Old 03-24-2013, 09:16 PM   #2801
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by _davin View Post
I hope not, I'm about to order a Mach V EBCS and install my AVO TMIC and Perrin turbo inlet...
I would definitely take it into consideration. I've seen 2 shops have issues tuning a setup like I mentioned, one of them was Cobb Socal.
PearlRex11 is offline   Reply With Quote
Old 03-24-2013, 09:21 PM   #2802
_davin
Member#: 260501
2003 miata SE
Blurple
Oh well, I guess we'll find out. Worst case scenario I have an excuse to order the downpipe I really wanted.
Actually now that I think about it, it would cost about the same to just get the new EWG setup from Cobb.
_davin is offline   Reply With Quote
Old 03-24-2013, 09:28 PM   #2803
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
lol EWG
Celery GT-5 is offline   Reply With Quote
Old 03-25-2013, 12:35 AM   #2804
tcoffin014
Member#: 173734
Sexy White Princess
I had ebcs, catless dp, cat back exhaust, intake and a high flow intercooler for a while with a tp tune and no problems. I just recently sold the intercooler to get some extra money and everything still works fine. They do have high and low wastegate duty cycle ots maps that I hear usually fix the over boost and under boost issues. I have a friend with the spearco intercooler, ebcs, intake, cat back exhaust running 20 psi on Erics stage 3 map and he's never had a problem with over boosting either except for once when there were 5 people in the car and he got on it in 4th at low revs
tcoffin014 is offline   Reply With Quote
Old 03-25-2013, 01:11 AM   #2805
Celery GT-5
Member#: 98210
2002 WRX SRP
I think the whole problem is blown out of proportion
Old 03-30-2013, 10:03 AM   #2806
tcoffin014
Member#: 173734
Sexy White Princess
Well something is going on with my clutch again. It's starting to make the squeak noise like the firewall welds are breaking. I hope that's not the case. I'm gonna check it out later when I have the time
Old 04-11-2013, 01:34 PM   #2807
Celery GT-5
Member#: 98210
2002 WRX SRP
so has anyone blown the end tanks off their stock tmic?
Old 04-11-2013, 01:41 PM   #2808
SWP is Sexy
Member#: 302389
I'm a stormtrooper pewpew
I got the BP kit preemptively, so not me
SWP is Sexy is offline   Reply With Quote
Old 04-11-2013, 02:39 PM   #2809
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
i got a PW TMIC when i went stage 2, didnt wanna risk it. i did not verify whether or not the plastic endtank myth is a reality
Asharus is offline   Reply With Quote
Old 04-11-2013, 04:01 PM   #2810
SWP is Sexy
Member#: 302389
I can testify that the press-on clips looked like they had been under pressure and starting to pull away when I put the BP kit on, but nothing gave out.
Old 04-11-2013, 04:24 PM   #2811
Celery GT-5
Member#: 98210
2002 WRX SRP
hrm
so I was bored today, put my cobbs SF back on and did some before and after virtual dyno pulls. I did two graphs because it got too crowded and also the pulls were done in 2 different spots
seems to hold a bit more boost up top
I think the IAT was a bit higher with cobb
Old 04-11-2013, 06:40 PM   #2812
_davin
Member#: 260501
2003 miata SE
Blurple
I started having a problem with my e-brake yesterday, or maybe it's not a problem. When I release the lever it feels loose, like the cable is slack and the brake is still engaged. But it doesn't seem to be. After I drive around for awhile it seems to tighten back up, but happens again the next time I use it. When I first noticed it I drove for a bit and then touched the rear rotors and didn't burn myself so hopefully I'm not wearing anything out.
Old 04-12-2013, 01:22 AM   #2813
PearlRex11
Member#: 284420
2011 WRX Sedan
Mine was squeaking really bad at the last inch of the pedal being pushed all the way in. I pushed the pedal in with my hand and squirted white lithium grease inside where the clutch linkage goes through the firewall. Seems to have fixed it now.
Old 04-12-2013, 01:24 AM   #2814
PearlRex11
Member#: 284420
2011 WRX Sedan
I keep telling myself I'm going to buy this. Did you use the zip ties or bolts?
Old 04-12-2013, 01:51 AM   #2815
SWP is Sexy
Member#: 302389
The stainless zip ties, theyre even just an excess measure though. The rails are so tight it took a rubber mallet to get them on all the way lol
Old 04-12-2013, 09:15 AM   #2816
PearlRex11
Member#: 284420
2011 WRX Sedan
Cool, I think it looks cleaner with the zip ties. Thanks
Old 04-12-2013, 10:52 AM   #2817
SWP is Sexy
Member#: 302389
Agreed, if you're not paying attention you wouldn't notice it at all. I forget it's on there sometimes lol
Old 04-12-2013, 11:03 AM   #2818
PearlRex11
Member#: 284420
2011 WRX Sedan
Yeah I want to get it, I do think $90 seems a little steep for the materials in the kit. It does however appear to be a fix for the stock tmic so that would justify the cost Imo.
Old 04-12-2013, 12:20 PM   #2819
tcoffin014
Member#: 173734
Sexy White Princess
I think that's where my problem is too. It stopped doing it the other day and hadn't really come back yet but I'm gonna grease it up if it comes back. Thanks
Old 04-12-2013, 10:24 PM   #2820
SWP is Sexy
Member#: 302389
It is, but if you're planning on just running an ots map it's one of the best options for sure.
Old 04-12-2013, 10:26 PM   #2821
Celery GT-5
Member#: 98210
2002 WRX SRP
can't you just get some metal brackets yourself and bolt them on?
Old 04-12-2013, 10:29 PM   #2822
SWP is Sexy
Member#: 302389
If you can size them right, sure. I'm happy with the kit, is nice thick aluminum. Iirc it's cnc'd too. Pretty much as stable as you're practically gonna get
Old 04-12-2013, 10:34 PM   #2823
Celery GT-5
Member#: 98210
2002 WRX SRP
a guy I talk to on another forum said most 08+ tmic's have slight leaks even before the sides blow off. Not sure if I believe him, he said he would prove it the next time one comes through his shop. I think he knows his stuff but he is a much bigger troll than I am so idk..lol
Old 04-12-2013, 10:56 PM   #2824
SWP is Sexy
Member#: 302389
After seeing how those clips start to separate I believe it
Old 04-12-2013, 10:59 PM   #2825
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah weaksauce
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
