Old 04-01-2013, 09:19 PM   #1
wnowak1
Member#: 276499
Default Too much oil?
I've read the 2011 STI takes 4.24 quarts of oil. I poured a bit too much by accident, about 4.5-4.6 quarts. The dipstick is reading Full after shutting the engine off. Is this too much oil? Should I drain some? I let the oil drain for about 25 minutes before putting on a new filter and putting the drain plug back on the oil pan. If it is too much oil, can I loosen the drain plug a bit to let some oil out without having to replace the crush washer?
Thank you.
wnowak1 is offline   Reply With Quote
Old 04-01-2013, 09:24 PM   #2
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
It's fine. You don't have to do anything.
Old 04-01-2013, 09:27 PM   #3
wnowak1
Member#: 276499
Thanks, I can sleep at night now
Old 04-01-2013, 09:34 PM   #4
greenplates
Member#: 239162
Glad you are changing your oil by yourself! Keep checking oil levels, remember to keep it topped off
greenplates is offline   Reply With Quote
Old 04-01-2013, 10:45 PM   #5
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
pretty sure they are one time use. so once you tighten them then loosen them you will want to throw it away and replace it.
Dmochowski is online now   Reply With Quote
Old 04-01-2013, 11:00 PM   #6
meebs
Member#: 3251
2009 WRX Hatch
That's right where you want it; and actually you could probably get away with a little more. The "hot" reading if you will, is the notch ABOVE full. Meaning, it's OK to touch that notch if you are checking *right after* you shut the engine off.
meebs is offline   Reply With Quote
Old 04-01-2013, 11:19 PM   #7
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Everyone I know dumps on 5 quarts and calls it a day.
Old 04-01-2013, 11:23 PM   #8
Badler
Member#: 133597
That's what I always did.
Badler is online now   Reply With Quote
Old 04-01-2013, 11:28 PM   #9
wnowak1
Member#: 276499
Thank you all for responding.
Old 04-02-2013, 08:50 AM   #10
rkramer
Member#: 118209
2015 WRX Limitec
officially they are, but I've also replaced crush washers in some vehicles every 100k miles or so, without a single drop leaking... GENERALLY it is fine to reuse them.
rkramer is offline   Reply With Quote
Old 04-02-2013, 08:59 AM   #11
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
I've never replaced my crush washer in the 85K miles of oil chages I have performed and have never had a single drop leak out.
Maybe I have a magical crush washer?
Brock31 is offline   Reply With Quote
Old 04-02-2013, 08:59 AM   #12
greenplates
Member#: 239162
I purchased this
https://www.google.com/search?q=oil+...UgKM2v2_ovM%3A
Old 04-02-2013, 09:30 AM   #13
Dmochowski
Member#: 306478
2012 WRX limited
Yeah I didn't replace them the first couple changes either but they are less than a dollar do I went to the dealer and picked up like ten at once and they sit in a cup in my garage.
Old 04-02-2013, 10:46 AM   #14
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Fumoto drain valve ftw
2.5L Monster is offline   Reply With Quote
