Old 03-30-2013, 06:02 PM   #1
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Default Limited AUTO A/C control question
When I have the fan setting in auto, and the vent selector in auto, the A/C turns on if I set the temperature to a cooler setting than what it is inside the cabin. My question is, I have noticed, mostly when sitting at a stop light, or drive thru, if I press the A/C button so the light goes out (and according to the manual the A/C turns off) why is it that I can hear the compressor cycle on and off?? If I want outside air (vent) then why do I need the compressor running? Better yet, why have an A/C button at all if it only turns a light on and off?
Anybody else with a Limited notice this??
jsteg is offline   Reply With Quote
Old 03-30-2013, 06:16 PM   #2
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
If its on Auto and you set it to cooler than outside then the car is going to try to cool the air.
maybe the light is for when you are in manual mode
Old 03-30-2013, 06:39 PM   #3
vwgti123
Member#: 335945
2013 Sport Limited
Per my manual - in Auto Mode everything is controled automatically. To achieve what you are attempting.. you have to go to manual mode to acomplish. The A/C light is only for manual mode. Hope this helps.
vwgti123 is offline   Reply With Quote
Old 03-30-2013, 06:59 PM   #4
jsteg
Member#: 329271
Ice Silver Metallic
So in full auto mode, even if I push the AC button to turn it off, and the light indicates it's off, it's still going to do what it wants??
Weird, but I guess understandable. They should have made it where if you pushed it in full auto, the light doesn't turn off. Gives false indication the way it is now.
Old 03-30-2013, 07:10 PM   #5
dhlee528
Member#: 337395
2014 Impreza SP Ltd
ISM
as for my mom's camry, if A/C light is off A/C is off even in full auto mode, however, car keeps the fan on so cooler air comes into the car whereas if A/C is on then cold air comes into the car.
so basically, if it's on auto, car will do whatever it takes to do to decrease or increase temperature. pressing A/C just turns on/off A/C. btw, A/C works with hot air too.
dhlee528 is offline   Reply With Quote
Old 03-30-2013, 07:16 PM   #6
jsteg
Member#: 329271
Ice Silver Metallic
Ok well thanks for that I guess lol. I'm not sure how your mom's camry is related to this, as it's a completely different system altogether.
Yes, I understand AC works with hot air too, but not if I leave it in Auto and turn the know warmer, it will shut the AC off. Pressing the AC button in my case does nothing but turn the light off if left in full auto.
Old 03-30-2013, 08:13 PM   #7
Zeeper
Member#: 299286
2015 WRX CVT
Maybe the auto function cycling on and off the AC accounts for some of the extra fuel consumption some CVT owners are complaining about?
Old 03-31-2013, 01:20 PM   #8
vwgti123
Member#: 335945
2013 Sport Limited
Old 03-31-2013, 07:18 PM   #9
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
On the left knob/control, do you have it placed in one of the "defrost" positions? (All the way right or the next two positions to the left of there, I think). If it is in any of the "defrost" positions, the A/C is automatically activated.
G-Omaha is offline   Reply With Quote
Old 03-31-2013, 07:20 PM   #10
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Defrost in any setting causes additional fuel consumption. Also the "heavy foot" and driving it like a typical AT can also effect the MPG. It just will not shift like an AT, no matter how hard you try.
For some reason (maybe better weather, I am seeing an additional 6/7 MPG in the last week).
Old 03-31-2013, 08:28 PM   #11
jsteg
Member#: 329271
Ice Silver Metallic
When I have the fan setting in auto, and the vent selector (far left knob) in auto, the A/C turns on if I set the temperature to a cooler setting than what it is inside the cabin. My question is, I have noticed, mostly when sitting at a stop light, or drive thru, if I press the A/C button so the light goes out (and according to the manual the A/C turns off) why is it that I can hear the compressor cycle on and off?? If I want outside air (vent) then why do I need the compressor running? Better yet, why have an A/C button at all if it only turns a light on and off?
You tell me...........
Old 04-01-2013, 08:36 AM   #12
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Didn't catch that. If in Auto mode and the temperature is less than 37 degrees (I think or it may be 47 - it's in the manual), then the defrost mode will automatically engage. Ideal for cars equipped with the remote starter.
Old 04-01-2013, 08:57 AM   #13
jsteg
Member#: 329271
Ice Silver Metallic
Yeah I saw that mentioned here before but when I've noticed this, it's not anywhere near that cold.
Old 04-01-2013, 09:02 AM   #14
Zeeper
Member#: 299286
2015 WRX CVT
So the price for having the Limited with Auto controls is less MPG's, in part because letting the car decide when to cycle the A/C on and off instead of the driver (like in the manual temp controls) is that it turns on and off more, way more apparently.
Ah, the price of luxury. Please keep it in mind when you are complaining about the CVT's, or overrride it if you can if you are trying to maximize your mpgs.
Old 04-01-2013, 07:28 PM   #15
vwgti123
Member#: 335945
2013 Sport Limited
Such a weenis!
Old 04-01-2013, 08:30 PM   #16
Zeeper
Member#: 299286
2015 WRX CVT
Such a weenis!
You don't want me to comment on your posts, and PM spammed me to tell me, so don't comment on my posts. Is that hard for you to grasp?
Old 04-01-2013, 08:35 PM   #17
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Such a weenis!
Troll Alert??????
Old 04-02-2013, 06:37 PM   #18
jsteg
Member#: 329271
Ice Silver Metallic
I've never complained about my MPGs......
Old 04-02-2013, 07:24 PM   #19
vwgti123
Member#: 335945
2013 Sport Limited
Exactly. It had nothing to do with your post or you honest question... His way to start trouble..... That is why I gave him the weenis. GMama, no comment... Zipper - Learn to stop telling others what to do... Let's please move on.
