Old 03-30-2013, 02:36 AM   #1
skimpreza06
Member#: 304086
Default low boost after washing engine bay??
Hey guys so i have a fully stock 2002 wrx and yesterday i decided to clean the engine bay. I used scrubles bubbles, sprayed on a good amount and rinsed the engine bay 2 times without covering anything. I used my hose to spray it down with not a lot of pressure. My boost gauge was indicating between 12 and 15 psi at max before and now it wont go more than 7 psi. What is going on?
skimpreza06 is offline   Reply With Quote
Old 03-30-2013, 05:30 AM   #2
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
Have you checked all of your vacuum lines? Another possibility is that you soaked your BCS or the sending unit for your boost gauge. Whenever you wash your engine bay, always cover everything that is connected to your engine harness including the bulk harnesses or anything electronic for that matter.
Ken Sekiguchi
KenSekiguchi is offline   Reply With Quote
Old 03-30-2013, 06:04 AM   #3
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
Ken Sekiguchi
Agreed with covering harnesses and anything electronic in the future. Also, avoid directly spraying the alternator. It is best to use a plastic garbage bag to cover up certain areas as mentioned. I agree that you should check vacuum lines first. That would be an easy fix. Good luck!
07STifastashell is online now   Reply With Quote
Old 03-31-2013, 01:07 PM   #4
skimpreza06
Member#: 304086
I checked the vaccum lines and everything is fine. how can i know if its the bcs or not?
Old 03-31-2013, 07:06 PM   #5
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Did you get your air filter soaked?
skimobile is offline   Reply With Quote
Old 04-01-2013, 01:32 AM   #6
808wrx719
Member#: 352040
do you have a cold air intake ? I had a buddy that sprayed down his engine bay at a car wash, got some on his k&n cold air and it caused extreme starting issues, boost issues post wash, as well as idling problems. Be careful when getting water in that engine bay!
808wrx719 is offline   Reply With Quote
Old 04-01-2013, 11:16 PM   #7
skimpreza06
Member#: 304086
No i dont have a cold air intake. My car is all stock, but i dont think the air filter got soaked it was in its box well sealed. Its weird the car is idling fine, driving fine, no check engine light , it just wont go over 7 psi no matter how much i give her.
Old 04-01-2013, 11:22 PM   #8
and people always wonder why i tell them NOT to DO this
Old 04-02-2013, 10:18 AM   #9
thehanz123
Member#: 318418
rally blue
thehanz123 is offline   Reply With Quote
Old 04-02-2013, 11:29 AM   #10
danger1138
Member#: 279525
04 rex luger!
U should post some before and after pics of the engine bay to see if u notice a difference in cleanliness..
danger1138 is online now   Reply With Quote
Old 04-02-2013, 11:46 AM   #11
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
7psi is wastegate pressure, so something is wrong with the bcs or a vacuum line that its only running wastegate pressure.
jayman4312 is offline   Reply With Quote
Old 04-02-2013, 12:01 PM   #12
greenplates
Member#: 239162
This.
greenplates is offline   Reply With Quote
Old 04-02-2013, 01:29 PM   #13
skimpreza06
Member#: 304086
ok thanks guys, im going to try to get a bcs this week and try it out.
Old 04-02-2013, 09:18 PM   #14
Andrewxxcarlson
Member#: 316415
2006 WRX
This, check and make sure all lines are still connected.
Old 04-04-2013, 02:14 PM   #15
skimpreza06
Member#: 304086
hey guys so i checked all lines again, and everything is perfect. I unplugged the bcs and tested it with 2 wires connected to a battery and the bcs was working fine. it was making a click click noise when the current was passing through. Even diconnected the battery and reset the ecu. took it out for a spin and it was the same story still blocks at 7psi. what should i do now?
Old 04-04-2013, 02:24 PM   #16
thehanz123
Member#: 318418
rally blue
Do you have a restrictor pill??
Old 04-04-2013, 02:34 PM   #17
skimpreza06
Member#: 304086
yes i verified and the restrictor pill is there!
Old 04-04-2013, 02:38 PM   #18
thehanz123
Member#: 318418
rally blue
Ever done a boost leak test?
Old 04-04-2013, 03:02 PM   #19
skimpreza06
Member#: 304086
no ive never done a boost leak test, but before i washed it i never had problems.
i read on another thread about disconnecting the wg nipple and driving around to see if it will boost more than 7 psi, and it did, it went over 7 psi but it bucked at one point and i have a check engine light that came on. i will check the code tomorrow to see what it gives me.
Old 04-04-2013, 03:33 PM   #20
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
omg dooooooode do the boost leak test////
you could have pushed a vacuum line off or something weird when you powerwashed your engine bay. "checking all lines" isn't good enough. you can visually see the underside of the turbo inlet, or your y-pipe under your tmic, or see a small pin size hole in a random line.
Old 04-04-2013, 03:38 PM   #21
skimpreza06
Member#: 304086
im guessing boost leak test is my next option. but im telling you guys i did not touch anything nor was the water pressure strong. IMO i think its something electrical that has to do with bcs.
Old 04-04-2013, 03:43 PM   #22
skimpreza06
Member#: 304086
should i change the bcs? even after testing it and hearing it click?
Old 04-04-2013, 04:01 PM   #23
thehanz123
Member#: 318418
rally blue
Im currently in the same position as you and awaiting to complete the diy boost leak tester...
Its better to not replace parts that are already good because your problem will still be there.
