Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-26-2013, 03:18 AM   #2551
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Originally Posted by meifert View Post
read that. it's been confirmed by multiple people. you load up the rear with a WRX/STI suspension and the control arm will hit the body or frame potentially causing failure, damage and discomfort. just because something can bolt right up, doesn't mean it should be done.
http://www.subaruforester.org/vbulle...p-help-116896/
jmackoul from subaruforester.org said this.
What i'm talking about is that with the sti/wrx suspension, the upper control arm is very very close to the chasis. when and if you have over 300lbs load in back seats + a passenger, in other words, a full car, the upper control arm will actually rest on the chasis. This is because the impreza has a bent upper control arm and the forester has a straight upper control arm. This is why some people that have swapped for the sti suspension opted for a 1'' top hat lift kit front and rear. Slamming the forester isn't a mechanically sound mod unless you swap out the straight upper control arm for a bent impreza upper control arm.
I don't plan on swapping to the sti/wrx setup. Based on portbarton's (Philippines) review of them on stock springs, the dampening rate is higher and provides a slightly firmer ride, although he does emphasize that they are not a sport strut. SH owners interested in the KYB's hope to mate them with swifts as this should provide a few things:
1) a better dampening strut that is better than stock
2) a strut that can easily handle the 1'' drop from the sift springs
3) a comfortable strut
IMO, struts and springs are not the crux of ones suspension. sway bars, end links, springs, and subframe bushings are really what can make a comfortable daily driver turn like a track car.
I've not had any problems with it yet. I initially looked into the wrx control arms as they can be had pretty cheap on Ebay. I might get some down the road. The only draw back is then I've got to have another alignment. I would then have to have the powerflex bushings installed into the wrx control arms. Which is even more added expense. Then again theoretically if I went with coil overs the same thing would occur unless they were Forester specific.
2010SubieFoz is offline   Reply With Quote
Old 03-30-2013, 11:01 PM   #2552
emac08
Member#: 346355
2014 Forester XT
Originally Posted by Aussie Dave View Post
323 hp atw but not done yet
As of March 2013 it looks like this:
such a sweet forester!
emac08 is offline   Reply With Quote
Old 03-31-2013, 11:39 AM   #2553
Bjay51d
Member#: 294228
05 Forester XT
new look still need to install lip
Bjay51d is offline   Reply With Quote
Old 03-31-2013, 12:36 PM   #2554
pushnpounds
Member#: 207683
02 bugeye
wrb
i want that wing^^^ where did you get it? this is my fxt.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
pushnpounds is offline   Reply With Quote
Old 03-31-2013, 03:10 PM   #2555
Bjay51d
Member#: 294228
05 Forester XT
You can get in touch with jackie...She has the wings dirt cheap she wont have your color but you can get it painted$159 vs 260 http://www.subaruforester.org/vbulle...-added-128627/
Old 03-31-2013, 04:06 PM   #2556
chunkybird
Member#: 256755
chunkybird is offline   Reply With Quote
Old 03-31-2013, 04:27 PM   #2557
Bjay51d
Member#: 294228
05 Forester XT
Low looks so good...I'd be worried bout my fumoto valve if I went lower.I also like the fact I can scoot under my car and change the oil without ramps.
Old 03-31-2013, 11:46 PM   #2558
NEU
Member#: 265995
2000 Volvo v70R
2011 Forester XT Touring
From a recent family road trip to Florida.
NEU is offline   Reply With Quote
Old 03-31-2013, 11:56 PM   #2559
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
Looks good^^
m_clark54 is offline   Reply With Quote
Old 04-01-2013, 10:52 AM   #2560
NEU
Member#: 265995
2000 Volvo v70R
Thanks! It's coming along slowly... Still needs some springs and struts, don't want to lower it too much maybe an inch. And needs a good tune.
Old 04-01-2013, 11:11 AM   #2561
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
Is that an STI sedan exhaust?
Old 04-01-2013, 01:15 PM   #2562
NEU
Member#: 265995
2000 Volvo v70R
Yep, '11 STI sedan, no cutting and sounds great! Not to loud to wake the neighborhood, adds a nice deep rumble and no drone... And my wife likes it too, which is important since it's her daily driver...
The stock Foz system has a baffled center section (resonator) it's really restrictive compared straight thru (glasspack) and the quad mufflers. They are a lot louder then stock mufflers too, I tried different combos. Even without a tune I can tell the STI system has helped with the XT performance.
And the best part I got it for dirt cheap too.
Since I have the original system still, I thought about cutting out the resonator and putting straight pipe on it to see how it sounds. I've heard some Youtube videos of quad system with straight pipe, and is sounds very raspy, maybe too much, but hey it's free....
Old 04-01-2013, 02:08 PM   #2563
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
I used a nameless axleback from a 2010 wrx sedan. Free. Was a prototype.
Can you post up a video clip of your exhaust?
Would like to hear how it sounds on a fxt.
Old 04-01-2013, 08:40 PM   #2564
scrappydoo225
Member#: 262933
2005 Leztastic wagon
cayanne red pearl
the summer setup, still gotta get a lip and Retrofit the head lights.
Bjay the flares look good
scrappydoo225 is offline   Reply With Quote
Old 04-01-2013, 09:17 PM   #2565
NEU
Member#: 265995
2000 Volvo v70R
Sorry, I don't have any clips of the full STI exhaust, just these clips of stock, DP only and STI center with XT mufflers. I tried that for a while before adding the quad mufflers and didn't take video. I do have to say that the quads have gotten louder in the almost 2 years since i've installed them, they were brand new (under 500miles).
https://www.youtube.com/watch?v=kscB...qVwfw&index=31
https://www.youtube.com/watch?v=sWYL...qVwfw&index=30
https://www.youtube.com/watch?v=95L8...qVwfw&index=28
Old 04-02-2013, 12:24 AM   #2566
emac08
Member#: 346355
2014 Forester XT
Damn man. Loving the wheel set up. What size wheels/tires you end up going with?
what wheels are these?
Old 04-02-2013, 01:48 AM   #2567
meifert
Member#: 301676
2009 Forester XT
they look like OZ superleggaras or ultraleggaras. not sure if spelling is right though
meifert is offline   Reply With Quote
Old 04-02-2013, 07:04 AM   #2568
scrappydoo225
Member#: 262933
cayanne red pearl
18x9.5 +30. Tires are 245/40
Old 04-02-2013, 07:42 AM   #2569
NEU
Member#: 265995
2000 Volvo v70R
Mine are OZ Ultraleggeras 18x8 40et (18.4lbs) 245/45 Yoko AVS ES100s.
Old 04-02-2013, 01:19 PM   #2570
Bjay51d
Member#: 294228
05 Forester XT
Perfect stance and love the rims man...Ebay has an importology knockoff that fits pretty good. I have one but I need a extra set of hands and some one else to eyeball from a distance would be nice also.
Old 04-02-2013, 08:27 PM   #2571
meifert
Member#: 301676
2009 Forester XT
how much do they weigh?
Old 04-07-2013, 04:25 PM   #2572
ToNIX
Member#: 336132
2008 Foz
Newport Blue
ToNIX is offline   Reply With Quote
Old 04-07-2013, 07:11 PM   #2573
EspoNation
Member#: 272237
2013 2.0i ImprezaSpt
I miss them and I need them back... Now!
I kid, they look awesome Josh.
EspoNation is offline   Reply With Quote
Old 04-09-2013, 09:08 PM   #2574
ajc65
Member#: 253927
2003 WRX w/ V9 EJ207
Midnight Black Pearl
AND NOW summer mode......
04 fxt
vf-39
power enterprise 850cc injectors
spt intake
2011 sti top mount
walbro 255
perrin up and down pipe
bosal cat back exhaust
Fortune Auto Coilovers (fxt specific)
18x8 rpf-1s with a 245/40/18
ajc65 is offline   Reply With Quote
Old 04-10-2013, 10:48 PM   #2575
Aussie Dave
Member#: 78790
2010 Forester XTP
Aussie Dave is offline   Reply With Quote
VA - CD player for Forester Ferret13 MAIC Private Classifieds 2 06-03-2010 11:18 PM
Forester Gallery Jeff's Forester Forester Forum 10 10-20-2004 01:31 AM
Prescott Forest Photo Gallery SLIG Motorsports 0 10-20-2001 02:03 AM
Killer Forester in the Gallery. Imprezer Forester Forum 5 02-09-2001 04:29 PM
