Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 02-10-2012, 04:05 PM   #1
SubUSAF
Member#: 309805
2011 Impreza WRX STI
Lightning Red
Default 2011 STI Possible ECU issues
I bought my STI back in June. I recently went over 13,500 miles.
On my way from driving to Omaha, NE from California I had a cylinder #2 misfire @ 94 mph in 6th gear or about 3670 rpm. This issue was cleared up after a number of restarts and a short trip to the dealership. It would seem that now I am having an issue with the ABS/hill start assist/traction control turning off, the terrain of Omaha is slightly more hill ridden than California but these problems have only seemed to occur when sitting on flat terrain at stop lights. Turning the car on/off clears the problem but it is starting to get rather bothersome. This is my 4th Subaru. 1984 Wagon. 2006 Impreza. 2010 WRX.
SubUSAF is offline   Reply With Quote
Old 02-10-2012, 08:32 PM   #2
NoGraffix
Member#: 276209
I am Rub
Function>Form
are you saying your ABS/traction control/hill assit randomly turn off?
I'm confused please restate your question.
NoGraffix is offline   Reply With Quote
Old 02-10-2012, 08:53 PM   #3
SubUSAF
Member#: 309805
Lightning Red
Yes. I can be sitting idle at a stop light w/ foot off the clutch and all the warning lights for ABS, traction control, and hill assist just turn on.
Old 02-10-2012, 09:09 PM   #4
NoGraffix
Member#: 276209
I am Rub
Function>Form
does a check engine light come on too?
Old 02-10-2012, 09:14 PM   #5
SubUSAF
Member#: 309805
Lightning Red
Not with this new problem.
Old 02-11-2012, 09:09 AM   #6
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
What leads you to believe that this is an ECU problem? When you turn the car off, you do not cut power to the ECU which means that there is no reset occurring. Honestly, you have a car that is misbehaving significantly and it's under warranty. Bring it to the dealership and have them look at it. Sounds like you don't have problems reproducing it so they should be able to see it.
Ziggyrama is offline   Reply With Quote
Old 02-11-2012, 03:50 PM   #7
SubUSAF
Member#: 309805
Lightning Red
Thank you for the advice.
Old 02-18-2012, 11:24 PM   #8
SubUSAF
Member#: 309805
Lightning Red
Okay, after a small wait to get into the dealer, here is their almighty answer.
Apparently after driving my car for about 10 miles they were unable to duplicate the issue.
Not very surprising really. There was a stored code for the ABS/Traction control system stored in the computer but they were not sure what really caused this issue.
STI 1 - Dealer 0....
Old 02-19-2012, 12:30 AM   #9
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
While this doesn't 'solve' the problem, why not just turn off the hill assist? I have it perma-enabled on my 08, and it's never been a problem. But I believe in 09+'s you can turn it off with some procedure...
Napalm3nema is offline   Reply With Quote
Old 04-01-2013, 08:32 PM   #10
Gienek
Member#: 295695
2011 STi
Just curious if you were able to solve this problem? ...Asking because I have a 2011 Sti Limited which started doing the same thing at 12k and I am kinda reluctant to take it to the dealer for obvious reasons,...thanks.
Gienek is offline   Reply With Quote
Old 04-01-2013, 11:53 PM   #11
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
I'm wondering if you living in California, aren't you limited to 91 octane gas? If so, get tuned for that gas, as your STi is really setup for 93 octane currently. When you then throw changing elevations on your road trip into the mix, that could be a contributing factor potentially. Aside from that, what gas are you using? You could have just had a bad tank of gas. I recommend sticking to new(er) Chevron stations, and don't just toss anything you can find into the car.
Good luck...
Old 04-02-2013, 09:17 AM   #12
SpamBot
Member#: 287534
The dealership should have been able to pull the DTC from the VDC memory. Even if they could not duplicate the condition, the DTC in memory would give them an indication of what may be happening.
Then again, if the freeze frame data indicated 94 MPH, they would just clear the code and tell you to pound sand.
SpamBot is offline   Reply With Quote
Old 04-02-2013, 12:57 PM   #13
NE_06STI
Member#: 271713
2011 STI Limited
I had the same issue with the traction control, ABS, and Hill Assist lights coming on. I took it to Beardmore Subaru in Omaha and they told me it was the break sensor and replaced it for me and haven't had an issue ever since. Hope this helps.
NE_06STI is offline   Reply With Quote
Old 04-09-2013, 11:28 AM   #14
SubWRX09
Member#: 351860
2009 WRX
I'm having the exact same problem with the ABS traction control and up hill assist lights coming on. Mine don't always come on when I start the car but after driving for maybe 5-10 minutes they come on. I hit a curb this winter and had my control arm replaced. Think the ABS sensor could be broken also?
SubWRX09 is offline   Reply With Quote
2011 WRX Ecu issue Primer13 Warranty Issues & SOA Problems 76 03-17-2014 06:48 AM
2004 STI Possible TPS issue klarowe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-04-2013 08:29 AM
WTT : 2011 STI Steering wheel airbag and controls, black for grey. TheTallOne TXIC Private Classifieds 1 02-10-2012 06:10 PM
2011 STI embedded ECU break in? snoopy_sti Engine Management & Tuning 11 06-14-2011 08:18 PM
Possible ECU issue furryfootstool South West Impreza Club Forum -- SWIC 12 05-12-2009 11:37 AM
