Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 05-24-2006, 04:41 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default Cheepest place to find EZ30R Shims for Valve Adjustment
I have a TWE Shim Under Bucket kit that uses stock Subaru Shim Under Buckets and am getting ready to do a valve adjustment and may need a set of shims.
I was told the shims that this setup uses is off the EZ30R.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 05-25-2006, 03:24 PM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Cheapest place Ive found so far is subaruparts.com. They are around $25 cheaper then straight from the dealer.
Old 05-25-2006, 08:16 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
That's where I'd get them. So your 99 legacy GT is dohc?
Tim Sanderson is offline   Reply With Quote
Old 05-25-2006, 09:09 PM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Yep DOHC.
I found out also that the Subaru shim under bucket setup is in the EZ30D.
Old 02-04-2007, 04:22 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Just trying to figure this stuff out myself. The EZ30D is the EZ30R, from what I understand. I don't know what the designation is of the "normal" EZ30 - if it's just EZ30 or what.
Anyway, I've downloaded the appropriate sections of the Service Manuals for various models. The EZ30R's lifters (buckets) are 32.959-32.975mm in diameter, which is the same as the DOHC EJ25. The regular EZ30's lifters are 1mm larger (and the STI/WRX lifters are 1mm larger than that).
Pat Olsen
'97 Legacy 2.5GT sedan
Old 03-31-2013, 11:51 AM   #6
2slofouru
Member#: 90539
Ancient thread bump. I've searched but can't find a list of the ez30r solid buckets with varying thicknesses, like the sti versions which can be purchased to adjust clearance. Anyone know a site where the oem part numbers are listed? Subaruparts.com only has one listing and its about $20 but there isn't a way to request sizes. Seems the intake buckets are indeed hydraulic judging by their price being almost 5x as much. Bump for help
Old 04-01-2013, 04:14 PM   #7
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Intakes are for active valve lift and have a spring/pin inside. Look up Porsche VarioCam Plus to see how it works. Underneath is a shim, the bucket itself is one size.
Exhaust is shimless bucket, 33mm dia:
Part number Size
13228AC580 4.62
13228AC590 4.63
13228AC600 4.64
13228AC610 4.65
13228AC620 4.66
13228AC630 4.67
13228AC640 4.68
13228AC650 4.69
13228AC660 4.70
13228AC670 4.71
13228AC680 4.72
13228AC690 4.73
13228AC700 4.74
13228AC710 4.75
13228AC720 4.76
13228AC730 4.77
13228AC740 4.78
13228AC750 4.79
13228AC760 4.80
13228AC770 4.81
13228AC780 4.82
13228AC790 4.83
13228AC800 4.84
13228AC810 4.85
13228AC820 4.86
13228AC830 4.87
13228AC840 4.88
13228AC850 4.89
13228AC860 4.90
13228AC870 4.91
13228AC880 4.92
13228AC890 4.93
13228AC900 4.94
13228AC910 4.95
13228AC920 4.96
13228AC930 4.97
13228AC940 4.98
13228AC950 4.99
13228AC960 5.00
13228AC970 5.01
13228AC980 5.02
13228AC990 5.03
13228AD000 5.04
13228AD010 5.05
13228AD020 5.06
13228AD030 5.07
13228AD040 5.08
13228AD050 5.09
13228AD060 5.10
13228AD070 5.11
13228AD080 5.12
13228AD090 5.13
13228AD100 5.14
13228AD110 5.15
13228AD120 5.16
13228AD130 5.17
13228AD140 5.18
13228AD150 5.19
13228AD160 5.20
13228AD170 5.21
13228AD180 4.32
13228AD190 4.34
13228AD200 4.36
13228AD210 4.38
13228AD220 4.40
13228AD230 4.42
13228AD240 4.44
13228AD250 4.46
13228AD260 4.48
13228AD270 4.50
13228AD280 4.52
13228AD290 4.54
13228AD300 4.56
13228AD310 4.58
13228AD320 4.60
13228AD330 5.23
13228AD340 5.25
13228AD350 5.27
13228AD360 5.29
13228AD370 5.31
13228AD380 5.33
13228AD390 5.35
13228AD400 5.37
13228AD410 5.39
13228AD420 5.41
13228AD430 5.43
13228AD440 5.45
13228AD450 5.47
13228AD460 5.49
13228AD470 5.51
13228AD480 5.53
13228AD490 5.55
13228AD500 5.57
13228AD510 5.59
Marnix is offline   Reply With Quote
Old 04-01-2013, 04:16 PM   #8
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
Your looking at the wrong part. The part you are looking for sits directly on top of the valve stem. The buckets on the intake side are multi-peice to allow for the variable valve lift system. This is the reason for the tiny shim that sits on the valve shim. The exhaust buckets (on the ez30r) are the normal shim buckets like what the STI uses.
jake
KONKILR is offline   Reply With Quote
Old 04-01-2013, 08:07 PM   #9
2slofouru
Member#: 90539
\/ This guy is awesome
\/ Not so sure who this guy is replying to
jake
Place to find a cat delete for 95 impreza?? nerally Normally Aspirated Powertrain 1 05-26-2009 12:55 PM
Best place to find front bumper for 05' STI? Adam P Texas Impreza Club Forum -- TXIC 4 04-10-2006 11:40 AM
Help me find a place to rent a Vette for the day in CT! BrysImpreza New England Impreza Club Forum -- NESIC 13 02-24-2006 06:30 PM
Semi-Emergency: Need an alternator tensioner bolt for 02 WRX or place to find it gryph Texas Impreza Club Forum -- TXIC 10 10-30-2005 02:05 PM
Outside Tucson - not emergency - but want to find mechanic for valve adjust Chris Stein South West Impreza Club Forum -- SWIC 0 11-06-2002 09:47 PM
