTS?
art@grimmspeed is offline   Reply With Quote
Old 03-27-2013, 09:00 AM   #5
Trizzeb
Member#: 331467
2005 WRX Sti
CGM
Off the shelf stage 2 on ap
Old 03-27-2013, 10:46 AM   #6
norkkron
Member#: 180679
2005 STI
not sure if relevant, but cobb says not to use catless DPs with their OTS maps
norkkron is offline   Reply With Quote
Old 03-27-2013, 04:51 PM   #7
Andrewxxcarlson
Member#: 316415
2006 WRX
Not relevant.
Andrewxxcarlson is offline   Reply With Quote
Old 03-28-2013, 10:20 AM   #8
henria86
Member#: 303849
2004 Forester Xt
Silver stg2
YUP I'm havin the same problem too cant hit my target boost of 18 lbs only constant 15lbs . cant seem to find the issue. i smoke tested the car n changed all the vacum lines .
it was protuned hitting 18 lbs for 2 weeks then it stopped
thanks
henri
henria86 is offline   Reply With Quote
Old 03-28-2013, 11:35 AM   #9
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
check your wastegate actuator and swap out your bcs with a known working one.
scoobasaurusrex is offline   Reply With Quote
Old 03-28-2013, 12:53 PM   #10
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Manual boost controller, or stock?
The only thing that - bar a fubar'd turbo - is going to inhibit that turbo is the wastegate, and/or an exhaust leak. If you run a line directly from the wastegate actuator to the compressor, you should hit boost fine. I performed this test a while ago, and used it to identify a faulty OEM EBCS. Do NOT floor the car, but it will let you know if it is solely the boost controller that is inhibiting boost, or a pre-turbo exhaust leak.
BeastianSTI is offline   Reply With Quote
Old 03-28-2013, 01:02 PM   #11
Andrewxxcarlson
Member#: 316415
2006 WRX
Guarantee it's your wastegate actuator. Pop the e clip off, DON'T LOSE THIS CLIP IT TENDS TO SPRING OFF SO KEEO YOUR OPPOSITE HAND ON IT, break the 10mm locking nut. One turn at a time clockwise to tighten actuator arm. Put clip back on lock the nut. Go for a drive. If still not maybe one more turn. There's gotta be a certain amount of preload to keep the wastegate closed until target boost.
Then come back and tell me I'm right.
Old 03-28-2013, 01:17 PM   #12
BeastianSTI
Member#: 310506
2005 WRX STi
Originally Posted by Andrewxxcarlson View Post
Guarantee it's your wastegate actuator. Pop the e clip off, break the 10mm locking nut. One turn at a time clockwise to tighten actuator arm. Put clip back on lock the nut. Go for a drive. If still not maybe one more turn. There's gotta be a certain amount of preload to keep the wastegate closed until target boost.
Not sure that he should be adjusting the wastegate arm, rather than the BC if it was hitting boost before, without changing anything.
Old 03-28-2013, 01:21 PM   #13
Andrewxxcarlson
Member#: 316415
2006 WRX
It's a possibility that it is his bcs, but the same thing happened to me, got tuned, hit full boost for a couple weeks, adjusted 2 turns clockwise to add preload on the wastegate. Hit full boost for 6 months after. I then detuned my car, stage 2 OTS, noticed I was now over boosting. Back the wastegate arm 2 turns counterclockwise everything perfect.
Old 03-29-2013, 01:22 PM   #14
Trizzeb
Member#: 331467
2005 WRX Sti
CGM
So preloading the wastegate arm may solve the issue..? Or it could be the bcs? Ill try it today when I get a chance and see if I can find someone with a stock bcs I can see if it works
Old 03-29-2013, 02:10 PM   #15
Andrewxxcarlson
Member#: 316415
2006 WRX
Try the wastegate actuator first, it's easily reversible. Takes me about 7 mins including taking off heat shield.
Old 03-29-2013, 02:14 PM   #16
jbulls93
Member#: 315840
2000 2.5rs
I didn't think the WGA on the VF turbos could be adjusted.
jbulls93 is offline   Reply With Quote
Old 03-29-2013, 02:21 PM   #17
Andrewxxcarlson
Member#: 316415
2006 WRX
Ugh my mistake. Thought td :/ bcs would be good to test now... Lol
Old 03-29-2013, 11:21 PM   #18
icemanftr
Member#: 320444
2012 WRX
Took me 6 mins... Little rusty there Andrew...
icemanftr is offline   Reply With Quote
Old 03-30-2013, 12:04 AM   #19
Andrewxxcarlson
Member#: 316415
2006 WRX
I didn't factor out the time I took to pound the beer...damn you!
Old 03-30-2013, 12:21 AM   #20
icemanftr
Member#: 320444
2012 WRX
I did I pounded one at 2 min mark and 5min mark
Old 03-30-2013, 01:16 AM   #21
Andrewxxcarlson
Member#: 316415
2006 WRX
I'm astonished! Congrats bud! That's impressive! *slow clap*
Old 03-30-2013, 01:24 AM   #22
icemanftr
Member#: 320444
2012 WRX
:-D lol
Old 03-30-2013, 09:43 AM   #23
BeastianSTI
Member#: 310506
2005 WRX STi
Any luck op?
Old 04-01-2013, 08:22 AM   #24
Trizzeb
Member#: 331467
2005 WRX Sti
CGM
Any luck op?
No luck thus far... under advisement from cobb im running the HWG mapp and still cant hit full boost however its much closer...... i am noticing that the wastegate arm has play in it when the cars off dont know if it should be that easy to move....? but other than that its looking more and more like i need bcs everything else checks out
