Old 04-02-2013, 12:42 PM   #1
cdetten4
Member#: 348147
2007 Impreza wrx
Default clutch opinions
New to the tuner world and everything i search makes a tough call on choosing. I was told to get a exedy and then i start calling dealers and they all say act or spec but people here in town say no spec. So Im wanting a poll between the three to help me pick and the car will get Cobb stage two by the end of the year so it will need yo handle a little power. Thanks for the input!!!
cdetten4 is offline   Reply With Quote
Old 04-02-2013, 01:22 PM   #2
ToneWrx02
Member#: 239095
2002 Wrx
im very please with my heavy duty act clutch.
ToneWrx02 is offline   Reply With Quote
Old 04-02-2013, 02:46 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
1. This isn't the "tuner world", start off by using the right terms first off.
2. Read the sticky threads at the top of each forum BEFORE posting. Here's your hint: http://forums.nasioc.com/forums/show....php?p=9878792
3. Without posting your car's torque, not even Jesus can help you...the only thing that will happen is that n00bs will throw out random clutch brand/types that will confuse you.
4. Now that you've had your head aligned, go to item 2 above and read it fully as the advice listed there is badass and in case you are too lazy to read it, here are the CliffNotes:
You do NOT need anything other than a stock clutch and flywheel at Stage 2 or less power levels regardless of what Subaru you own and if you go out and use something else, even if you were to get said clutch for $0, you are a moron.
Old 04-02-2013, 02:52 PM   #4
1wrxtra
Member#: 316364
Did you read the Clutch + Flywheel sticky? My money is on no, no you didn't.
http://forums.nasioc.com/forums/showthread.php?t=775679
Read. Learn. Make informed decision. Profit.
Old 04-02-2013, 02:52 PM   #5
NoGraffix
Member#: 276209
I am Rub
Function>Form
your "stage2" stock turbo (td04) will not make enough power to warrant the purchase of a new clutch
NoGraffix is offline   Reply With Quote
Old 04-02-2013, 02:52 PM   #6
1wrxtra
Member#: 316364
Damn you beat me to it.
Old 04-02-2013, 03:35 PM   #7
cdetten4
Member#: 348147
2007 Impreza wrx
Brutal info but thanks. I don't have time to go find a dyno to get you torque numbers. Ill read up on it when i get off work. Thanks
Old 04-02-2013, 03:39 PM   #8
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
Stock clutch will handle stage 2 easily. Heck, it'll handle vf39. Might as well use that money and go stage vf39.
SilverBOXER4 is offline   Reply With Quote
