Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 04-01-2013, 10:54 PM   #1
sedonarex13
Member#: 313573
06 wrx
Default Am i over boosting?
I am still trying to figure out if i have issues or not, cant seem to get a answer. 06 wrx, catless tbe, running cobb stage 2 93 octane mt. My car has hit as high as 19.5 psi in 3rd gear punching it from 3500 rpm but it will just peak then drop back down and hold at 14 or 15 psi. I took some logs but my shaty computer will not recognize my ap so data logging is not realy an option. I simply want to know if i am safe with these boost numbers.
sedonarex13 is offline   Reply With Quote
Old 04-01-2013, 11:06 PM   #2
420bugeye
Member#: 283513
2012 Wrx
Just look at the notes for your ap map on cobb website where it says maximum psi.Simple as that. Prepare for flame fer not searchin first
420bugeye is offline   Reply With Quote
Old 04-01-2013, 11:13 PM   #3
sedonarex13
Member#: 313573
06 wrx
I can not view the maps on cobbs website i forgot to mention that my computer is one of the first ones ever made lol
Old 04-01-2013, 11:17 PM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
What's your target boost?
What's your actual boost?
Is actual boost higher than target boost? If yes, then you're over boosting. Else, you're not over boosting.
Old 04-02-2013, 08:08 AM   #5
masterforce
Member#: 221580
2011 WRX STI
You should have read the Notes for the map before even installing it......Anyways here is what the notes say for 06-07 WRX...
Stage2 93 MTv300
o Fuel Requirements: 93 - 94 octane or better
o Intake Requirements: Stock airbox or COBB Tuning SF Intake
o Exhaust Requirements: Upgraded turbo-back exhaust
o Boost Targets: ~15.2psi peak boost pressure tapering down to ~10.0psi by the 6700RPM redline, +/- 0.7psi
If you numbers you are saying are spot on, then even with +/- 0.7psi, you are overboosting...
masterforce is offline   Reply With Quote
Old 04-02-2013, 08:35 AM   #6
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Call cobb and see what they say about your overboosting. Then go get a pro tune
booSTin-scoobs is offline   Reply With Quote
Old 04-02-2013, 09:05 AM   #7
greenplates
Member#: 239162
Also, many guys have Grimspeed 3 port electronic boost control solenoid. This ensures rock solid boost curve without any spikes. This requires a pro tune
greenplates is offline   Reply With Quote
Old 04-09-2013, 02:02 AM   #8
sedonarex13
Member#: 313573
06 wrx
So can i just decrease the boost buy ajusting the wastegate arm?
Old 04-09-2013, 06:27 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2020 Subaru
Outback
Do not touch the wastegate arm if you do not know what you are doing. Also do not buy/install an MBC for that same reason.
Old 04-10-2013, 10:49 PM   #10
sedonarex13
Member#: 313573
06 wrx
Are the wastegates ajustable on a 06 people have been telling me they are electronicly controlled and can not be ajusted
Old 04-10-2013, 10:52 PM   #11
Nate_1990
Member#: 234485
2004 STI
Rally Blue
I have never had any issue with the grimmspeed solenoid. I had it protuned and never seen anything above target boost. Very good product.
Nate_1990 is offline   Reply With Quote
Old 04-11-2013, 01:38 AM   #12
J-mez
Member#: 292727
You may want to look into the LWG map if you do find that you are overboosting.
J-mez is offline   Reply With Quote
Old 04-11-2013, 06:39 AM   #13
HinshawWRX
Medium Frank
Member#: 140114
2020 Subaru
Outback
Yes, the wastegate is adjustable via the wastegate arm. DO NOT TOUCH IT. If you don't know what you are doing, you will make it worse.
Old 04-11-2013, 06:41 AM   #14
Ziggyrama
Member#: 53665
2022 BMW M240i
Thundernight
You're spiking, not overboosting. The ECU is overshooting the initial target on approach and settles down eventually. It's not great but not the end of the world either. BTW, if you're reading your boost off the gauge, it is likely slightly higher than what the ECU is seeing in the manifold which means that your actual boost error is not as big as you think. Your gauge is likely reading off the IC which is subject to some pressure loss before the MAP sensor. The only way to accurately assess the situation is to log the car and see what is reported. Your gauge could also be inaccurate and you're sweating for nothing.
Ziggyrama is offline   Reply With Quote
Old 04-11-2013, 12:33 PM   #15
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Get yourself a used laptop or PC that is capable of running the AP Manager program. Or find a friend that will let you install the program on their computer. It doesn't take cutting edge hardware to run it. Then take some logs and have a look at them or post them up. You're talking about the health of your engine here. The only way to know if things are safe is to look at your logs.
It's like saying you think you might be having a heart attack but you can't call 911 because your cell phone is broken.
findurpath is offline   Reply With Quote
Old 04-11-2013, 02:43 PM   #16
sedonarex13
Member#: 313573
06 wrx
The only gauge i have is the ap itself i recently had to send the ap back to cobb because something was broken inside of it but they let me keep my car.tuned and just send it to them so i am currently not driving the car because i have no way of monitoring
Old 04-11-2013, 03:40 PM   #17
blueninja85
Member#: 324091
Doesn't a catless downpipe cause boost creep on the EJ25's creating a overboosting condition? If I remember correctly, Cobb highly recommends a catted downpipe for this very reason. But even then a catted downpipe might cause boost creep. However, a solution to helping fix boost creep, if that is what you're experiencing to port your wastegate.
blueninja85 is offline   Reply With Quote
Old 04-11-2013, 04:01 PM   #18
Shelamae24
Member#: 353126
I don't think you are..
Shelamae24 is offline   Reply With Quote
Old 04-11-2013, 04:55 PM   #19
sedonarex13
Member#: 313573
06 wrx
I will wait to get my ap and somehow take some logs and let yall know. Thanx for all the help
