Old 06-11-2012, 12:58 AM   #1
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Default 2012 Impreza 2.0i Roof Spoiler Install
I installed my roof spoiler this weekend and someone was asking for pics of the install, so here they are. This is the first time I've installed anything that required drilling into my car, and I made some mistakes, so hopefully this will prevent others from repeating them.
For reference, here's the PDF with the installation instructions:
http://techinfo.subaru.com/proxy/660...210fj600xx.PDF
Here's what the spoiler looks like out of the box:
First step is to pry off the interior trim around the hatch window. This is really easy; I started from the top right corner, used a small thin tool to create a gap, then a larger tool to pry off the middle piece.
The side pieces can be easily removed by hand once the middle piece is off.
Next pull the wire loop out of the hole:
Cut out the template and tape it on. Make sure it's symmetric on both ends, and try to minimize any bulging up that could affect the placement of the hole markers.
I was skeptical that it was really necessary to cover the windshield and surrounding areas with newspaper like the instructions say, but I didn't want to take any chances to I did it anyway. In retrospect I think it's a good idea to at least cover the back window so that it doesn't get covered in metallic dust from the drilling, and covering up the rest certainly doesn't hurt.
To start off the holes I used a sharp metal poker to create the initial hole through the paint, then used a pointed hammer punch to create a small indent in the metal. I started off with a 2 mm drill bit, then went to 3, 5, and 9 mm (I don't have a metric drill bit set so I just used the closest size I had). I didn't find that taping the bits at these sizes was necessary; I just went slowly, didn't apply too much pressure, and the holes drilled cleanly. After drilling each hole at each bit size, I used the magnet from a magnetic pick-up tool to pick up the metal shavings.
Drilling the two 12mm holes went less smoothly, and this is where taping the bits with a generous amount of tape (to create a drill stop at 5 mm from the tip, like the instructions say) would've helped. Even though I was being careful, once the bit punched through it pulled into the hole, mangling the edge. I was even more careful on the second hole, thinking that it wouldn't happen again, but it did.
After cleaning up the area with the magnet and some compressed air, I pried off the metal shards with needle-nose pliers, and used a small round file to smooth the holes off. I covered the tips of the pliers with tape to unwarp the sheet metal as much as I could.
After cleaning up the shavings from the filing, it was time to prime the exposed metal. Make sure you check the fit of the spoiler before doing this so that you don't have to drill and prime again.
I used Dupli-Color DAP1699 Gray General Purpose Primer Sealer, which came in a spray can, so I sprayed a small amount into a paint tray and used a small paintbrush to apply the primer to each hole:
I let that dry for about 1.5 hours, but an hour would've been plenty I'm sure.
The last step is to bolt on the spoiler. To keep from losing the nuts inside the hatch, I lined the inside of my 10mm socket with masking tape to make a snug fit. (I took off the tape before tightening them down.) Before tightening to the specified torque, tighten the two end nuts enough to keep the spoiler from moving, and make sure you're happy with its position (lower the hatch to check). I found that my spoiler wanted to tip towards the left when loose, resulting in a noticeably smaller distance from the front edge of the hatch to the front of the spoiler. I had to loosen and readjust a couple of times before it was even.
That's it; enjoy your new spoiler!
gfxguy is offline   Reply With Quote
Old 06-11-2012, 01:09 AM   #2
jrands
Member#: 176522
2015 Crosstrek
ISM
+11111111111111111111 Thank you. Have been pondering whether to install the wing myself or take it to a shop. May still do the latter, but good to know. Thanks, I'm sure many a people will really appreciate your thread. thanks!1!1!
jrands is offline   Reply With Quote
Old 06-11-2012, 01:37 AM   #3
12ImprezaSL
Member#: 322198
2012 Impreza SL
Nice! I was thinking about doing it myself but I didn't want to screw it up so I brought it to the shop.
I think it looks a lot better with it.
12ImprezaSL is offline   Reply With Quote
Old 06-11-2012, 02:23 AM   #4
brockd
Member#: 235571
2012 Impreza 2.0i
moar pics
brockd is offline   Reply With Quote
Old 06-11-2012, 10:14 PM   #5
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
You're welcome.
Originally Posted by brockd View Post
moar pics
I just took some, here you go.
Old 06-14-2012, 12:36 AM   #6
imcausinmadrukis
Member#: 318978
How is the front under spoiler held? Glue? Screw? Poo?
imcausinmadrukis is offline   Reply With Quote
Old 06-14-2012, 12:37 AM   #7
imcausinmadrukis
Member#: 318978
Looks sweet. Cant wait to install my spoiler
Old 06-14-2012, 01:12 AM   #8
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Two screws in the wheel well, a plastic rivet under the front of the bumper, and double-sided foam tape along the length. Here's the instructions.
http://techinfo.subaru.com/proxy/659...410fj000xx.PDF
Old 06-27-2012, 12:51 PM   #9
1stSubaru2me
Member#: 324486
2012 Imp. Sport Lim
Default Thanks
Hey,
Thanks...I just bought my 2012 and I wanted a spoiler and didn't want to pay the dealer for the install (which equaled the cost of the spoiler). So with the help of your pics and suggestions...I got the confidence and got it done with no problems.
1stSubaru2me is offline   Reply With Quote
Old 06-27-2012, 10:26 PM   #10
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Originally Posted by 1stSubaru2me View Post
Hey,
Great! Glad it was useful.
Old 07-10-2012, 04:46 PM   #11
imcausinmadrukis
Member#: 318978
[quote=gfxguy;37344132]I installed my roof spoiler this weekend and someone was asking for pics of the install, so here they are. This is the first time I've installed anything that required drilling into my car, and I made some mistakes, so hopefully this will prevent others from repeating them.
What is the name of this specific tool?
Old 07-31-2012, 02:04 AM   #12
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
[quote=imcausinmadrukis;37560468]
It's a pry tool.
I had ordered this:
http://www.ebay.ca/itm/310408961815?...84.m1439.l2649
Old 07-31-2012, 07:31 AM   #13
dubiousmike
Member#: 327473
2012 Impreza Sport L
Great job! What tint levels are you using on your windows?
dubiousmike is offline   Reply With Quote
Old 07-31-2012, 11:28 AM   #14
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Thanks -- 35% front, 20% rear.
Old 08-26-2012, 12:38 AM   #15
Feerdy
Member#: 200212
Just a little advice for people drilling holes in their cars.
Having a really slow drill will cause you issues (unless you push very very soft).
Also you can step the hole up from a smaller size which should help prevent your holes from deforming.
Drill stops will help but honestly its the type of bit and speed of drill that will determine the quality and roundness of your holes.
Use a lubricant to help keep the temperature of the metal and drill bit low so you don't cause the paint to separate from the high heat around the edge of your hole.
You shouldn't have to push very hard to drill your holes, let the drillbits do the work. Pushing hard will cause the material to blow out the opposite side when you are almost through.
Feerdy is offline   Reply With Quote
Old 08-26-2012, 01:55 PM   #16
Grumble7
Member#: 301373
2012 Imp Sport Prem
Gray Metallic
Default Extra road grime?
I installed the same spoiler on my sport a couple of months ago and I notice alot of extra grime and dust building up on the back windshield. Anyone else notice this. Probably normal but annoying.
Grumble7 is offline   Reply With Quote
Old 08-26-2012, 11:35 PM   #17
pkL
Member#: 313093
2012 Impreza 2.0i
There is a whole thread about this, basically the spoiler interrupts the aerodynamic flow of air over the rear of the car, that's why it dumps dust and crap on the hatch.
Old 01-26-2013, 02:50 PM   #18
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
How much did this cost you overall? Planning to buy an after market roof spoiler too...
subaru604 is offline   Reply With Quote
Old 01-27-2013, 12:30 AM   #19
hi5.0
Member#: 340456
2013 Impreza
And I thought it was already pretty bad without the spoiler... Guess that's the trade off for improved looks.
hi5.0 is offline   Reply With Quote
Old 01-27-2013, 01:43 AM   #20
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
OoOooo Honolulu Hawaii, just wondering what do you do there?
I love it there when I went last year ! Wish I can just leave everything behind and move to Hawaii and live there forever...but don't know what can I do there to survive...
Old 01-29-2013, 05:46 PM   #21
CWBill
Member#: 337523
Looks great --- since installation of the roof spoiler requires drilling into the roof, is there any concern about water getting in, or other structural problems? I'm adding the spoiler as an option on a factory order.
CWBill is offline   Reply With Quote
Old 01-29-2013, 08:40 PM   #22
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
You'll be fine spoiler installs aren't much of a big deal don't sweat it I had the factory add mine as I also ordered my car
Old 03-24-2013, 01:36 PM   #23
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Anyone find them pretty cheap in price
subaru222 is offline   Reply With Quote
Old 03-24-2013, 02:52 PM   #24
sexyypants
Member#: 347122
I just installed mine the other day and it was fairly easy. Template was good and used a center punch to indent into the roof. Than drilled.
But for ppl be careful to not push to hard when drilling cuz yoy might hit the washer lines for the water.
And use an airhose to spray the metal shavings off afterwards.
sexyypants is offline   Reply With Quote
Old 03-31-2013, 10:49 AM   #25
gt601
Member#: 308387
2012 Impreza Sport
white
Subaruonlineparts.com is probably the best price. They are great to deal with. If you go with OEM they come color matched to your paint and they fit perfect. Anything after market you will most likely have to mess with it more than is worthwhile and then paint to match. Not that anyone even offers one that I know of.
Paul
gt601 is offline   Reply With Quote
('11-'14) 2012 Impreza 2.0i Stability Control Function riccnick Impreza Forum 420 02-14-2015 05:53 PM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
('11-'14) 2012 Impreza 2.0i Gauges &Center LCD Readout riccnick Impreza Forum 23 03-19-2012 10:51 AM
